684M5W1103L461
684M5W1103L461
    NORCOMP
    弯插
    5(4 + 1 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 通孔,直角 焊接
684M5W1103L461 数据手册
DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED 5 GΩ MIN. 250V -55°C TO +125°C 1.0 mΩ MAX. 10 mΩ MAX. 1.213 [30.80] SEE P/N KEY 5 AMPS 0.984 [25.00] 0.665 [16.90] A1 1 4.5 Kg MAX. 0.3 Kg MIN. COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED 2 0.327 [8.30] 230°C PROCESS TEMP. 0.492 [12.50] 3 NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS 4 10° 0.240 [6.10] 0.031 [0.80] 684M5W1103LYYY 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 04/19/2013 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M5W1103L461 2 DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED RIGHT ANGLE BRACKET DIMENSIONS(in/mm) 0.984 OPTION #4-40 INSERT Ø0.043 4-PLACES 0.217 S P 0.146 0.185 46 Ø0.130 2-PLACES 3.70 4.70 0.087 0.087 2.22 2.22 62 Ø0.165 1-PLACE 0.470 0.520 0.420 [10.67] 0.163 SIGNAL CONTACTS POWER CONTACTS PCB EDGE 0.420 0.037 Ø 0.026 [Ø 0.65] S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 04/19/2013 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M5W1103L461 2
684M5W1103L461
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有快速响应时间和高输入输出隔离电压。
3. 引脚分配:EL817有6个引脚,包括发光二极管的阳极、阴极和光晶体管的集电极、发射极、基极和电源引脚。
4. 参数特性:包括最大正向电流、最大反向电压、最大功率耗散等。
5. 功能详解:EL817通过输入电流控制发光二极管发光,光晶体管根据接收到的光信号导通或截止。
6. 应用信息:广泛应用于数字通信、测量设备、工业控制系统等领域。
7. 封装信息:EL817采用DIP-6封装形式。
684M5W1103L461 价格&库存
很抱歉,暂时无法提供与“684M5W1103L461”相匹配的价格&库存,您可以联系我们找货
