Not Recommended for New designs
RI-ANT-S01C, RI-ANT-S02C
www.ti.com
SCBS851 – DECEMBER 2002 – REVISED DECEMBER 2005
SERIES 2000 STICK ANTENNA
FEATURES
Best in Class Performance Through Patented
HDX Technology
IP 64+ Protected
2 Types Available
Proven in Harsh Industrial Environments
Easy to Install and Use
APPLICATIONS
Access Control
Vehicle Identification
Container Tracking
Asset Management
Waste Management
DESCRIPTION
These antenna products connect to Radio Frequency Modules (RFM) and reader/writers to form the interface to
the low frequency (LF) 134.2 kHz Texas Instruments transponders. In combination with a reader/writer they
transmit energy and signals to the transponder and receive the response from the tag. There are two standard
stick antennas with 1 or 3 meter cable length available for usage in low frequency systems. Each antenna is
capable of creating a specific size and shape of read zone to meet the requirements of the target application.
Stick antennas provide a more focused read zone and an ability to discriminate between transponders.
The antennas are well suited for usage in a broad range of applications including, but not limited to, access
control, vehicle identification, container tracking, asset management and waste management applications.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2002–2005, Texas Instruments Incorporated
RI-ANT-S01C, RI-ANT-S02C Not Recommended for New designs
www.ti.com
ABSOLUTE MAXIMUM RATINGS
over operating free-air temperature range (unless otherwise noted)
RI-ANT-S01C
RI-ANT-S02C
UNIT
Operating temperature
–30°C to +70°C
–30°C to +70°C
°C
Storage temperature
–40°C to +85°C
–40°C to +85°C
°C
OPERATING CHARACTERISTICS
PART NUMBER
PARAMETER
RI-ANT-S01C
RI-ANT-S02C
Type
Ferrite rod
Inductance
Typically 27 µH @ 134.2 kHz
Protection class
IP66
Vibration
Mil-Std -- 810 E, Test 514.4 (Category 1, Procedure 1; Basic transportation)
Case material
Glass reinforced epoxy (grey)
Dimensions
21 ± 2 × 140 ± 2
Weight
134
185
g
Cable Lenght
1
3
m
Connection terminals
Ring lugs: 3.5 mm inside diameter, 6 mm outside diameter
Mounting
Use non-metal clamps. Mounting material is not supplied with the antenna.
mm
Readout pattern of Stick Antenna
Trp. 1 reading field
Trp. 2 reading field
±2
Trp. 1
∅21
Trp. 1
140 ± 2
Trp. 2
Trp. 2
2
UNIT
Submit Documentation Feedback
PACKAGE OPTION ADDENDUM
www.ti.com
15-Jul-2017
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
Lead/Ball Finish
MSL Peak Temp
(2)
(6)
(3)
Op Temp (°C)
Device Marking
(4/5)
RI-ANT-S01C-30
NRND
TBD
Call TI
Call TI
-30 to 70
TRPGR30ATGA
ACTIVE
RFIDT
TGA
Pb-Free
(RoHS)
Call TI
N / A for Pkg Type
-25 to 70
TRPGR30ATGB
ACTIVE
RFIDT
TGB
Pb-Free
(RoHS)
Call TI
N / A for Pkg Type
-25 to 70
TRPGR30ENATGA
ACTIVE
RFIDT
TGA
Pb-Free
(RoHS)
Call TI
N / A for Pkg Type
-25 to 70
TRPGR30ENATGB
ACTIVE
RFIDT
TGB
Pb-Free
(RoHS)
Call TI
N / A for Pkg Type
-25 to 70
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
很抱歉,暂时无法提供与“TRPGR30TGC”相匹配的价格&库存,您可以联系我们找货
