IRLML6402TRPBF
www.VBsemi.tw
P-Channel 20-V (D-S) MOSFET
FEATURES
MOSFET PRODUCT SUMMARY
RDS(on) ()
ID (A)a
0.035 at VGS = - 10 V
- 5e
0.043 at VGS = - 4.5 V
-5e
0.061 at VGS = - 2.5 V
- 4.8
VDS (V)
- 20
Qg (Typ.)
10 nC
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg Tested
• Compliant to RoHS Directive 2002/95/EC
APPLICATIONS
• Load Switch
• PA Switch
• DC/DC Converters
TO-236
(SOT-23)
G
1
3
S
D
2
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
Maximum Power Dissipation
ID
IDM
Pulsed Drain Current
Continuous Source-Drain Diode Current
Limit
- 20
± 12
- 5e
- 4.8
- 4.5b, c
- 3.5b, c
- 18
- 2.1
- 1.0b, c
2.5
1.6
1.25b, c
0.8b, c
- 55 to 150
TC = 25 °C
TA = 25 °C
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
IS
PD
TJ, Tstg
Operating Junction and Storage Temperature Range
Unit
V
A
W
°C
THERMAL RESISTANCE RATINGS
Parameter
5 s
Maximum Junction-to-Ambientb, d
Steady State
Maximum Junction-to-Foot (Drain)
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 5 s.
d. Maximum under steady state conditions is 166 °C/W.
e. Package limited.
E-mail:China@VBsemi TEL:86-755-83251052
Symbol
RthJA
RthJF
Typical
75
40
Maximum
100
50
Unit
°C/W
1
IRLML6402TRPBF
www.VBsemi.tw
MOSFET SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VDS = 0 V, ID = - 250 µA
- 20
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS/TJ
VDS Temperature Coefficient
VGS(th) Temperature Coefficient
VGS(th)/TJ
ID = - 250 µA
Gate-Source Threshold Voltage
V
- 13.4
VGS(th)
VDS = VGS, ID = - 250 µA
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 12 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
VDS - 5 V, VGS = - 4.5 V
VGS = - 10 V, ID = - 5.1 A
0.035
RDS(on)
VGS = - 4.5 V, ID = - 4.5 A
0.043
VGS = - 2.5 V, ID = - 3.7 A
0.061
VDS = - 5 V, ID = - 5.1 A
15
VDS = - 10 V, VGS = 0 V, f = 1 MHz
180
Drain-Source On-State
Resistancea
Forward Transconductancea
gfs
mV/°C
2.9
- 0.5
- 1.5
V
± 100
nA
VDS = - 20 V, VGS = 0 V
-1
VDS = - 20 V, VGS = 0 V, TJ = 55 °C
- 10
- 18
µA
A
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
835
155
VDS = - 10 V, VGS = - 4.5 V, ID = - 5.1 A
Turn-On Delay Time
tr
td(off)
Turn-Off Delay Time
VDS = - 10 V, VGS = - 2.5 V, ID = - 5.1 A
nC
1.7
3.4
f = 1 MHz
VDD = - 10 V, RL = 2.4
ID = - 4.1 A, VGEN = - 4.5 V, Rg = 1
tf
Fall Time
10
6.4
td(on)
Rise Time
pF
0.9
4.4
8.8
22
33
28
42
9
18
ns
Drain-Source Body Diode Characteristics
a
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
- 2.1
- 20
IS = - 4.1 A
IF = - 4.1 A, dI/dt = 100 A/µs, TJ = 25 °C
A
- 0.8
- 1.2
V
23
35
ns
12
nC
15
8
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
IRLML6402TRPBF
www.VBsemi.tw
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
5
VGS = 5 V thru 3 V
ID - Drain Current (A)
4
VGS = 2.5 V
15
10
VGS = 2 V
3
2
TC = 25 °C
5
1
TC = 125 °C
VGS = 1.5 V
TC = - 55 °C
1
1.5
2
1
1.5
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
2
1400
0.08
RDS(on) - On-Resistance (Ω)
VGS = 2.5 V
1050
VGS = 4.5 V
0.04
VGS = 10 V
C - Capacitance (pF)
0.06
Ciss
700
350
0.02
Coss
Crss
10
15
10
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
5
ID = 5.1 A
VGS = 10 V
4
VDS = 5 V
(Normalized)
15
3
VDS = 10 V
2
VDS = 16 V
1.3
1.1
0.9
1
VGS = 4.5 V
6
9
12
0.7
- 50
- 25
50
75
100
125
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
150
3
IRLML6402TRPBF
www.VBsemi.tw
0.08
10
TJ = 150 °C
TJ = 25 °C
1
0.1
0.0
IS - Source Current (A)
ID = 5.1 A
0.06
TJ = 25 °C
0.04
TJ = 125 °C
0.02
0.4
0.6
0.8
1.0
1.2
2
4
VSD - Source-to-Drain Voltage (V)
8
10
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
1.1
10
8
Power (W)
1.0
VGS(th) (V)
6
ID = 250 μA
0.8
6
4
0.7
2
0.5
- 50
- 25
50
100
75
125
TA = 25 °C
150
0.1
1
10
100
1000
Time (s)
TJ - Temperature (°C)
Single Pulse Power
Threshold Voltage
100
Limited by RDS(on)*
10
100 μs
1 ms
1
10 ms
100 ms
0.1
TC = 25 °C
Single Pulse
0.01
0.1
BVDSS Limited
1
1 s, 10 s
DC
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
4
IRLML6402TRPBF
www.VBsemi.tw
8
6
Package Limited
4
2
50
75
100
125
150
TC - Case Temperature (°C)
Current Derating*
1
3
2.5
0.8
Power (W)
Power (W)
2
1.5
0.6
0.4
1
0.2
0.5
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power, Junction-to-Foot
Power, Junction-to-Ambient
150
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
IRLML6402TRPBF
www.VBsemi.tw
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
0.02
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 166 °C/W
3. TJM - TA = PDMZthJA(t)
4. Surface Mounted
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
6
IRLML6402TRPBF
www.VBsemi.tw
SOT-23 (TO-236): 3-LEAD
b
3
E1
1
E
2
e
S
e1
D
0.10 mm
C
0.004"
A2
A
C
q
Gauge Plane
Seating Plane
Seating Plane
C
A1
Dim
0.25 mm
L
L1
MILLIMETERS
INCHES
Min
Max
Min
Max
A
0.89
1.12
0.035
0.044
A1
0.01
0.10
0.0004
0.004
A2
0.88
1.02
0.0346
0.040
b
0.35
0.50
0.014
0.020
c
0.085
0.18
0.003
0.007
D
2.80
3.04
0.110
0.120
E
2.10
2.64
0.083
0.104
E1
1.20
1.40
0.047
e
0.95 BSC
e1
L
1.90 BSC
0.40
L1
q
0.0748 Ref
0.60
0.016
0.64 Ref
S
0.024
0.025 Ref
0.50 Ref
3°
0.055
0.0374 Ref
0.020 Ref
8°
3°
8°
ECN: S-03946-Rev. K, 09-Jul-01
DWG: 5479
7
IRLML6402TRPBF
www.VBsemi.tw
0.049
(1.245)
0.029
0.022
(0.559)
(0.724)
0.037
(0.950)
(2.692)
0.106
RECOMMENDED MINIMUM PADS FOR SOT-23
0.053
(1.341)
0.097
(2.459)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index Return to Index
8
IRLML6402TRPBF
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
9
