BK13C06-50DS/2-0.35V(895) 数据手册
COUNT
DESCRIPTION OF REVISIONS
CHKD DATE
BY
COUNT
BY
CHKD
DATE
APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
STORAGE
TEMPERATURE RANGE
APPLICABLE
CONNECTOR
-55℃ TO +85℃(note1)
VOLTAGE
30 V AC/DC
CURRENT
SIGNAL CONTACT 0.3A(note2)
POWER CONTACT 5.0A
-10℃ TO +60℃
BK13C06-50DS/2-0.35V(**)
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT AT
CONSTRUCTION
GENERAL EXAMINATION
CONFIRMED VISUALLY AND BY MEASURING
INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
X
X
X
X
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE
20mV AC OR LESS 1kHz, 1mA
SIGNAL CONTACT : 90mΩ MAX
POWER CONTACT : 30mΩ MAX
X
INSULATION RESISTANCE
100V DC
50MΩ MIN
X
VOLTAGE PROOF
100V AC FOR 1min.
NO FLASHOVER OR BREAKDOWN
X
X
X
X
X
X
X
MECHANICAL CHARACTERISTICS
MECHANICAL
OPERATION
① CONTACT RESISTANCE:
10 TIMES INSERTIONS AND EXTRACTIONS.
② NO DAMAGE, CRACK OR LOOSENESS
OF PATRS.
VIBRATION
SHOCK
FREQUENCY 10 TO 55 TO 10 Hz, APPROX 5min
SINGLE AMPLITUDE 0.75mm, 10CYCLES,
FOR 3 DIRECTIONS.
① NO ELECTRICAL DISCONTINUITY OF 1μs.
OF PARTS.
490 m/s² DURATION OF PULSE 11ms AT 3 TIMES
FOR 3 DIRECTIONS.
OF PARTS.
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE -55 → +85℃
TIME
30 → 30 min
UNDER 5 CYCLES.
(RELOCATION TIME TO CHAMBER: WITHIN2~3 MIN)
② INSULATION RESISTANCE: 50MΩ MIN
③ NO DAMAGE, CRACK OR LOOSENESS
OF PARTS.
DAMP HEAT
(STEADY STATE)
EXPOSED AT 40±2℃, 90 TO 95%, 96h.
② INSULATION RESISTANCE: 25MΩ MIN
OF PARTS.
SULPHUR DIOXIDE
EXPOSED IN 25 PPM FOR 96h, 25℃, 75±5%RH.
(Test standard : JIS C 60068)
OF PARTS.
REMARKS
Note 1 : INCLUDE THE TEMPERATURE RISING BY CURRENT.
Note 2 : MAX 12A AT TOTAL PIN CONTACTS.
QT: QUALIFICATION TEST
AT: ASSURANCE TEST
HIROSE KOREA CO.,LTD.
CODE NO.(OLD)
DESIGNED
CHECKED
APPROVED
D.K.YUN
D.K.YUN
H.W.JO
H.W.JO
RELEASED
ENG
20.09.25
Unless otherwise specified, refer to JIS C 5402 and IEC 60512
Note
DRAWN
20.09.25
20.09.25
20.09.25
20.09.25
DEPT
X: APPLICABLE TEST
SPECIFICATION SHEET
DRAWING NO.
ELC3-632996-95
PART NO.
BK13C06-50DP/2-0.35V(895)
1
CODE NO.
CL 6665-0033-4-895
1
BK13C06-50DS/2-0.35V(895) 价格&库存
很抱歉,暂时无法提供与“BK13C06-50DS/2-0.35V(895)”相匹配的价格&库存,您可以联系我们找货
