ES1AL – ES1JL
Taiwan Semiconductor
1A, 50V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low profile Package
Low power loss, high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 600
V
IFSM
30
A
TJ MAX
150
°C
APPLICATIONS
Package
Sub SMA
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: Sub SMA
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019g (approximately)
Sub SMA
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
ES
1AL
ES
1BL
ES
1CL
ES
1DL
ES
1FL
ES
1GL
ES
1HL
ES
UNIT
1JL
EAL
EBL
ECL
EDL
EFL
EGL
EHL
EJL
Repetitive peak reverse voltage
VRRM
50
100
150
200
300
400
500
600
V
Reverse voltage, total rms value
VR(RMS)
35
70
105
140
210
280
350
420
V
Forward current
Peak forward surge current,
8.3ms single half sine-wave
superimposed on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: L2103
ES1AL – ES1JL
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
35
°C/W
Junction-to-ambient thermal resistance
RӨJA
85
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
ES1AL
ES1BL
ES1CL
ES1DL
ES1FL
ES1GL
ES1HL
ES1JL
(1)
Reverse current @ rated VR
TJ = 25°C
(2)
Junction capacitance
IF = 1A, TJ = 25°C
Reverse recovery time
1MHz, VR = 4.0V
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
TYP
MAX
UNIT
0.95
V
1.30
V
1.70
V
5
µA
100
µA
10
pF
8
pF
35
ns
VF
IR
TJ = 125°C
ES1AL
ES1BL
ES1CL
ES1DL
ES1FL
ES1GL
ES1HL
ES1JL
SYMBOL
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ES1xL
Sub SMA
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(ES1AL) to 600V(ES1JL)
2
Version: L2103
ES1AL – ES1JL
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
14
12
ES1AL-ES1DL
CAPACITANCE (pF)
1
10
8
ES1FL - ES1JL
6
4
2
50
75
100
125
f=1.0MHz
Vsig=50mVp-p
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
10
TJ=75°C
1
TJ=25°C
40
50
60
70
80
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10 10
ES1FL - ES1GL
ES1AL - ES1DL
UF1DLW
1
TJ=125°C
1
0.1
TJ=25°C
ES1HL - ES1JL
0.01
0.1
0.001
0.4 0.6 0.8 1.0
0.3
0.4
0.5
Pulse width 300μs
1% duty cycle
Pulse width
1.2 1.4 1.6 1.8 2.0
0.6
0.7
0.8
0.9
FORWARD VOLTAGE (V)
2.2
1
1.1
Fig.5 Maximum Non-Repetitive Forward Surge Current
40
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
1000
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
0.1
10
(A)
AVERAGE FORWARD CURRENT (A)
2
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: L2103
1.2
ES1AL – ES1JL
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: L2103
ES1AL – ES1JL
PACKAGE OUTLINE DIMENSIONS
Sub SMA
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2103
ES1AL – ES1JL
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2103
很抱歉,暂时无法提供与“ES1JL RQG”相匹配的价格&库存,您可以联系我们找货
