A
B
C
D
E
F
G
H
N1
8
1
2
3
4
5
N1
6
C
:critical dimension
M
:major dimension
8
N2
7
16,5/0.649 Max.
Coaxial insert
23/0.906 Max.
Multicontacts insert
( n17,8/0.669)
7
18,75/0.708 Max.
A.3; Validé
CountryJurisdiction
& Control List
FR
NOT LISTED
7
6
6
(20/0.787)
3.5/0.118 Min.
MARQUAGE/MARKING
52.5/2.047 Max.
JUPITER
FR
FED10PLY
5
5
SEMAINE/WEEK
ANNEE/YEAR
4
N1 : MONTAGE AVEC GRAISSE
MOUNTING WITH GREASE
REFERENCE COMMERCIALE
PART NUMBER
N2
CFE10PLY
3
7
ISOLANT / INSERT
6
JOINT TORIQUE ISOLANT / O'RING INSERT
5
JOINT TORIQUE ACCOUPLEMENT / O'RING COUPLING
4
BAGUE DE RETENUE / RETAINING RING
3
DOUILLE D'ACCOUPLEMENT / COUPLING RING
2
CIRCLIPS / RETAINING CLIP
A
1
FICHE DROITE FED / STRAIGHT PLUG FED
Iss
REP
: ISOLANT HORS FOURNITURE
INSERT NOT SUPPLIED
3
DESIGNATION
05/09/16
Initial drawing
_ _ ORAIN
2
1
D
MOD N $
PROTECTION/PLATING
CODE
DIMENSIONS ARE DEFINED BEFORE PLATING
Generales tolerances
ISO 2768
General machining
Voir Référence Commerciale / See Part Number
SOURIAU
3, RUE DU VALLON
ZAC N $ 2
94440 MAROLLES-EN-BRIE
Surface texture
This document is the property of
SOURIAU
it must not be reproduced or
communicated without permission.
C
PL54
SERIE PL - TAILLE 10
Material Reference
2
PROJECT
FICHE DROITE FED SA / STRAIGHT PLUG FED SA TYPE
(FRANCE)
TEL. 33 (0)1 45 10 78 00
Geometrical Tolerances: NF EN ISO 1101
E
Designed by Checked by
DIFF
TREATMENT
Scale
4/1
F
Nat.
MEFFRE
MATERIAL --
SCALE 2/1
G
A C
MODIFICATIONS
Date
TITLE
H
4
FORMAT
A2
B
SOURIAU DRG N $
542F0130A8C
Iss
A
A
SHEET
1/1
1
很抱歉,暂时无法提供与“CFE10PLSAY”相匹配的价格&库存,您可以联系我们找货
