Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMI-9605IC-0380T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• 3 Vdc rated
• 80 dB
• through hole
• magnetic
• internally driven
• narrow frequency range
• used in medical & security applications
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
3
operating voltage
2
current consumption
at rated voltage
rated frequency
at rated voltage
sound pressure level
at 10 cm, rated voltage
tone
single
dimensions
Ø9.6 x 5.0
2,600
2,700
Vdc
Vdc
30
mA
2,800
Hz
dB
mm
0.8
material
PBT
terminal
pins (brass with tin plating)
operating temperature
storage temperature
washable
units
5
80
weight
g
-30
70
°C
-40
85
°C
max
units
250
°C
yes
RoHS
Notes:
typ
yes
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMI-9605IC-0380T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
(32;
很抱歉,暂时无法提供与“CMI-9605IC-0380T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 150+6.77525
- 300+6.53469
