Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMI-9605IC-0580T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• 5 Vdc rated
• 80 dB
• through hole
• magnetic
• internally driven
• narrow frequency range
• used in medical & security applications
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
5
operating voltage
3
current consumption
at rated voltage
rated frequency
at rated voltage
sound pressure level
at 10 cm, rated voltage
tone
single
dimensions
Ø9.6 x 5.0
2,600
2,700
Vdc
Vdc
30
mA
2,800
Hz
dB
mm
0.8
material
PBT
terminal
pins (brass with tin plating)
operating temperature
storage temperature
washable
units
7
80
weight
g
-30
70
°C
-40
85
°C
max
units
250
°C
yes
RoHS
Notes:
typ
yes
1. All specifications measured at 25±3°C, humidity at 60~70%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
5±1 s
0.5~1.5°/s
>6°/s
Temperature (°C)
250
200
150
100
50
60
90
120 150 180 210 240 270
Time (sec)
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMI-9605IC-0580T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
0DVNLQJ/DEHO
3DGV
+ROH
Recommended PCB Layout
Top View
PERFORMANCE CURVES
SPL: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
90
85
30
SPL
80
25
75
I
15
70
65
3
4
5
6
Supply Voltage(Vdc)
cuidevices.com
7
10
Current Consumption(mA)
Sound Pressure Level(dB)
at 10 cm
Product Page
3D Model
PCB Footprint
PACKAGING
units: mm
Carton Size: 505 x 420 x 280 mm
Carton QTY: 7,500 pcs per carton
DGKHVLYHWDSH
DGKHVLYHWDSH
cuidevices.com
date 08/05/2022 | page 3 of 4
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
11/12/2019
1.01
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMI-9605IC-0580T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+9.87127
- 10+8.44494
- 25+7.89824
- 50+7.49435
- 100+6.87931
