Universal Reversible USB 2.0 Hi-Speed
Extension Cable (Reversible A to A M/F), White,
6-ft.
MODEL NUMBER: UR024-006-WH
Highlights
Universal / Reversible A-Male
plugs in any direction
Extend distances of USB 2.0
cables with this extension cable
Supports faster data transfer
rates (1.5 to 480 Mbps) for low
speed and high speed devices,
especially multimedia
applications
Premium double-shielded
cables with tinned copper braid
and aluminum mylar foil feature
twisted 28/24 AWG data lines
Gold plated contacts provide
superior conductivity
System Requirements
Any USB device requiring a
USB cable
USB2.0 performance only when
used with USB2.0 device and
USB2.0 controller
Package Includes
Reversible Right Angle USB "A" connector plugs in any direction
Description
This 6-ft USB extension cable features a Universal / Reversible, A-Male connector, and is manufactured
using USB2.0 cable. Universal / Reversible connector allows the cable to be plugged in any direction. This
cable is backwards compatible and can also be used with the older USB 1.1 cables. Made with superior
foil shielding for reliable error-free data communications. Features nickel plated connectors and gold
plated copper contacts for superior conductivity. The cable is manufactured with molded connectors and
integral strain relief for extra durability and long life. The significantly faster data transfer rates of USB 2.0
(up to 480 Mbps) makes it perfect for multimedia applications.
Features
6ft, White, USB 2.0 A-Male to A-Female Extension, with Universal / Reversible "A" Male connector
USB 2.0 compliant, to 480Mbps transfer rates
Backward compatible with previous USB generations
Gold plated contacts and molded ends provide a lifetime of use
28AWG Data Pair, 24AWG Power pair
Specifications
OVERVIEW
UPC Code
037332182074
Technology
USB 2.0 (High Speed)
1/2
Universal Reversible USB 2.0 AMale to A-Female Extension
Cable - White - 6ft
PHYSICAL
Color
White
Cable Length (ft.)
6
Cable Length (m)
1.83
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 1.27
Shipping Weight (lbs.)
0.14
Shipping Weight (kg)
0.06
ENVIRONMENTAL
Operating Temperature Range
-10/+75° C (14 to 167° F)
Storage Temperature Range
-20/+80° C (-4 to 176° F)
CONNECTIONS
Side A - Connector 1
REVERSIBLE USB A (MALE)
Side B - Connector 1
USB A (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“UR024-006-WH”相匹配的价格&库存,您可以联系我们找货
