1000 Eaton Boulevard
Cleveland, OH 44122
United States
Easy Pull Long-Run Display Cable - Type-A
Analog Plenum Trunk Cable, 50-ft.
MODEL NUMBER: EZA-050-P
Highlights
Versatile trunk cable allows for a
variety of connection options
Plenum-rated jacket to comply
with local fire codes
At a diameter of 7/8 in., it easily
pulls through conduit or confined
spaces using the included end
cap with integrated pull tab
High quality RGB style VGA
cable supports resolutions up to
1600 x 1200, as well as Audio
pass through
Package Includes
Description
Tripp Lite's EZA-050-P 50 ft. Easy Pull VGA Plenum Trunk Cable makes pulling video cable through
conduit or confined areas a breeze. Plenum-rated jacket complies with local fire codes. Threaded ends
feature screw on pull-caps, which can be attached to fish tape. Choose from a variety of connector
choices that easily screw on to the threaded ends of the trunk cable. Trunk cables are available in 35 ft.,
50 ft. and 100 ft. lengths, both PVC and plenum rated. Cable ends are colored-coded green to denote
VGA applications (Digital trunk cables are Yellow). Cable features triple-shielded construction with 75 ohm
coax conductors for RGBHV signals supporting resolutions up to 1600 x 1200. Trunk also carries Audio
signals when used with Easy Pull end kits that feature Audio connections.
Features
Eliminates the need to field terminate VGA connectors
Detachable, screw-on connectors
Plenum-rated jacket complies to local fire codes
At a diameter of 7/8 in., it makes pulling long cables fast and easy
Protects entire cable from strain, dirt, debris and damage
Choose from a variety of connector combinations for the perfect fit
Available in 35 ft., 50 ft. and 100 ft., both PVC and plenum rated
Supports Video and Audio pass through depending on end kit used
Specifications
OVERVIEW
UPC Code
037332141866
1/2
Easy Pull Type-A VGA Analog
Plenum Trunk Cable, 50 ft.
Cleveland, OH 44122
United States
Technology
VGA/SVGA
PHYSICAL
Color
Black; Green
Cable Length (ft.)
50
Cable Length (m)
15.24
Shipping Dimensions (hwd / in.)
12.00 x 10.00 x 0.50
Shipping Dimensions (hwd / cm)
30.48 x 25.40 x 1.27
Shipping Weight (lbs.)
4.50
Shipping Weight (kg)
2.04
CONNECTIONS
Side A - Connector 1
DIN 14 PIN (FEMALE)
Side B - Connector 1
DIN 14 PIN (FEMALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“EZA-050-P”相匹配的价格&库存,您可以联系我们找货
