LL4148
SMALL SIGNAL SWITCHING DIODE
REVERSE VOLTAGE: 75 V
CURRENT: 0.15 A
FEATURES
MINI-MELF
Silicon epitaxial diode
High speed switching diode
Cathode indification
φ1 .5±0.1
500mW power dissipation
MECHANICAL DATA
Case:MINI-MELF glass case
Polarity:Color band denotes cathode
0.4±0.1
to
r
3.4 +0.3
-0.1
Weight: Approx 0.031 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
uc
Ratings at 25 oC ambient temperature unless otherwise specified
MAXIMUM RATINGS
Peak reverse voltage
V RM
Average forw ard rectified current
at
tamb=25oC and
f
50Hz
Forw ard surge current at t 1S and TJ =25oC
Junction temperature
Storage temperature range
IFSM
Se
Pow er dissipaton at tamb
=25oC
mi
IO
Half w ave rectification w ith resistive load
75.0
V
100.0
V
150.0
mA
500.00
mA
1)
mW
nd
VR
UNITS
co
Reverse voltage
LL4148
Ptot
500.0
TJ
175.0
o
C
o
35-55--- +175
TSTG
C
CR
O
1) Valid prov ided that electrodes are kept at ambient temperature.
JS
MI
Forw ard voltage @ IF=10mA
MIN
TYP
MAX
UNITS
VF
1.0
V
IR
IR
IR
25.0
5.0
50.0
nA
Ctot
4.0
pF
Vfr
2.5
V
trr
4.0
ns
350.01)
K/W
Leakage current
at V R=20V
at V R=75V
111111111at V R=20V TJ =150oC
Capacitance at V F=V R=0V
A
A
Voltage rise w hen sw itching on
tested w ith 50mA pulses
tp=0,1 S,rise time
30ns, fp=5 to 100KHz
Reverse recovery time
from IF=10mA
V R=6V,RL=100 ,at IR=1mA
Thermal resistance junction to ambient
Rectification effciency at 100MHz,V RF=2V
R
JA
V
0.45
1)Valid prov ided that electrodes are kept at ambient temperature
www,jsmsemi.com
第1/2页
LL4148
FIG.1 -- ADMISSIBLE POWER DISSIPATION VERSUS
AMBIENT TEMPERATURE
FIG.2-- FORWARD CHARACTERISTICS
mW
mA
3
10
1000
900
800
10
IF
700
O
TJ =100 C
600
to
r
Ptot
2
10
500
O
TJ =25 C
400
300
200
-1
nd
10
100
100
-2
175 200℃
T
10
co
uc
1
2V
V
F
CR
O
Se
mi
A
JS
MI
FIG.3-ADMISSIBLE REPETITIVE PEAK FORWORD CURRENT VERSUS PULSE DURATION
100
IFRM
I
V=tp/T
T=1/tp
10
0.1
tp
n=0
0.2
1
IFRM
T
0.3
0.1
-3
-5
10
10
-2
-1
10
10
1
10S
tp
www,jsmsemi.com
第2/2页
很抱歉,暂时无法提供与“LL4148”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.03400
- 50+0.03100
- 500+0.02800
- 1000+0.02500
- 2500+0.02360
- 5000+0.02240
