Additional Resources:
Product Page
3D Model
PCB Footprint
date
11/13/2019
page
1 of 4
MODEL: CMI-1295IC-0585T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
5 Vdc rated
85 dB
through hole
magnetic
internally driven
narrow frequency range
used in medical & security applications
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
5
operating voltage
4
current consumption
at rated voltage
rated frequency
at rated voltage
sound pressure level
at 10 cm, rated voltage
tone
single
dimensions
Ø12 x 9.5
2,300
2,400
Vdc
Vdc
30
mA
2,500
Hz
dB
mm
1.8
material
PBT
terminal
pins (red coppper with tin plating)
operating temperature
storage temperature
washable
yes
RoHS
yes
units
7
85
weight
Notes:
typ
g
-30
70
°C
-40
85
°C
max
units
250
°C
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: CMI-1295IC-0585T │ DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 11/13/2019 │ page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
0$6.,1*/$%(/
(32;
很抱歉,暂时无法提供与“CMI-1295IC-0585T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.77330
- 10+6.79843
- 25+6.44136
- 50+6.15710
- 100+6.12640
