Additional Resources:
Product Page
3D Model
PCB Footprint
date
12/11/2019
page
1 of 4
MODEL: CPI-4233-92T │ DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• fast pulse option
• continuous tone option
• through hole
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
6
at rated voltage
continuous tone
fast pulse tone
rated frequency
2,300
sound pressure level
at 30 cm, rated voltage
continuous tone
fast pulse tone
tone
continuous
fast pulse at rated voltage (3.0 ±20% Hz)
dimensions
Ø42.5 x 33.0
2,800
material
ABS (UL94 1/16” HB)
terminal
pins (tin plating)
storage temperature
no
RoHS
yes
Vdc
Vdc
13
11
mA
mA
3,300
Hz
dB
dB
mm
operating temperature
washable
units
28
92
87
weight
Notes:
max
12
operating voltage
current consumption
typ
35
g
-30
85
°C
-40
95
°C
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
maximum 3 seconds
330
350
370
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: CPI-4233-92T │ DESCRIPTION: PIEZO BUZZER INDICATOR
date 12/11/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
(CONST) (PULSE)
PIEZO AUDIO INDICATOR
12.5
WEEK
YEAR
81&
Recommended PCB Layout
Top View
PERFORMANCE CURVES
Voltage vs. Current Consumption
Sound Pressure Level (dB)
Current Consumption (mA)
Voltage vs. Sound Pressure Level
at 30 cm
Voltage (Vdc)
Voltage (Vdc)
cuidevices.com
Product Page
3D Model
PACKAGING
units: mm
Carton Size: 550 x 330 x 290 mm
Carton QTY: 400 pcs per carton
cuidevices.com
PCB Footprint
date 12/11/2019 │ page 3 of 4
Product Page
3D Model
PCB Footprint
date 12/11/2019 │ page 4 of 4
REVISION HISTORY
rev.
1.0
description
date
initial release
12/11/2019
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPI-4233-92T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 8+56.38035
- 80+54.10724
- 200+51.91877
- 国内价格
- 8+71.85329
- 80+68.51944
- 200+65.53652
