BAS116H
Low leakage switching diode
Rev. 3 — 31 May 2011
Product data sheet
1. Product profile
1.1 General description
Low leakage switching diode, encapsulated in a SOD123F small and flat lead
Surface-Mounted Device (SMD) plastic package.
1.2 Features and benefits
Small and flat lead SMD plastic package
Low leakage current
Excellent coplanarity and improved thermal behavior
AEC-Q101 qualified
1.3 Applications
General-purpose switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
IF
forward current
IR
reverse current
VR
reverse voltage
trr
reverse recovery time
Conditions
[1][2]
VR = 75 V
[3]
Min
Typ
Max
Unit
215
mA
0.003
5.0
nA
75
V
0.8
3.0
s
[1]
Pulse test: tp 300 s; 0.02.
[2]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[3]
When switched from IF = 10 mA to IR = 10 mA; RL = 100 ; measured at IR = 1 mA.
2. Pinning information
Table 2.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Graphic symbol
[1]
1
1
2
2
sym001
[1]
The marking bar indicates the cathode.
BAS116H
Nexperia
3. Ordering information
Table 3.
Type number
BAS116H
Package
Name
Description
Version
plastic surface-mounted package; 2 leads
SOD123F
4. Marking
Table 4.
Marking codes
Type number
Marking code
BAS116H
B1
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
VRRM
repetitive peak reverse
voltage
VR
reverse voltage
IF
forward current
IFRM
repetitive peak forward
current
IFSM
non-repetitive peak forward
current
total power dissipation
Ptot
Min
Max
Unit
85
V
75
V
215
mA
500
mA
tp = 1 s
4
A
tp = 1 ms
1
A
tp = 1 s
0.5
A
375
mW
[1][2]
square wave
Tamb 25 C
[3]
[1][4]
[5]
BAS116H
Product data sheet
Tj
junction temperature
150
C
Tamb
ambient temperature
65
+150
C
Tstg
storage temperature
65
+150
C
[1]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[2]
[3]
Tj = 25 C prior to surge.
[4]
Reflow soldering is the only recommended soldering method.
[5]
Soldering point of cathode tab.
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 10
BAS116H
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
Rth(j-sp)
junction to solder point
in free air
Min
Typ
Max
Unit
[1][2]
330
K/W
[3]
70
K/W
[1]
[2]
[3]
7. Characteristics
Table 7.
Characteristics
Tamb = 25 C unless otherwise specified.
Symbol
Parameter
VF
forward voltage
IR
BAS116H
Product data sheet
Conditions
reverse current
Cd
diode capacitance
trr
Min
Typ
Max
Unit
IF = 1 mA
0.90
V
IF = 10 mA
1.00
V
IF = 50 mA
1.10
V
IF = 150 mA
1.25
V
VR = 75 V
0.003
5.0
nA
VR = 75 V; Tj = 150 C
3
80.0
nA
2
pF
0.8
3.0
s
[1]
VR = 0 V; f = 1 MHz
[2]
[1]
[2]
3 of 10
BAS116H
Nexperia
mlb752
300
mbg704
102
IF
(mA)
IFSM
(A)
10
200
(1)
(2)
(3)
1
100
10−1
0.8
1.2
VF (V)
1.6
1
10
102
103
104
tp (μs)
(1) Tamb = 150 C; typical values
Based on square wave currents
(2) Tamb = 25 C; typical values
Tj = 25 C; prior to surge
(3) Tamb = 25 C; maximum values
Fig 1.
Forward current as a function of forward
voltage
Fig 2.
mlb754
102
Non-repetitive peak forward current as a
function of pulse duration; maximum values
mbg526
2
IR
(nA)
(1)
10
Cd
(pF)
1
1
10−1
(2)
10−2
10−3
100
150
Tj (°C)
200
10
15
VR (V)
Tamb = 25 C; f = 1 MHz
VR = 75 V
(1) Maximum values
(2) Typical values
Fig 3.
Reverse current as a function of junction
temperature
BAS116H
Product data sheet
Fig 4.
Diode capacitance as a function of reverse
voltage; typical values
4 of 10
BAS116H
Nexperia
8. Test information
tr
tp
t
D.U.T.
10 %
+ IF
IF
RS = 50 Ω
SAMPLING
OSCILLOSCOPE
trr
t
Ri = 50 Ω
V = VR + IF × RS
VR
(1)
90 %
mga881
input signal
output signal
(1) IR = 1 mA
Fig 5.
Reverse recovery time test circuit and waveforms
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
9. Package outline
1.7
1.5
1.2
1.0
1
0.55
0.35
3.6
3.4
2.7
2.5
2
0.70
0.55
0.25
0.10
Dimensions in mm
Fig 6.
04-11-29
Package outline SOD123F
10. Packing information
Table 8.
Packing methods
The -xxx numbers are the last three digits of the 12NC ordering code.[1]
Type number
BAS116H
[1]
BAS116H
Product data sheet
Package
SOD123F
Description
4 mm pitch, 8 mm tape and reel
Packing quantity
3000
10000
-115
-135
For further information and the availability of packing methods, see Section 14.
5 of 10
BAS116H
Nexperia
11. Soldering
Footprint information for reflow soldering of plastic surface-mounted, 2 leads package
SOD123F
4.4
2.9
2.8
1.1 1.2
(2×) (2×)
2.1 1.6
1.1
(2×)
1.2
(2×)
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sod123f_fr
Fig 7.
Reflow soldering footprint SOD123F
BAS116H
Product data sheet
6 of 10
BAS116H
Nexperia
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BAS116H v.3
20110531
Product data sheet
BAS116H v.2
Modifications:
Section 1 “Product profile”: updated.
Table 5 and 6: updated.
Table 7: VF values changed from mV to V.
Figure 2: updated.
Section 8.1 “Quality information”: added.
Figure 7: updated.
Section 13 “Legal information”: updated.
BAS116H v.2
20091214
Product data sheet
BAS116H v.1
BAS116H v.1
20050411
Product data sheet
BAS116H
Product data sheet
7 of 10
BAS116H
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
13.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
BAS116H
Product data sheet
8 of 10
BAS116H
Nexperia
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BAS116H
Product data sheet
9 of 10
Nexperia
BAS116H
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5
Quality information . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 5
Packing information . . . . . . . . . . . . . . . . . . . . . 5
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 7
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 8
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 8
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Contact information. . . . . . . . . . . . . . . . . . . . . . 9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Date of release: 31 May 2011
