TSM033NB04LCR
Taiwan Semiconductor
N-Channel Power MOSFET
40V, 121A, 3.3mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
PARAMETER
VALUE
UNIT
VDS
40
V
● Logic level
● Low gate charge for fast power switching
● 100% UIS and Rg tested.
RDS(on) (max)
● 175°C Operating Junction Temperature
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
VGS = 10V
3.3
VGS = 4.5V
4
mΩ
Qg
40
nC
APPLICATIONS
BLDC Motor Control
Battery Power Management
DC-DC converter
Secondary Synchronous Rectification
PDFN56
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
40
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
TC = 25°C
(Note 1)
ID
TA = 25°C
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
121
21
A
IDM
484
A
IAS
EAS
34
173
A
mJ
PD
PD
107
36
3.1
1
W
W
TJ, TSTG
- 55 to +175
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
1.4
°C/W
Junction to Ambient Thermal Resistance
RӨJA
48
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is
2
determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper.
1
Version: B1804
TSM033NB04LCR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
40
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1
1.6
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
2.3
3.3
3.2
4
gfs
63
Qg
79
Qg
40
Qgs
12
Qgd
19
Ciss
4456
Coss
475
Crss
276
Rg
0.4
1.5
2.9
td(on)
3
tr
21
td(off)
47
tf
25
VSD
1
V
VGS = 0V, VDS = 40V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 40V
TJ = 125°C
Drain-Source On-State Resistance
VGS = 10V, ID = 21A
(Note 3)
VGS = 4.5V, ID = 19A
Forward Transconductance
Dynamic
(Note 3)
RDS(on)
VDS = 10V, ID = 21A
µA
mΩ
S
(Note 4)
VGS = 10V, VDS = 20V,
Total Gate Charge
ID = 21A
Total Gate Charge
VGS = 4.5V, VDS = 20V,
Gate-Source Charge
ID = 19A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 20V
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
ID = 21A, RG = 2Ω
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 21A
Reverse Recovery Time
IS = 21A ,
trr
26
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
17
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 34A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSM033NB04LCR RLG
PDFN56
2,500pcs / 13” Reel
2
Version: B1804
TSM033NB04LCR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
40
40
ID, Drain Current (A)
24
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
VGS=4V
VGS=3.5V
VGS=3V
32
16
8
32
24
25℃
16
8
175℃
2
3
4
On-Resistance vs. Drain Current
3
4
10
0.005
0.004
VGS=4.5V
0.003
0.002
VGS=10V
0.001
VDS=20V
ID=21A
8
6
4
2
VGS=10V
ID=21A
1.5
1
0.5
50
75 100 125 150 175
60
80
On-Resistance vs. Gate-Source Voltage
RDS(on), Drain-Source On-Resistance (Ω)
On-Resistance vs. Junction Temperature
2.5
40
Qg, Gate Charge (nC)
(Normalized)
2
Gate-Source Voltage vs. Gate Charge
0.006
VGS, Gate to Source Voltage (V)
R DS(on), Drain-Source On-Resistance (Ω)
1
VDS, Drain to Source Voltage (V)
2
-55℃
TJ, Junction Temperature (°C)
0.02
0.015
0.01
0.005
ID=21A
4
5
6
7
8
9
10
3
Version: B1804
TSM033NB04LCR
BVDSS vs. Junction Temperature
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
C, Capacitance (pF)
6000
5000
CISS
4000
3000
2000
CRSS
1000
COSS
ID=5mA
1.1
1
0.9
0.8
40
-75 -50 -25
25
50
75 100 125 150 175
Maximum Safe Operating Area, Junction-to-Case
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
1000
RDS(ON)
100
10
SINGLE PULSE
RӨJC=1.4°C/W
TC=25°C
1
10
175℃
1
25℃
-55℃
0.1
0.1
1
10
100
0.2
0.4
0.6
0.8
1
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
10
Normalized Effective Transient
Thermal Impedance, ZӨJC
SINGLE PULSE
RӨJC=1.4°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: B1804
TSM033NB04LCR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
PDFN56
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
033NB04L
GYWWF
G
Y
WW
F
5
TSC
033NB04L
GYWWF
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
Version: B1804
TSM033NB04LCR
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: B1804
