PBSS4160PANPS
60 V, 1 A NPN/NPN low VCEsat (BISS) transistor
11 February 2015
Product data sheet
1. General description
NPN/PNP low VCEsat Breakthrough In Small Signal (BISS) transistor in a leadless
medium power DFN2020D-6 (SOT1118D) Surface-Mounted Device (SMD) plastic
package with visible and solderable side pads.
NPN/NPN complement: PBSS4160PANS. PNP/PNP complement: PBSS5160PAPS.
2. Features and benefits
Very low collector-emitter saturation voltage VCEsat
High collector current capability IC and ICM
High collector current gain hFE at high IC
Reduced Printed-Circuit Board (PCB) requirements
Exposed heat sink for excellent thermal and electrical conductivity
High energy efficiency due to less heat generation
Suitable for Automatic Optical Inspection (AOI) of solder joints
AEC-Q101 qualified
3. Applications
Load switch
Battery-driven devices
Power management
Charging circuits
LED lighting
Power switches (e.g. motors, fans)
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
60
V
1
A
1.5
A
Per transistor; for the PNP transistor with negative polarity
VCEO
collector-emitter
voltage
IC
collector current
ICM
peak collector current
open base
single pulse; tp ≤ 1 ms
PBSS4160PANPS
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
collector-emitter
saturation resistance
IC = 0.5 A; IB = 50 mA; pulsed;
240
mΩ
360
mΩ
TR1 (NPN)
RCEsat
tp ≤ 300 µs; δ ≤ 0.02; Tamb = 25 °C
TR2 (PNP)
RCEsat
collector-emitter
IC = -0.5 A; IB = -50 mA; pulsed;
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
E1
emitter TR1
2
B1
base TR1
3
C2
collector TR2
4
E2
emitter TR2
5
B2
base TR2
6
C1
collector TR1
7
C1
collector TR1
8
C2
collector TR2
Simplified outline
6
Graphic symbol
5
7
1
4
8
2
C1
B2
TR2
TR1
3
Transparent top view
E2
E1
B1
C2
sym139
6. Ordering information
Table 3.
Type number
PBSS4160PANPS
Package
Name
Description
Version
DFN2020D-6
DFN2020D-6: plastic, thermally enhanced ultra thin and small
outline package; no leads; 6 terminals; body 2 x 2 x 0.65 mm
SOT1118D
7. Marking
Table 4.
Marking codes
Type number
Marking code
PBSS4160PANPS
3G
PBSS4160PANPS
Product data sheet
All information provided in this document is subject to legal disclaimers.
11 February 2015
Nexperia B.V. 2017. All rights reserved
2 / 23
PBSS4160PANPS
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VCBO
collector-base voltage
open emitter
60
V
VCEO
collector-emitter voltage
open base
60
V
VEBO
emitter-base voltage
open collector
7
V
IC
collector current
1
A
ICM
1.5
A
IB
base current
0.3
A
IBM
peak base current
1
A
Ptot
total power dissipation
Tamb ≤ 25 °C
[1]
370
mW
[2]
570
mW
[3]
530
mW
[4]
700
mW
[5]
450
mW
[6]
760
mW
[7]
700
mW
[8]
1450
mW
[1]
510
mW
[2]
780
mW
[3]
730
mW
[4]
960
mW
[5]
620
mW
[6]
1040
mW
[7]
960
mW
[8]
2000
mW
Per device
Ptot
Tamb ≤ 25 °C
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
[1]
[2]
[3]
[4]
[5]
PBSS4160PANPS
Product data sheet
Device mounted on an FR4 PCB, single-sided 35 µm copper strip line, tin-plated and standard footprint.
Device mounted on an FR4 PCB, single-sided 35 µm copper strip line, tin-plated, mounting pad for
2
collector 1 cm .
Device mounted on 4-layer PCB 35 µm copper strip line, tin-plated and standard footprint.
2
Device mounted on 4-layer PCB 35 µm copper strip line, tin-plated, mounting pad for collector 1 cm .
Device mounted on an FR4 PCB, single-sided 70 µm copper strip line, tin-plated and standard footprint.
11 February 2015
3 / 23
PBSS4160PANPS
Nexperia
[6]
[7]
[8]
Device mounted on an FR4 PCB, single-sided 70 µm copper strip line, tin-plated, mounting pad for
2
collector 1 cm .
Device mounted on 4-layer PCB 70 µm copper strip line, tin-plated and standard footprint.
2
Device mounted on 4-layer PCB 70 µm copper strip line, tin-plated, mounting pad for collector 1 cm .
1.5
006aad165
(1)
Ptot
(W)
1.0
(2)
(3) (4)
(5)
0.5 (6)
(7)
(8)
-25
25
75
(1) 4-layer PCB 70 µm, mounting pad for collector 1 cm
(2) FR4 PCB 70 µm, mounting pad for collector 1 cm
(3) 4-layer PCB 70 µm, standard footprint
125
175
Tamb (°C)
2
2
2
(4) 4-layer PCB 35 µm, mounting pad for collector 1 cm
(5) FR4 PCB 35 µm, mounting pad for collector 1 cm
(6) 4-layer PCB 35 µm, standard footprint
(7) FR4 PCB 70 µm, standard footprint
(8) FR4 PCB 35 µm, standard footprint
Fig. 1.
2
Per transistor: power derating curves
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
thermal resistance
from junction to
ambient
in free air
Min
Typ
Max
Unit
[1]
338
K/W
[2]
219
K/W
[3]
236
K/W
[4]
179
K/W
[5]
278
K/W
[6]
164
K/W
[7]
179
K/W
[8]
86
K/W
Per transistor
Rth(j-a)
PBSS4160PANPS
Product data sheet
11 February 2015
4 / 23
PBSS4160PANPS
Nexperia
Symbol
Parameter
Conditions
Rth(j-sp)
thermal resistance
from junction to solder
point
Min
Typ
Max
Unit
30
K/W
[1]
245
K/W
[2]
160
K/W
[3]
171
K/W
[4]
130
K/W
[5]
202
K/W
[6]
120
K/W
[7]
130
K/W
[8]
63
K/W
Per device
Rth(j-a)
thermal resistance
from junction to
ambient
[1]
[2]
[3]
[4]
[5]
[6]
[7]
[8]
in free air
2
collector 1 cm .
2
collector 1 cm .
2
006aad166
103
Zth(j-a)
(K/W)
2
duty cycle = 1
0.75
102
0.33
0.5
0.2
0.1
0.05
10
0.02
0.01
10-5
10-4
10-3
10-2
10-1
1
10
102
tp (s)
103
Fig. 2.
Per transistor: transient thermal impedance from junction to ambient as a function of pulse duration;
typical values
PBSS4160PANPS
Product data sheet
11 February 2015
5 / 23
PBSS4160PANPS
Nexperia
006aad167
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.33
0.5
0.2
0.1
0.05
10
0.02
1
10-5
0.01
10-3
10-2
10-1
Fig. 3.
1
10
102
tp (s)
103
2
typical values
006aad168
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.33
0.5
0.2
0.1
0.05
10
0.02
1
10-5
0.01
10-3
10-2
10-1
1
10
102
tp (s)
103
Fig. 4.
typical values
PBSS4160PANPS
Product data sheet
11 February 2015
6 / 23
PBSS4160PANPS
Nexperia
006aad169
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.33
0.5
0.2
0.1
0.05
10
0.02
0.01
1
10-5
10-3
10-2
10-1
Fig. 5.
1
10
102
tp (s)
103
2
typical values
006aac610
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.33
0.5
0.2
0.1
0.05
10
0.02
10- 5
0.01
10- 4
10- 3
10- 2
10- 1
1
10
102
tp (s)
103
Fig. 6.
typical values
PBSS4160PANPS
Product data sheet
11 February 2015
7 / 23
PBSS4160PANPS
Nexperia
006aac611
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
10
0.1
0.05
0.02
5
10
0.01
10- 4
10- 3
10- 2
10- 1
Fig. 7.
1
10
102
tp (s)
103
2
typical values
006aad170
103
Zth(j-a)
(K/W)
duty cycle = 1
102
0.75
0.5
0.33
0.2
0.1
0.05
10
0.02
0.01
1
10-5
10-3
10-2
10-1
1
10
102
tp (s)
103
Fig. 8.
typical values
PBSS4160PANPS
Product data sheet
11 February 2015
8 / 23
PBSS4160PANPS
Nexperia
102
006aad171
duty cycle = 1
0.75
0.5
Zth(j-a)
(K/W)
0.33
0.2
10
0.1
0.05
0.02
0.01
10-5
10-4
10-3
10-2
10-1
Fig. 9.
1
10
102
tp (s)
103
2
typical values
PBSS4160PANPS
Product data sheet
11 February 2015
9 / 23
PBSS4160PANPS
Nexperia
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
collector-base cut-off
current
VCB = 48 V; IE = 0 A; Tamb = 25 °C
100
nA
VCB = 48 V; IE = 0 A; Tj = 150 °C
50
µA
IEBO
emitter-base cut-off
current
VEB = 5 V; IC = 0 A; Tamb = 25 °C
100
nA
hFE
DC current gain
VCE = 2 V; IC = 100 mA; pulsed;
290
430
150
220
70
110
IC = 500 mA; IB = 50 mA; Tamb = 25 °C
90
120
mV
IC = 1 A; IB = 50 mA; pulsed;
185
240
mV
175
220
mV
240
mΩ
1
V
1.1
V
1.1
V
0.9
V
TR1 (NPN)
ICBO
VCE = 2 V; IC = 500 mA; pulsed;
VCE = 2 V; IC = 1 A; pulsed; tp ≤ 300 µs;
VCEsat
collector-emitter
saturation voltage
IC = 1 A; IB = 100 mA; pulsed;
RCEsat
VBEsat
collector-emitter
base-emitter saturation IC = 500 mA; IB = 50 mA; Tamb = 25 °C
voltage
VBEon
base-emitter turn-on
voltage
VCE = 2 V; IC = 0.5 A; pulsed;
td
delay time
VCC = 10 V; IC = 0.5 A; IBon = 25 mA;
15
ns
tr
rise time
IBoff = -25 mA; Tamb = 25 °C
90
ns
ton
turn-on time
105
ns
ts
storage time
410
ns
tf
fall time
130
ns
toff
turn-off time
540
ns
fT
transition frequency
90
175
MHz
4
6
pF
VCE = 10 V; IC = 50 mA; f = 100 MHz;
Tamb = 25 °C
Cc
collector capacitance
VCB = 10 V; IE = 0 A; ie = 0 A;
f = 1 MHz; Tamb = 25 °C
PBSS4160PANPS
Product data sheet
11 February 2015
10 / 23
PBSS4160PANPS
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
current
VCB = -48 V; IE = 0 A
-100
nA
VCB = -48 V; IE = 0 A; Tj = 150 °C
-50
µA
IEBO
current
VEB = -5 V; IC = 0 A
-100
nA
hFE
DC current gain
VCE = -2 V; IC = -100 mA; pulsed;
170
245
120
170
70
100
-125
-180
mV
-390
-550
mV
-240
-340
mV
360
mΩ
-1
V
-1
V
-1.1
V
-0.9
V
TR2 (PNP)
ICBO
VCE = -2 V; IC = -500 mA; pulsed;
VCE = -2 V; IC = -1 A; pulsed;
VCEsat
collector-emitter
saturation voltage
IC = -500 mA; IB = -50 mA; pulsed;
IC = -1 A; IB = -50 mA; pulsed;
IC = -1 A; IB = -100 mA; pulsed;
RCEsat
VBEsat
collector-emitter
base-emitter saturation IC = -500 mA; IB = -50 mA; pulsed;
voltage
VBEon
td
voltage
VCE = -2 V; IC = -0.5 A; pulsed;
delay time
VCC = -10 V; IC = -0.5 A; IBon = -25 mA;
15
ns
tr
rise time
IBoff = 25 mA; Tamb = 25 °C
40
ns
ton
turn-on time
55
ns
ts
storage time
95
ns
tf
fall time
40
ns
toff
turn-off time
135
ns
fT
65
125
MHz
9.5
13
pF
VCE = -10 V; IC = -50 mA; f = 100 MHz;
Tamb = 25 °C
Cc
VCB = -10 V; IE = 0 A; ie = 0 A;
PBSS4160PANPS
Product data sheet
11 February 2015
11 / 23
PBSS4160PANPS
Nexperia
006aad204
800
006aad205
1.50
IB = 15 mA
IC
(A)
hFE
(1)
13.5
12
10.5
1.00
600
(2)
9
7.5
6
0.75
4.5
400
3
0.50
(3)
1.5
200
0.25
1
10
102
104
IC (mA)
VCE = 2 V
2
3
4
VCE (V)
5
Tamb = 25 °C
(1) Tamb = 100 °C
Fig. 11. TR1 (NPN): Collector current as a function of
collector-emitter voltage; typical values
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 10. TR1 (NPN): DC current gain as a function of
collector current; typical values
006aad206
1.2
006aad207
1.2
VBEsat
(V)
VBE
(V)
1.0
(1)
0.8
(1)
0.8
(2)
(2)
(3)
0.6
(3)
0.4
0.4
1
10
102
0.2
10-1
103
104
IC (mA)
1
10
VCE = 2 V
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb= 100 °C
Fig. 12. TR1 (NPN): Base-emitter voltage as a function
of collector current; typical values
PBSS4160PANPS
Product data sheet
102
103
104
IC (mA)
Fig. 13. TR1 (NPN): Base-emitter saturation voltage as a
function of collector current; typical values
11 February 2015
12 / 23
PBSS4160PANPS
Nexperia
006aad208
1
006aad209
10
VCEsat
(V)
VCEsat
(V)
10-1
1
(1)
(2)
10-1
(1)
(3)
10-2
(2)
10-2
(3)
10-3
10-1
1
102
10
10-3
10-1
103
104
IC (mA)
1
IC/IB = 20
Tamb = 25 °C
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
10
102
103
104
IC (mA)
Fig. 14. TR1 (NPN): Collector-emitter saturation voltage Fig. 15. TR1 (NPN): Collector-emitter saturation voltage
as a function of collector current; typical values
006aad210
103
RCEsat
(Ω)
RCEsat
(Ω)
102
102
10
10
(1)
1
006aad211
103
(2)
(1)
(2)
1
10-1
10-1
(3)
(3)
10-2
10-1
1
10
102
10-2
10-1
103
104
IC (mA)
IC/IB = 20
1
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
Fig. 16. TR1 (NPN): Collector-emitter saturation
resistance as a function of collector current;
typical values
Product data sheet
102
103
104
IC (mA)
Tamb = 25 °C
(1) Tamb = 100 °C
PBSS4160PANPS
10
Fig. 17. TR1 (NPN): Collector-emitter saturation
typical values
11 February 2015
13 / 23
PBSS4160PANPS
Nexperia
006aad212
500
-1.50
hFE
IC
(A)
400
006aad213
IB = -20 mA
-18
-16
-14
-1.00
(1)
-12
-10
300
-8
-0.75
-6
(2)
200
(3)
100
-4
-0.50
-1
-2
-0.25
-10
-102
-104
IC (mA)
VCE = −2 V
-2
-3
-4
VCE (V)
-5
Tamb = 25 °C
(1) Tamb = 100 °C
Fig. 19. TR2 (PNP): Collector current as a function of
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig. 18. TR2 (PNP): DC current gain as a function of
006aad214
-1.2
006aad215
-1.2
VBEsat
(V)
VBE
(V)
-1.0
-0.8
(1)
(1)
-0.8
(2)
(2)
-0.6
(3)
(3)
-0.4
-0.4
-1
-10
-102
-0.2
-10-1
-103
-104
IC (mA)
-1
-10
VCE = −2 V
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = −55 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = 100 °C
Fig. 20. TR2 (PNP): Base-emitter voltage as a function
PBSS4160PANPS
Product data sheet
-102
-103
-104
IC (mA)
Fig. 21. TR2 (PNP): Base-emitter saturation voltage as a
11 February 2015
14 / 23
PBSS4160PANPS
Nexperia
006aad216
-10
006aad217
-10
VCEsat
(V)
VCEsat
(V)
-1
-1
(1)
(2)
-10-1
-10-1
(1)
(2)
(3)
-10-2
-10-3
-10-1
-1
-10
-102
(3)
-10-2
-10-3
-10-1
-103
-104
IC (mA)
-1
IC/IB = 20
Tamb = 25 °C
(1) Tamb = 100 °C
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB = 10
-10
-102
-103
-104
IC (mA)
Fig. 22. TR2 (PNP): Collector-emitter saturation voltage Fig. 23. TR2 (PNP): Collector-emitter saturation voltage
006aad218
103
006aad219
103
RCEsat
(Ω)
RCEsat
(Ω)
102
102
(1)
10
10
(1)
1
(2)
1
10-1
-10-1
(2)
10-1
(3)
-1
-10
-102
10-2
-10-1
-103
-104
IC (mA)
IC/IB = 20
(3)
-1
(1) IC/IB = 100
(2) Tamb = 25 °C
(2) IC/IB = 50
(3) Tamb = −55 °C
(3) IC/IB= 10
Fig. 24. TR2 (PNP): Collector-emitter saturation
typical values
Product data sheet
-102
-103
-104
IC (mA)
Tamb = 25 °C
(1) Tamb = 100 °C
PBSS4160PANPS
-10
Fig. 25. TR2 (PNP): Collector-emitter saturation
typical values
11 February 2015
15 / 23
PBSS4160PANPS
Nexperia
11. Test information
IB
input pulse
(idealized waveform)
90 %
IBon (100 %)
10 %
IBoff
output pulse
IC
90 %
IC (100 %)
10 %
t
td
ts
tr
ton
tf
toff
006aaa003
Fig. 26. TR1 (NPN): BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mlb826
Fig. 27. TR1 (NPN): Test circuit for switching times
PBSS4160PANPS
Product data sheet
11 February 2015
16 / 23
PBSS4160PANPS
Nexperia
- IB
input pulse
90 %
- I Bon (100 %)
10 %
- I Boff
output pulse
- IC
90 %
- I C (100 %)
10 %
t
td
ts
tr
t on
tf
t off
006aaa266
Fig. 28. TR2 (PNP): BISS transistor switching time definition
VBB
RB
VCC
RC
Vo
(probe)
oscilloscope
450 Ω
(probe)
450 Ω
R2
VI
oscilloscope
DUT
R1
mgd624
Fig. 29. TR2 (PNP): Test circuit for switching times
11.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PBSS4160PANPS
Product data sheet
11 February 2015
17 / 23
PBSS4160PANPS
Nexperia
12. Package outline
DFN2020D-6: plastic, thermally enhanced ultra thin and small outline package; no leads;
bp
(6x)
v
SOT1118D
A B
D
A
B
A
E
A1
pin 1
index area
detail X
solderable lead end
protrusion maximum 0.035 mm (6x)
D1
(2x)
pin 1
index area
1
C
e1
e1
y1 C
3
Lp
(6x)
cut-off end of
non-fuctional
bonding wire
(8x)
E1
(2x)
6
e
4
e
X
mm
A
A1
bp
max 0.65 0.04 0.35
nom 0.62
0.30
min 0.59
0.25
2 mm
scale
Dimensions (mm are the original dimensions)
Unit
y
D
D1
E
E1
2.1
2.0
1.9
0.77
0.67
0.57
2.1
2.0
1.9
1.0
0.9
0.8
e
e1
Lp
0.54 0.30
0.65 0.49 0.25
0.44 0.20
v
0.1
y
y1
0.05 0.05
Note
1. Dimension A is including plating thickness.
Outline
version
SOT1118D
sot1118d_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
14-07-16
14-10-16
Fig. 30. Package outline DFN2020D-6 (SOT1118D)
PBSS4160PANPS
Product data sheet
11 February 2015
18 / 23
PBSS4160PANPS
Nexperia
13. Soldering
SOT1118D
2.2
1.65
0.2
0.3
0.45
0.35
0.25
0.65
0.53 0.43 0.33
solder lands
0.12 0.22
2.5 2.3
0.9
1
solder paste
1.1
solder resist
0.935
occupied area
0.49
0.31
0.21
Dimensions in mm
0.57
0.67
0.77
1.65
sot1118d_fr
Fig. 31. Reflow soldering footprint for DFN2020D-6 (SOT1118D)
PBSS4160PANPS
Product data sheet
11 February 2015
19 / 23
PBSS4160PANPS
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PBSS4160PANPS v.1
20150211
Product data sheet
PBSS4160PANPS
Product data sheet
11 February 2015
20 / 23
PBSS4160PANPS
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PBSS4160PANPS
Product data sheet
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
11 February 2015
21 / 23
PBSS4160PANPS
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PBSS4160PANPS
Product data sheet
11 February 2015
22 / 23
PBSS4160PANPS
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Thermal characteristics .........................................4
10
Characteristics ..................................................... 10
11
11.1
Test information ................................................... 16
Quality information ............................................. 17
12
Package outline ................................................... 18
13
Soldering .............................................................. 19
14
Revision history ................................................... 20
15
15.1
15.2
15.3
15.4
Legal information .................................................21
Data sheet status ............................................... 21
Definitions ...........................................................21
Disclaimers .........................................................21
Trademarks ........................................................ 22
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 11 February 2015
PBSS4160PANPS
Product data sheet
11 February 2015
23 / 23
