684S21W1103L461
684S21W1103L461
    NORCOMP
    弯插
    21(20 + 1 电源) 位 D-Sub,组合式 插头,公引脚 连接器, 通孔,直角 焊接
684S21W1103L461 数据手册
DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 ELECTRICAL: INSULATOR RESISTANCE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER CONTACT AMPERAGE: 2.088 [53.05] 1.852 [47.05] 1.533 [38.95] 5 GΩ MIN. 250V -55°C TO +125°C 1.0 mΩ MAX. SEE P/N KEY MECHANICAL: 4.5 Kg MAX. CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 0.3 Kg MIN. 0.492 [12.50] 0.327 [8.30] 1 2 3 4 5 11 12 13 14 15 A1 6 7 8 9 10 MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SHELL: BRACKET: BOARD LOCK: SEAL: NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS F08 FLEXIBLE ADHESIVE 230°C PROCESS TEMP. 16 17 18 19 20 10° MEETS IP67 STANDARDS (SEE PAGE 3 FOR SEALING DETAILS) 0.240 [6.10] 0.031 [0.80] 684S21W1103LYYY 00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 06/11/2013 NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 684S21W1103L461 4 DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 1.852 RIGHT ANGLE BRACKET 0.652 0.598 DIMENSIONS(in/mm) 0.544 OPTION #4-40 INSERT 0.489 0.435 S P 0.146 0.185 46 0.381 3.70 4.70 0.087 0.087 2.22 2.22 62 0.326 Ø0.165 1-PLACE 0.272 0.420 [10.67] 0.218 0.163 Ø0.130 2-PLACES SIGNAL CONTACTS 0.520 0.470 0.420 0.370 POWER CONTACTS Ø0.043 20-PLACES PCB EDGE Ø 0.026 [Ø 0.65] S Ø 0.148 [Ø 3.75] P 0.370 [9.40] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 06/11/2013 0.520 [13.20] NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 684S21W1103L461 4 DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67 A A FRONT SEAL APPLIED OVER INSULATOR AND BETWEEN FRONT & REAR SHELLS DETAIL A-A SHOWN FOR REFERENCE ONLY RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DO NOT SCALE FROM DRAWING DRAWN: M. SIGMON DATE: 06/11/2013 NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 684S21W1103L461 4
684S21W1103L461 价格&库存
很抱歉,暂时无法提供与“684S21W1103L461”相匹配的价格&库存,您可以联系我们找货
