Universal Reversible USB 2.0 Cable (Reversible
A to 5Pin Micro B M/M) White, 3 ft. (0.91 m)
MODEL NUMBER: UR050-003-WH
Highlights
Next Generation USB Digital
Device Connector
Provides both Data and Power
transfers
USB 2.0 480Mbps Transfer
rates
Universal / Reversible "A" Male
to Micro-B Male
System Requirements
Digital devices that use the USB
Micro-B Female socket
Package Includes
Universal / Reversible "A" connector allows plugging in any direction
Description
Tripp Lite UR050-003-WH, White, 3-ft. (0.91 m), USB 2.0 A to Micro-B cable, features a Universal /
Reversible "A" connector, which takes the guesswork out of which way to position the "A" connector for
plugging. Micro-USB is the next generation of USB connector that will be found on Cell Phones, PDA's,
USB On-the-Go ( OTG ) devices, Digital Cameras, and more. Smaller and more durable ( 10,000 insertion
cycles ) than the existing mini-B connectors, the Micro-USB will also handle Power transfers, as well as
Data. The USB Implementers Forum ( USB-IF ) has designed the Micro-USB to eliminate many of the
proprietary Mini connectors found on different manufacturers digital devices, and it will be the standard
USB connection on phones from the major cell phone manufacturers. USB 2.0 rated cable handles
480Mbps data transfer rates.
Features
USB Universal / Reversible A Male to Micro-B Male
Available in lengths up to 10-ft. (3.05 m)
480Mbps USB 2.0 Data Transfer Rates
Data and Power transference
Specifications
OVERVIEW
UPC Code
037332182388
Technology
USB 2.0 (High Speed)
USB Cable Type
Passive
PHYSICAL
Cable Jacket Color
White
1/2
3-ft. (0.91 m) USB2.0 Universal /
Reversible A to Micro-USB B
Device Cable (A Male to MicroB Male) - White
Cable Length (ft.)
3
Cable Length (m)
0.91
Shipping Dimensions (hwd / in.)
7.00 x 9.00 x 0.50
Shipping Dimensions (hwd / cm)
17.78 x 22.86 x 1.27
Shipping Weight (lbs.)
0.09
Shipping Weight (kg)
0.04
ENVIRONMENTAL
Operating Temperature Range
14 to 122 F (-10 to 50 C)
Storage Temperature Range
5 to 140 F (-15 to 60 C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
REVERSIBLE USB A (MALE)
Side B - Connector 1
MICRO-USB B (MALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“UR050-003-WH”相匹配的价格&库存,您可以联系我们找货
