Additional Resources:
Product Page
3D Model
date
12/12/2019
page
1 of 4
MODEL: CPI-4232-72SST │ DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• internal drive
• slow pulse tone
• screw terminals
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
8
at 8 Vdc
at 12 Vdc
at 28 Vdc
rated frequency
2,300
sound pressure level
at 60 cm, 8 Vdc
at 60 cm, 12 Vdc
at 60 cm, 28 Vdc
tone
slow pulse at rated voltage (1.2 ±20% Hz)
dimensions
Ø42.5 x 32.0
2,800
units
Vdc
28
Vdc
3
6
30
mA
mA
mA
3,300
Hz
68
72
80
dB
dB
dB
mm
weight
material
NYLON (UL94V-0)
terminal
screw terminals (tin plating)
37.9
g
operating temperature
-30
85
°C
storage temperature
-40
85
°C
max
units
380
°C
washable
no
RoHS
yes
Notes:
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
maximum 2 seconds
330
cuidevices.com
typ
Product Page
CUI Devices │ MODEL: CPI-4232-72SST │ DESCRIPTION: PIEZO BUZZER INDICATOR
3D Model
date 12/12/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
PERFORMANCE CURVES
Voltage vs. Sound Pressure Level
at 60 cm
Voltage vs. Current Consumption
cuidevices.com
Product Page
PACKAGING
units: mm
Carton Size: 550 x 330 x 290 mm
Carton QTY: 400 pcs per carton
cuidevices.com
3D Model
date 12/12/2019 │ page 3 of 4
Product Page
3D Model
date 12/12/2019 │ page 4 of 4
REVISION HISTORY
rev.
1.0
description
date
initial release
12/12/2019
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPI-4232-72SST”相匹配的价格&库存,您可以联系我们找货
