TSM3401
Taiwan Semiconductor
P-Channel Power MOSFET
-30V, -3A, 60mΩ
KEY PERFORMANCE PARAMETERS
Features
Advance Trench Process Technology
High Density Cell Design for Ultra Low Onresistance
PARAMETER
VALUE
UNIT
VDS
-30
V
RDS(on) (max)
Pb-free plating
RoHS compliant
Halogen-free package
VGS = -10V
60
VGS = -4.5V
90
Qg
9.52
mΩ
nC
Application
Load Switch
PA Switch
SOT-23
Notes: Moisture sensitivity level: level 3. Per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
ID
-3
A
IDM
-10
A
IS
-1.9
A
Continuous Drain Current
Pulsed Drain Current
(Note 1)
TA = 25°C
(Note 2)
Continuous Source Current (Diode Conduction)
Total Power Dissipation
TA = 25°C
TA = 70°C
Operating Junction and Storage Temperature Range
PDTOT
1.25
0.8
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
75
°C/W
Junction to Ambient Thermal Resistance
RӨJA
100
°C/W
THERMAL PERFORMANCE
PARAMETER
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000072
1
Version: D15
TSM3401
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 3)
Drain-Source Breakdown Voltage
VGS = 0V, ID = -250µA
BVDSS
-30
V
Gate Threshold Voltage
VDS = VGS, ID = -250µA
VGS(TH)
-1.0
-1.5
-3.0
V
Gate Body Leakage
VGS = ±20V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = -24V, VGS = 0V
IDSS
-1
µA
On-State Drain Current
VDS = -5V, VGS = -10V
ID(ON)
-6
A
50
60
75
90
gfs
4
7
Qg
9.52
Qgs
3.43
Qgd
1.71
Ciss
551.57
Coss
90.96
Drain-Source On-State Resistance
Forward Transconductance
Dynamic
VGS = -10V, ID = -3A
VGS = -4.5V, ID = -2A
VDS = -15V, ID = -5A
RDS(ON)
mΩ
S
(Note 4)
Total Gate Charge
VDS = -15V, ID = -3A,
Gate-Source Charge
VGS = -10V
Gate-Drain Charge
Input Capacitance
VDS = -15V, VGS = 0V,
Output Capacitance
Reverse Transfer Capacitance
Switching
f = 1.0MHz
Crss
nC
pF
60.79
(Note 5)
Turn-On Delay Time
VDD = -15V,
Turn-On Rise Time
RGEN = 6Ω,
Turn-Off Delay Time
ID = -1A, VGS = -10V,
Turn-Off Fall Time
Source-Drain Diode
td(on)
10.8
tr
2.33
td(off)
22.53
tf
3.87
VSD
-0.8
-1.3
ns
(Note 3)
Forward On Voltage
IS = -1.9 A, VGS = 0V
V
Notes:
1.
Pulse width limited by the maximum junction temperature.
2.
Surface Mounted on FR4 Board, t ≤ 5 sec.
3.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
4.
For DESIGN AID ONLY, not subject to production testing.
5.
Switching time is essentially independent of operating temperature.
2
Version: D15
TSM3401
ORDERING INFORMATION
PART NO.
TSM3401CX RFG
PACKAGE
PACKING
SOT-23
3,000pcs / 7” Reel
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: D15
TSM3401
CHARACTERISTICS CURVES
Output Characteristics
ID, Drain Current (A)
ID, Continuous Drain Current (A)
Transfer Characteristics
VDS, Drain to Source Voltge(V)
VGS, Gate to Source Voltge(V)
On-Resistance vs. Drain Current
RDS(on), On Resistance (mΩ)
-VGS, Gate to Source Voltage (V)
Gate Charge
Qg, Total Gate Charge (nC)
ID, Drain Current(A)
Source-Drain Diode Forward Voltage
IS, Source Current (A)
Normalized On Resistance (mΩ)
On-Resistance vs. Junction Temperature
VSD, Source to Drain Voltge(V)
TJ, Junction Temperature (°C)
4
Version: D15
TSM3401
On-Resistance vs. Gate-Source Voltage
VGS(th), Variance (V)
Threshold Voltage
Power (W)
Single Pulse Power
Time (sec)
Normalized Thermal Transient Impedance Curve
Square Wave Pulse Duration (s)
5
Version: D15
TSM3401
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-23
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
Y
M
L
= Year Code
= Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R
S =May T =Jun U =Jul
V
W =Sep X =Oct Y =Nov Z
= Lot Code (1~9, A~Z)
6
=Apr
=Aug
=Dec
Version: D15
TSM3401
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular
purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: D15
