1000 Eaton Boulevard
Cleveland, OH 44122
United States
Easy Pull Long-Run Display Cable - Type-A
Analog PVC Trunk Cable, 100 ft. (30.5 m)
MODEL NUMBER: EZA-100
Highlights
Versatile trunk cable allows for a
variety of connection options
At a diameter of 7/8 in., it easily
pulls through conduit or confined
spaces using the included end
cap with integrated pull tab
High quality RGB style VGA
cable supports resolutions up to
1600 x 1200, as well as Audio
pass through
Package Includes
Description
Tripp Lite's EZA-100 100-ft. (30.5 m) Easy Pull VGA Trunk cable makes pulling video cable through
conduit or confined areas a breeze. Threaded ends feature screw on pull-caps, which can be attached to
fish tape. Choose from a variety of connector choices that easily screw on to the threaded ends of the
trunk cable. Trunk cables are available in 35-ft. (10.67 m), 50-ft. (15.24 m), and 100-ft. (30.5 m) lengths,
PVC and plenum rated. Cable ends are colored-coded green to denote VGA applications (Digital trunk
cables are Yellow). Cable features triple-shielded construction with 75 ohm coax conductors for RGBHV
signals supporting resolutions up to 1600 x 1200. Trunk also carries Audio signals when used with Easy
Pull end kits that feature Audio connections.
Features
Eliminates the need to field terminate VGA connectors
Detachable, screw-on connectors
Allows cable to be run according to code - inside conduit, drop ceilings, etc.
At a diameter of 7/8 in., it makes pulling long cables fast and easy
Protects entire cable from strain, dirt, debris and damage
Choose from a variety of connector combinations for the perfect fit
Available in 35-ft. (10.67 m), 50-ft. (15.24 m), and 100-ft. (30.5 m) lengths, both PVC and plenum rated
Supports Video and Audio pass through depending on end kit used
Specifications
OVERVIEW
UPC Code
037332141880
1/2
Easy Pull Type-A VGA Analog
PVC Trunk Cable, 100-ft. (30.5
m)
Cleveland, OH 44122
United States
Technology
VGA/SVGA
PHYSICAL
Color
Black; Green
Cable Length (ft.)
100
Cable Length (m)
30.49
Shipping Dimensions (hwd / in.)
2.00 x 9.50 x 10.00
Shipping Dimensions (hwd / cm)
5.08 x 24.13 x 25.40
Shipping Weight (lbs.)
3.90
Shipping Weight (kg)
1.77
CONNECTIONS
Side A - Connector 1
DIN 14 PIN (FEMALE)
Side B - Connector 1
DIN 14 PIN (FEMALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“EZA-100”相匹配的价格&库存,您可以联系我们找货
