FDS8447
www.VBsemi.tw
N-Channel 40-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
RDS(on) (Ω)
ID (A)d
0.012 at VGS = 10 V
12
0.012 at VGS = 4.5 V
9
VDS (V)
40
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg Tested
• 100 % UIS Tested
• Compliant to RoHS directive 2002/95/EC
Qg (Typ.)
15 nC
APPLICATIONS
• Synchronous Rectification
• POL, IBC
- Secondary Side
SO-8
S
1
8
D
S
2
7
D
S
3
6
D
G
4
5
D
D
G
Top View
S
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current (TJ = 150 °C)
Pulsed Drain Current
Avalanche Current
Avalanche Energy
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
TA = 70 °C
L = 0.1 mH
TC = 25 °C
Continuous Source-Drain Diode Current
TA = 25 °C
TC = 25 °C
TC = 70 °C
Maximum Power Dissipation
TA = 25 °C
TA = 70 °C
Operating Junction and Storage Temperature Range
Limit
40
± 20
12
8
12.4a, b
8.8a, b
50
15
11
5
2.1a, b
6
3.8
2.5a, b
1.6a, b
- 55 to 150
ID
IDM
IAS
EAS
IS
PD
TJ, Tstg
Unit
V
A
mJ
A
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta, c
Maximum Junction-to-Foot (Drain)
t ≤ 10 s
Steady State
Symbol
RthJA
RthJF
Typical
37
17
Maximum
50
21
Unit
°C/W
Notes:
a. Surface Mounted on 1" x 1" FR4 board.
b. t = 10 s.
c. Maximum under Steady State conditions is 85 °C/W.
d. Based on TC = 25 °C.
1
FDS8447
www.VBsemi.tw
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
40
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
ΔVDS/TJ
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
Gate-Source Threshold Voltage
V
40
ID = 250 µA
mV/°C
-6
VGS(th)
VDS = VGS , ID = 250 µA
3
V
Gate-Source Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
nA
Zero Gate Voltage Drain Current
IDSS
VDS = 40 V, VGS = 0 V
1
VDS = 40 V, VGS = 0 V, TJ = 55 °C
5
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
VDS ≥ 5 V, VGS = 10 V
1
µA
A
50
VGS = 10 V, ID = 12.4 A
0.010
VGS = 4.5 V, ID = 10.8 A
0.012
VDS = 15 V, ID = 12.4 A
56
Ω
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Rg
2000
VDS = 20 V, VGS = 0 V, f = 1 MHz
td(off)
pF
150
VDS = 10 V, VGS = 10 V, ID = 12.4 A
VDS = 10 V, VGS = 4.5 V, ID = 12.4 A
33
50
15
23
6.7
f = 1 MHz
VDD = 20 V, RL = 2 Ω
ID ≅ 10 A, VGEN = 4.5 V, Rg = 1 Ω
1.4
2.1
25
40
12
40
tf
10
15
td(on)
10
15
15
25
30
45
10
15
tr
td(off)
nC
5.1
td(on)
tr
260
ID ≅ 10 A, VGEN = 10 V, Rg = 1 Ω
tf
Ω
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
Body Diode Reverse Recovery Time
trr
Body Diode Reverse Recovery Charge
Qrr
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
TC = 25 °C
30
50
IS = 10 A, VGS = 0 V
IF = 10 A, dI/dt = 100 A/µs, TJ = 25 °C
A
0.8
1.2
V
30
60
ns
26
52
nC
17.5
12.5
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
2
FDS8447
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
50
10
VGS = 10 V thru 5 V
8
ID - Drain Current (A)
40
30
4V
10
6
TC = 25 °C
4
TC = 125 °C
2
3V
0.8
1.2
1.6
2.0
TC = - 55 °C
0.5
1.0
1.5
2.5
Output Characteristics
3.5
35
40
125
150
Transfer Characteristics
2400
0.024
Ciss
2000
0.019
C - Capacitance (pF)
VGS = 4.5 V
0.014
VGS = 10 V
1600
1200
800
0.009
Coss
400
0.004
Crss
40
50
10
15
30
VDS - Drain-to-Source Voltage (V)
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
10
1.8
VDS = 20 V
ID = 12.4 A
8
1.6
R DS(on) - On-Resistance
(Normalized)
VGS - Gate-to-Source Voltage (V)
3.0
RDS(on) - On-Resistance (Ω)
2.0
6
4
2
VGS = 10 V
ID = 12.4 A
1.4
1.2
1.0
0.8
10
15
Qg - Total Gate Charge (nC)
Gate Charge
30
35
0.6
- 50
- 25
50
75
100
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
FDS8447
www.VBsemi.tw
60
0.030
ID = 12.4 A
I S - Source Current (A)
0.025
TJ = 150 °C
10
TJ = 25 °C
1
0.0
0.020
125 °C
0.015
0.010
25 °C
0.005
0.000
0.2
0.4
0.6
0.8
1.0
2
4
6
8
10
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
2.4
50
ID = 250 µA
2.2
40
30
Power (W)
1.8
1.6
10
1.2
1.0
- 50
- 25
50
75
100
125
150
0.01
0.1
1
10
100
TJ - Temperature (°C)
Time (s)
Threshold Voltage
Single Pulse Power (Junction-to-Ambient)
100
600
Limited by RDS(on)*
100 µs
10
I D - Drain Current (A)
V GS(th) (V)
2.0
1 ms
1
10 ms
100 ms
1s
10 s
0.1
BVDSS
Limited
TA = 25 °C
Single Pulse
0.01
0.1
1
DC
10
100
* VGS > minimum VGS at which R DS(on) is specified
Safe Operating Area, Junction-to-Ambient
4
FDS8447
www.VBsemi.tw
6
25
5
Power Dissipation (W)
10
5
4
3
2
1
50
75
100
TC - Case Temperature (°C)
Current Derating*
125
150
25
50
75
100
125
150
Power Derating
* The power dissipation PD is based on TJ(max) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
5
FDS8447
www.VBsemi.tw
Normalized Effective Transient
Thermal Impedance
2
1
Duty Cycle = 0.5
0.2
Notes:
0.1
0.1
PDM
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 68 °C/W
0.02
3. T JM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10 -4
10 -3
10 -2
10 -1
1
Square Wave Pulse Duration (s)
10
100
600
Normalized Thermal Transient Impedance, Junction-to-Ambient
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10-4
10-3
10-2
10-1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
6
FDS8447
www.VBsemi.tw
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
e
B
All Leads
q
A1
L
0.004"
MILLIMETERS
DIM
Min
INCHES
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
0.101 mm
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
7
FDS8447
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
Recommended Minimum Pads
Dimensions in Inches/(mm)
8
FDS8447
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
9
