74AUP1G19
Low-power 1-of-2 decoder/demultiplexer
Rev. 5 — 6 November 2014
Product data sheet
1. General description
The 74AUP1G19 provides a 1-of-2 decoder/demultiplexer with a common output enable.
It buffers the data on input pin A and passes it either to output pin 1Y (true) or 2Y
(complement), depending on whether the state of the enable input pin E is LOW or HIGH,
respectively.
Schmitt trigger action at all inputs makes the circuit tolerant to slower input rise and fall
times across the entire VCC range from 0.8 V to 3.6 V.
This device ensures a very low static and dynamic power consumption across the entire
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 0.8 V to 3.6 V
High noise immunity
Complies with JEDEC standards:
JESD8-12 (0.8 V to 1.3 V)
JESD8-11 (0.9 V to 1.65 V)
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-B (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 5000 V
MM JESD22-A115-A exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Low static power consumption; ICC = 0.9 A (maximum)
Latch-up performance exceeds 100 mA per JESD 78 Class II
Inputs accept voltages up to 3.6 V
Low noise overshoot and undershoot < 10 % of VCC
IOFF circuitry provides partial Power-down mode operation
Multiple package options
Specified from 40 C to +85 C and 40 C to +125 C
74AUP1G19
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AUP1G19GW
40 C to +125 C
SC-88
plastic surface-mounted package; 6 leads
SOT363
74AUP1G19GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74AUP1G19GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74AUP1G19GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74AUP1G19GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
4. Marking
Table 2.
Marking
Marking code[1]
Type number
74AUP1G19GW
pY
74AUP1G19GM
pY
74AUP1G19GF
pY
74AUP1G19GN
pY
74AUP1G19GS
pY
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
PQE
Fig 1.
Logic symbol
74AUP1G19
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 20
74AUP1G19
Nexperia
6. Pinning information
6.1 Pinning
74AUP1G19
74AUP1G19
A
1
6
A
1
6
1Y
GND
2
5
VCC
1Y
GND
2
5
VCC
E
3
4
2Y
E
3
4
2Y
A
1
6
1Y
GND
2
5
VCC
E
3
4
2Y
001aai074
001aai073
Transparent top view
001aai072
Fig 2.
74AUP1G19
Pin configuration SOT363
Fig 3.
Pin configuration SOT886
Fig 4.
Pin configuration SOT891,
SOT1115 and SOT1202
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
A
1
data input
GND
2
ground (0 V)
E
3
enable input (active LOW)
2Y
4
data output (complement)
VCC
5
supply voltage
1Y
6
data output (true)
7. Functional description
Table 4.
Function table[1]
Input
Output
E
A
1Y
2Y
L
L
L
H
L
H
H
L
H
L
H
H
H
H
H
H
[1]
H = HIGH voltage level; L = LOW voltage level.
74AUP1G19
Product data sheet
3 of 20
74AUP1G19
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
VI < 0 V
[1]
VO < 0 V
[1]
Min
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
0.5
+4.6
V
VO
output voltage
Active mode and Power-down mode
IO
output current
VO = 0 V to VCC
mA
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[2]
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SC-88 packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 packages: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Operating conditions
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Tamb
ambient temperature
t/V
input transition rise and fall rate
74AUP1G19
Product data sheet
Min
Max
Unit
0.8
3.6
V
V
Active mode
VCC
V
Power-down mode; VCC = 0 V
V
40
+125
C
ns/V
VCC = 0.8 V to 3.6 V
4 of 20
74AUP1G19
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
VCC = 0.8 V
VCC = 0.9 V to 1.95 V
Typ
Max
Unit
0.70 VCC -
V
0.65 VCC -
V
VCC = 2.3 V to 2.7 V
1.6
V
VCC = 3.0 V to 3.6 V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
IO = 20 A; VCC = 0.8 V to 3.6 V
VCC 0.1
V
IO = 1.1 mA; VCC = 1.1 V
0.75 VCC -
V
IO = 1.7 mA; VCC = 1.4 V
1.11
V
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VI = VIH or VIL
IO = 1.9 mA; VCC = 1.65 V
1.32
V
IO = 2.3 mA; VCC = 2.3 V
2.05
V
IO = 3.1 mA; VCC = 2.3 V
1.9
V
IO = 2.7 mA; VCC = 3.0 V
2.72
V
IO = 4.0 mA; VCC = 3.0 V
2.6
V
0.1
V
0.3 VCC
V
VI = VIH or VIL
0.31
V
0.31
V
0.31
V
0.44
V
0.31
V
0.44
V
II
input leakage current
VI = GND to 3.6 V; VCC = 0 V to 3.6 V
0.1
A
IOFF
power-off leakage current
VI or VO = 0 V to 3.6 V; VCC = 0 V
0.2
A
IOFF
additional power-off
leakage current
VCC = 0 V to 0.2 V
0.2
A
ICC
supply current
VI = GND or VCC; IO = 0 A;
0.5
A
ICC
additional supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 3.3 V
40
A
CI
input capacitance
VCC = 0 V to 3.6 V; VI = GND or VCC
0.8
pF
CO
output capacitance
VO = GND; VCC = 0 V
1.7
pF
74AUP1G19
Product data sheet
[1]
5 of 20
74AUP1G19
Nexperia
Table 7.
Static characteristics …continued
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.70 VCC -
V
0.65 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.30 VCC V
0.35 VCC V
0.7
V
0.9
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC 0.1
V
0.7 VCC
V
1.03
V
1.30
V
1.97
V
1.85
V
2.67
V
2.55
V
0.1
V
0.3 VCC
V
0.37
V
VI = VIH or VIL
0.35
V
0.33
V
0.45
V
0.33
V
0.45
V
II
0.5
A
IOFF
0.5
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.6
A
ICC
supply current
0.9
A
ICC
VCC = 3.3 V
50
A
74AUP1G19
Product data sheet
[1]
6 of 20
74AUP1G19
Nexperia
Table 7.
Symbol Parameter
Conditions
Min
VCC = 0.8 V
Typ
Max
Unit
0.75 VCC -
V
0.70 VCC -
V
1.6
V
2.0
V
VCC = 0.8 V
0.25 VCC V
0.30 VCC V
0.7
V
0.9
V
VIH
VIL
VOH
VOL
VI = VIH or VIL
VCC 0.11 -
V
0.6 VCC
V
0.93
V
1.17
V
1.77
V
1.67
V
2.40
V
2.30
V
0.11
V
0.33 VCC V
0.41
V
VI = VIH or VIL
0.39
V
0.36
V
0.50
V
0.36
V
0.50
V
II
0.75
A
IOFF
0.75
A
IOFF
leakage current
VCC = 0 V to 0.2 V
0.75
A
ICC
supply current
1.4
A
ICC
VCC = 3.3 V
75
A
[1]
[1]
One input at VCC 0.6 V, other input at VCC or GND.
74AUP1G19
Product data sheet
7 of 20
74AUP1G19
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 6.
Symbol Parameter
Tamb = 25 C
Conditions
Tamb =40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
15.9
VCC = 1.1 V to 1.3 V
2.3
5.3
11.5
2.1
11.9
12.0
ns
VCC = 1.4 V to 1.6 V
2.1
3.8
6.8
2.0
7.5
7.8
ns
VCC = 1.65 V to 1.95 V
1.6
3.1
5.4
1.5
6.1
6.4
ns
1.4
2.3
4.0
1.2
4.2
4.5
ns
1.3
2.0
3.4
1.0
3.8
4.1
ns
17.8
ns
2.4
5.8
11.6
2.1
12.0
12.1
ns
CL = 5 pF
tpd
propagation delay A to nY; see Figure 5
[2]
VCC = 0.8 V
E to nY; see Figure 5
ns
[2]
VCC = 0.8 V
2.0
4.2
6.9
1.9
7.5
7.8
ns
1.6
3.4
5.6
1.5
6.2
6.5
ns
1.4
2.6
4.0
1.3
4.5
4.8
ns
1.3
2.2
3.4
1.2
3.7
3.9
ns
18.9
ns
2.5
6.2
13.8
2.5
13.9
14.1
ns
CL = 10 pF
tpd
[2]
VCC = 0.8 V
2.3
4.5
8.2
2.1
8.5
8.9
ns
2.1
3.7
6.3
2.0
6.8
7.2
ns
1.7
2.9
4.7
1.6
5.0
5.3
ns
1.6
2.6
4.0
1.4
4.4
4.7
ns
21.0
ns
2.6
6.7
13.4
2.5
13.9
14.1
ns
2.3
4.8
8.2
2.1
8.8
9.1
ns
VCC = 0.8 V
74AUP1G19
Product data sheet
[2]
2.1
4.0
6.4
1.9
7.0
7.3
ns
1.8
3.1
4.7
1.6
5.1
5.5
ns
1.6
2.8
4.2
1.4
4.4
4.7
ns
8 of 20
74AUP1G19
Nexperia
Table 8.
Dynamic characteristics …continued
Symbol Parameter
Tamb = 25 C
Conditions
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
21.8
ns
3.0
7.0
15.2
2.7
15.8
16.1
ns
CL = 15 pF
tpd
[2]
VCC = 0.8 V
2.8
5.0
9.0
2.5
9.8
10.2
ns
2.3
4.2
7.0
2.2
7.8
8.2
ns
2.1
3.4
5.3
1.9
5.6
6.0
ns
1.9
3.0
4.6
1.7
5.2
5.4
ns
24.2
ns
3.0
7.5
15.1
2.8
15.7
16.0
ns
2.8
5.4
9.1
2.5
10.0
10.4
ns
[2]
VCC = 0.8 V
2.3
4.5
7.2
2.2
8.0
8.4
ns
2.1
3.6
5.4
2.0
5.8
6.2
ns
1.9
3.2
4.7
1.8
5.1
5.4
ns
30.4
ns
3.6
9.2
20.5
3.6
21.3
21.7
ns
3.2
6.6
11.5
3.3
12.8
13.4
ns
3.1
5.5
9.5
3.0
10.0
10.6
ns
2.9
4.6
6.3
2.6
7.2
7.7
ns
2.7
4.2
5.9
2.5
7.0
7.4
ns
CL = 30 pF
tpd
[2]
VCC = 0.8 V
VCC = 0.8 V
74AUP1G19
Product data sheet
[2]
33.6
ns
3.6
9.8
20.0
3.5
20.9
21.3
ns
3.2
7.0
11.6
3.3
12.8
13.5
ns
3.1
5.8
9.3
3.0
10.3
10.9
ns
2.9
4.7
6.8
2.7
7.4
7.9
ns
2.7
4.3
6.0
2.5
7.0
7.4
ns
9 of 20
74AUP1G19
Nexperia
Table 8.
Symbol Parameter
Tamb = 25 C
Conditions
Unit
Min
Typ[1]
Max
Min
Max
(85 C)
Max
(125 C)
VCC = 0.8 V
5.0
pF
5.3
pF
5.5
pF
5.8
pF
6.7
pF
7.6
pF
CL = 5 pF, 10 pF, 15 pF and 30 pF
power dissipation
capacitance
CPD
fi = 1 MHz; VI = GND to VCC
[1]
All typical values are measured at nominal VCC.
[2]
tpd is the same as tPLH and tPHL.
[3]
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of the outputs.
12. Waveforms
9,
90
$(LQSXW
90
*1'
W 3+/
W 3/+
92+
Q
很抱歉,暂时无法提供与“74AUP1G19GF,132”相匹配的价格&库存,您可以联系我们找货
