PESD5V0S1BA
Bidirectional ESD protection diode
23 August 2018
Product data sheet
1. General description
Bidirectional ElectroStatic Discharge (ESD) protection diode in very small SOD323 (SC-76) SM
plastic package designed to protect one signal line from the damage caused by ESD and other
transients.
2. Features and benefits
Bidirectional ESD protection of one line
Max. peak pulse power: PPPM = 130 W
Low clamping voltage: V(CL)R = 14 V
Low leakage current: IRM = 5 nA
ESD protection > 30 kV
IEC 61000-4-2, level 4 (ESD)
IEC 61000-4-5 (surge); IPPM = 12 A
Very small SMD plastic package
AEC-Q101 qualified
3. Applications
Cellular handsets and accessories
Portable electronics
Computers and peripherals
Communication systems
Audio and video equipment
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
Cd
diode capacitance
f = 1 MHz; VR = 0 V; Tamb = 25 °C
35
45
pF
PESD5V0S1BA
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K1
cathode (diode 1)
2
K2
cathode (diode 2)
Simplified outline
1
Graphic symbol
2
K1
K2
sym045
SOD323
6. Ordering information
Table 3. Ordering information
Type number
Package
PESD5V0S1BA
Name
Description
Version
SOD323
plastic, surface-mounted package; 2 leads; 1.3 mm pitch; 1.7
mm x 1.25 mm x 0.95 mm body
SOD323
7. Marking
Table 4. Marking codes
Type number
Marking code
PESD5V0S1BA
E6
PESD5V0S1BA
Product data sheet
All information provided in this document is subject to legal disclaimers.
23 August 2018
Nexperia B.V. 2018. All rights reserved
2 / 10
PESD5V0S1BA
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
PPPM
rated peak pulse power
tp = 8/20 µs
[1] [2]
130
W
IPPM
rated peak pulse current
Tj
junction temperature
[1] [2]
12
A
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
30
kV
10
kV
Per diode
ESD maximum ratings
VESD
[1]
[2]
[3]
electrostatic discharge
voltage
IEC 61000-4-2 (contact discharge)
[2] [3]
HBM MIL-Std 883
Non-repetitive current pulse 8/20 μs exponentially decaying waveform according to IEC 61000-4-5
Measured from pin 1 to pin 2.
Device stressed with ten non-repetitive ElectroStatic Discharge (ESD) pulses
001aaa191
mle218
120
Ipp
100 %
100 % Ipp; 8 µs
Ipp
90 %
80
e- t
50 % Ipp; 20 µs
40
10 %
Fig. 1.
t (µs)
8/20 µs pulse waveform according to
IEC 61000-4-5
PESD5V0S1BA
Product data sheet
40
t
tr = 0.7 to 1 ns
30 ns
60 ns
Fig. 2.
ESD pulse waveform according to
IEC 61000-4-2
23 August 2018
3 / 10
PESD5V0S1BA
Nexperia
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
VBR
breakdown voltage
IR = 1 mA; Tamb = 25 °C
5.5
9.5
V
IRM
reverse leakage current VRWM = 5 V; Tamb = 25 °C
5
100
nA
Cd
diode capacitance
35
45
pF
VCL
clamping voltage
IPP = 1 A; Tamb = 25 °C
[1] [2]
10
V
IPPM = 12 A; Tamb = 25 °C
[1] [2]
14
V
50
Ω
rdif
[1]
[2]
differential resistance
Non-repetitive current pulse 8/20 µs exponentially decaying waveform according to IEC61000-4-5.
Measures from pin 1 to pin 2.
001aaa202
103
001aaa193
1.2
PPP
PPP(25°C)
PPP
(W)
0.8
102
0.4
10
1
102
10
103
tp (µs)
Tamb = 25 °C
Fig. 3.
Peak pulse power as a function of exponential
pulse duration; typical values
Fig. 4.
001aaa203
38
100
150
200
Relative variation of peak pulse power as a
function of junction temperature; typical values
001aaa204
102
Cd
(pF)
Tj (°C)
IRM(Tj)
IRM(Tj=85°C)
34
10
30
1
26
22
2
3
4
VR (V)
10- 1
5
f = 1 MHz; Tamb = 25 °C
Fig. 5.
Diode capacitance as a function of reverse
voltage; typcial values
PESD5V0S1BA
Product data sheet
Fig. 6.
75
125
Tj (°C)
150
Relative variation of reverse leakage current
as a function of junction temperature; typical
values
23 August 2018
100
4 / 10
PESD5V0S1BA
Nexperia
ESD TESTER
RG 223/U
50 Ω coax
RZ
4 GHz DIGITAL
OSCILLOSCOPE
40 dB
ATTENUATOR
CZ
50 Ω
PESD5V0S1Bx
IEC 61000-4-2 network
CZ = 150 pF; RZ = 330 Ω
vertical scale = 200 V/div
horizontal scale = 50 ns/div
vertical scale = 10 V/div
GND
GND
unclamped +1 kV ESD voltage waveform
(IEC61000-4-2 network)
GND
GND
unclamped -1 kV ESD voltage waveform
Fig. 7.
006aaa056
ESD clamping test setup and waveforms
PESD5V0S1BA
Product data sheet
23 August 2018
5 / 10
PESD5V0S1BA
Nexperia
10. Application information
The device is designed for the protection of one bidirectional data or signal line from the damage
caused by ESD and/or other surge pulses. The device may be used on lines where the signal
polarities are both, positive and negative with respect to ground. It provides a surge capability of
130 W per line for an 8/20 μs waveform.
line to be protected
GND
aaa-002737
Fig. 8.
Bidirectional protection of one signal line
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge
transients. The following guidelines are recommended:
1.
2.
3.
4.
5.
6.
7.
Place the device as close to the input terminal or connector as possible.
Minimize the path length between the device and the protected line.
Avoid running protected conductors in parallel with unprotected conductors.
Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops.
Minimize the length of the transient return path to ground.
Avoid using shared transient return paths to a common ground point.
Use ground planes whenever possible. For multilayer PCBs, use ground vias.
11. Test information
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
12. Package outline
1.35
1.15
1.1
0.8
0.45
0.15
1
2.7
2.3
1.8
1.6
2
0.40
0.25
0.25
0.10
Dimensions in mm
Fig. 9.
03-12-17
Package outline SOD323
PESD5V0S1BA
Product data sheet
23 August 2018
6 / 10
PESD5V0S1BA
Nexperia
13. Soldering
3.05
2.1
solder lands
solder resist
1.65 0.95
0.5 (2×)
0.6 (2×)
solder paste
occupied area
2.2
Dimensions in mm
0.5
(2×)
0.6
(2×)
sod323_fr
Fig. 10. Reflow soldering footprint for SOD323
5
2.9
1.5 (2×)
solder lands
solder resist
occupied area
1.2
2.75
(2×)
Dimensions in mm
preferred transport
direction during soldering
sod323_fw
Fig. 11. Wave soldering footprint for SOD323
PESD5V0S1BA
Product data sheet
23 August 2018
7 / 10
PESD5V0S1BA
Nexperia
14. Revision history
Table 7. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PESD5V0S1BA v.1
20180823
Product data sheet
PESD5V0S1BA
_BB_BL_4
Modifications:
Features and benefit AEC-Q101 qualified added.
AEC-Q101 quality information added.
Limiting values; Tamb updated to -55°C.
Application information: updated.
Soldering section added.
The format of this data sheet had been redesigned to comply with the identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
PESD5V0S1BA
_BB_BL_4
20090820
Product data sheet
PESD5V0S1BA
_BB_BL_3
PESD5V0S1BA
_BB_BL_3
20041217
Product data sheet
PESD5V0S1BA
_BB_BL_2
PESD5V0S1BA
_BB_BL_2
20040322
Product specification
PESD5V0S1BA
_BB_BL_1
PESD5V0S1BA
_BB_BL_1
20040304
PESD5V0S1BA
Product data sheet
23 August 2018
8 / 10
PESD5V0S1BA
Nexperia
15. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
PESD5V0S1BA
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
23 August 2018
9 / 10
PESD5V0S1BA
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Characteristics.............................................................. 4
10. Application information............................................. 6
11. Test information.......................................................... 6
12. Package outline.......................................................... 6
13. Soldering..................................................................... 7
14. Revision history..........................................................8
15. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 23 August 2018
PESD5V0S1BA
Product data sheet
23 August 2018
10 / 10
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
PESD5V0L1BAZ PESD5V0S1BAF PESD5V0S1BA/8F PESD5V0S1BA/8X
