1000 Eaton Boulevard
Cleveland, OH 44122
United States
Safe-IT USB 2.0 A to Micro-B Antibacterial Cable
(M/M), White, 6 ft. (1.83 m)
MODEL NUMBER: U050AB-006-WH
Highlights
Supports USB 2.0 speeds up to
480 Mbps to ensure efficient
data transfers
Made with antibacterial material
proven effective in inhibiting the
growth of E. coli and staph
Foil and braid shielding protects
against EMI/RFI noise that can
distort or destroy data
Molded nickel-plated connectors
provide excellent conductivity
White jacket permits fast, easy
identification in a crowded hub
or computer
Applications
USB cable with antibacterial properties connects mobile devices to your computer while helping to protect
you from harmful bacteria.
Features
Durable USB-A to USB Micro-B Cable Transfers Important Data at USB 2.0 Speeds
This USB cable (M/M) connects a smartphone, GPS unit, digital camera or other USB Micro-B peripheral
to the USB-A port on your computer, laptop or wall charger. It charges and powers your smartphone
through its Micro-B port. It also transfers data at USB 2.0 speeds up to 480 Mbps for use with low-speed
and high-speed devices, including multimedia applications. The cable is backward compatible with earlier
USB generations.
Provides Extra Protection Against Certain Bacteria
The molded connectors and PVC jacket are constructed using an antibacterial material that is effective in
inhibiting the growth of Escherichia coli (E. coli) and Staphylococcus aureus (staph). This added
protection makes this cable an ideal solution for medical facilities, schools, businesses,
restaurants/kitchens and anywhere else that needs extra protection against bacteria.
Premium Construction for Superior Performance
Manufactured with twisted 28 AWG data lines and 28 AWG power lines, the U050AB-006-WH also
features molded nickel-plated connectors for excellent conductivity. Integral strain relief gives the cable
extra flexibility, reduces stress and helps the cable move freely without cracking or breaking loose from
the connector.
White Jacket Helps Avoid Misidentification That Can Cause Costly Downtime
The cable has a white PVC jacket, which is easy to identify quickly in a crowded computer or hub and
helps prevent the cable from becoming accidentally disconnected.
Specifications
OVERVIEW
UPC Code
037332260642
1/3
Connect a computer or laptop
and a USB Micro-B peripheral in
a home or office network
Charge and sync your
smartphone from a USB
computer or wall charger
Provide extra protection against
bacteria to give cable installers
and IT personnel peace of mind
during installation
Package Includes
U050AB-006-WH USB-A to USB
Micro-B Antibacterial Cable (M/M),
White, 6-ft. (1.83 m)
Cleveland, OH 44122
United States
Technology
USB 2.0 (High Speed)
Cable Type
Passive
PHYSICAL
Material of Construction
PVC
Cable Jacket Color
White
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Cable Outer Diameter (OD)
3.8mm
Wire Gauge (AWG)
28/28
Cable Length (ft.)
6
Cable Length (m)
1.83
Cable Length (in.)
72
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.05
Unit Packaging Type
Polybag
ENVIRONMENTAL
Operating Temperature Range
14° to 122°F (-10° to 50°C)
Storage Temperature Range
5° to 140°F (-15° to 60°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
CONNECTIONS
Side A - Connector 1
USB A (MALE)
Side B - Connector 1
MICRO-USB B (MALE)
Connector Plating
Nickel
Contact Plating
Gold
Connector Style
Straight
FEATURES & SPECIFICATIONS
Antimicrobial
No
USB Specification
USB 2.0 (up to 480 Mbps)
Antibacterial
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“U050AB-006-WH”相匹配的价格&库存,您可以联系我们找货
