DESCRIPTION: POWER / SIGNAL - RIGHT ANGLE - MALE - MACHINED
5 GΩ MIN.
250V
-55°C TO +125°C
2.732 [69.40]
1.0 mΩ MAX.
10 mΩ MAX.
SEE P/N KEY
5 AMPS
2.500 [63.50]
2.181 [55.40]
A1
A2
1 2 3
4 5
6 7
4.5 Kg MAX.
0.3 Kg MIN.
8
9 A3
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
A4
0.492 [12.50]
230°C PROCESS TEMP.
10 11 12 13 14 15 16 17
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
0.112 [2.84]
10°
0.327 [8.30]
0.240 [6.10]
0.031 [0.80]
0.433 [11.00]
684M21WA4PLYYY
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
07/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
684M21WA4PL461
2
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
2.500
0.893
OPTION
#4-40 INSERT
0.618
S
P
0.146
0.185
3.70
4.70
0.087
0.087
2.22
2.22
46
0.435
0.381
62
0.326
0.272
Ø0.043
17-PLACES
0.218
0.420 [10.67]
0.163
0.109
Ø0.165
4-PLACES
0.055
0.520
0.370
0.470
0.420
SIGNAL CONTACTS
POWER CONTACTS
Ø0.130
2-PLACES
PCB EDGE
Ø 0.026 [Ø 0.65]
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
07/22/2013
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
684M21WA4PL461
2
很抱歉,暂时无法提供与“684M21WA4PL461”相匹配的价格&库存,您可以联系我们找货
