TSF30H60C
Taiwan Semiconductor
30A, 60V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low power loss, high efficiency
High forward surge capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
PARAMETER
VALUE
UNIT
IF
2 x 15
A
VRRM
60
V
IFSM
230
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.75g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSF30H60C
UNIT
TSF30H60C
Repetitive peak reverse voltage
VRRM
60
V
Reverse voltage, total rms value
VR(RMS)
42
V
30
A
15
A
230
A
620
A
Forward current
per device
IF
per diode
Surge peak forward current single half sine- t = 8.3ms
wave superimposed on rated load per diode t = 1.0ms
IFSM
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: D2102
TSF30H60C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance per diode
RӨJL
3.4
°C/W
Junction-to-ambient thermal resistance per diode
RӨJA
14.8
°C/W
Junction-to-case thermal resistance per diode
RӨJC
3.0
°C/W
Thermal Performance Note: Mounted on Heat sink with 2" x 3" x 0.25" Al-Plate.
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 7.5A, TJ = 25°C
Forward voltage per diode
IF = 15A, TJ = 25°C
(1)
IF = 7.5A, TJ = 125°C
VF
IF = 15A, TJ = 125°C
Reverse current @ rated VR per diode
Junction capacitance per diode
(2)
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
IR
CJ
TYP
MAX
UNIT
0.47
V
0.55
0.70
V
0.38
V
0.50
0.67
V
50
µA
45
mA
1117
pF
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSF30H60C
ITO-220AB
50 / Tube
2
Version: D2102
TSF30H60C
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
30
25
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
35
10
1000
100
5
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
10
150
1
10
CASE TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
TJ=150°C
10000
TJ=125°C
100
10
TJ=25°C
1
10
40
50
60
70
80
90 100
10010
UF1DLW
1
TJ=150°C
TJ=125°C
10
0.1
TJ=25°C
TJ=125°C
(A)
INSTANTANEOUS FORWARD CURRENT (A)
100000
TJ=25°C
1
0.01
TJ=-55°C
Pulse
width
Pulse width
300μs
1% duty cycle
0.001
0.1
0.3
0.4
0.5
0.6
0.7
0.8
0.9
0.1 0.2 0.3 0.4 0.5 0.6 0.7
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1
0.8
1.1
FORWARD VOLTAGE (V)
Fig.5 Typical Transient Thermal Impedance
10
TRANSIENT THERMAL IMPEDANCE (°C/W)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
1000
100
REVERSE VOLTAGE (V)
1
0.1
0.01
0.001
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
PULSE DURATION (s)
3
Version: D2102
1.2
TSF30H60C
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: D2102
TSF30H60C
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: D2102
很抱歉,暂时无法提供与“TSF30H60C C0G”相匹配的价格&库存,您可以联系我们找货
