MMBT2222A
NPN General Purpose Amplifier
FEATURES
Epitaxial planar die construction.
Complementary PNP type available
MMBT2907A.
Ultra-small surface mount package.
MSL 1
1P
APPLICATIONS
Use as a medium power amplifier.
Switching requiring collector currents up to 500mA.
SOT-23
CR
MI
JS
Symbol
Parameter
O
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
mi
Se
Value
Unit
75
V
VCBO
Collector-Base Voltage
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
600
mA
1.5
A
Collector Current -Continuous
ICM
Collector Current –Peak pulse width≤40us,δ
= 0.35
PC
Collector Dissipation
Alumina Substrate (Note 1) TA = 25°C
PC
FR−5 Board (Note 2) TA = 25°C
nd
co
IC
300
mW
uc
mW
RθJA
Thermal resistance junction to ambient
417
°C/W
RθjC
Thermal Resistance Junction to Case
250
°C/W
TJ,TSTG
Junction and Storage Temperature
-55 to +150
225
r
to
°C
Note 1. FR−5 = 1.0 0.75 0.062 in.
Note 2. Alumina = 0.4 0.3 0.024 in. 99.5% alumina.
www.jsmsemi.com
第1/4页
MMBT2222A
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Symbol
Test conditions
MIN
Collector-base breakdown voltage
V(BR)CBO
IC=10μA IE=0
75
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=10mA IB=0
40
V
Emitter-base breakdown voltage
V(BR)EBO
IE=10μA IC=0
6
V
Collector cut-off current
ICBO
VCB=60V IE=0
0.01
μA
ICEX
VCE=60V,VBE=-3.0V
0.01
μA
Emitter cut-off current
IEBO
VEB=3V IC=0
0.01
μA
MI
JS
hFE
O
CR
DC current gain
VCE=10V IC=150mA
100
VCE=10V IC=0.1mA
35
VCE=10V IC=1.0mA
50
VCE=10V IC=10mA
75
VCE=10V IC=10mA
TA=-55℃
35
VCE=10V IC=500mA
40
VCE=1V IC=150mA
50
TYP
MAX
UNIT
300
mi
Se
Collector-emitter saturation voltage
VCE(sat)
IC=500mA IB=50mA
IC=150mA IB=15mA
1.0
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=500mA IB=50mA
IC=150mA IB=15mA
2.0
1.2
V
Transition frequency
fT
VCE=20V IC=20mA
f=100MHz
Output capacitance
Cobo
VCB=10V,IE=0,f=1.0MHz
8.0
pF
Input capacitance
Cibo
VEB=0.5V,IC=0,
f=1.0MHz
25
pF
Delay time
td
Rise time
tr
Storage time
ts
Fall time
tf
co
0.6
300
MHz
10
ns
25
ns
225
ns
60
ns
r
to
uc
nd
Vcc=30V, VBE(off)=-0.5V
IC=150mA , IB1= 15mA
VCC=30V, IC=150mA
IB1=-IB2=15mA
ESD RATING
Characteristic
Symbol
Value
Unit
JEDEC Class
Electrostatic Discharge - Human Body Model
ESD HBM
4,000
V
3A
Electrostatic Discharge - Machine Model
ESD MM
400
V
C
www.jsmsemi.com
第2/4页
MMBT2222A
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
O
CR
MI
JS
r
to
uc
nd
co
mi
Se
www.jsmsemi.com
第3/4页
MMBT2222A
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
SOT-23
A
Dim
Min
Max
A
2.70
3.10
B
1.10
1.50
C
0.90
1.10
D
0.30
0.50
E
0.35
0.48
G
1.80
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
E
K
B
JS
J
D
MI
G
CR
H
C
O
All Dimensions in mm
0.95
0.95
nd
co
mi
Se
SOLDERING FOOTPRINT
0.90
r
Unit : mm
0.80
to
uc
2.00
PACKAGE INFORMATION
Device
Package
Shipping
MMBT2222A
SOT-23
3000 pcs / Tape & Reel
www.jsmsemi.com
第4/4页
很抱歉,暂时无法提供与“MMBT2222A”相匹配的价格&库存,您可以联系我们找货
