74LV03
Quad 2-input NAND gate
Rev. 4 — 31 August 2017
1
Product data sheet
General description
The 74LV03 is a low-voltage Si-gate CMOS device and is pin and function compatible
with 74HC/HCT03.
The 74LV03 provides the 2-input NAND function.
The 74LV03 has open-drain N-transistor outputs, which are not clamped by a diode
connected to VCC. In the OFF-state, i.e., when one input is LOW, the output may be
pulled to any voltage between GND and VO(max). This allows the device to be used as
a LOW-to-HIGH or HIGH-to-LOW level shifter. For digital operation and OR-tied output
applications, these devices must have a pull-up resistor to establish a logic HIGH level.
2
Features and benefits
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical VOLP (output ground bounce) < 0.8 V @ VCC = 3.3 V, Tamb = 25 °C
Typical VOHV (output VOH undershoot) > 2 V @ VCC = 3.3 V, Tamb = 25 °C
Level shifter capability
ESD protection:
– HBM JESD22-A114F exceeds 2000 V
– MM JESD22-A115-A exceeds 200 V
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3
Ordering information
Table 1. Ordering information
Type number
74LV03D
Package
Temperature range
Name
Description
Version
-40 °C to + 125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV03
Nexperia
4
Functional diagram
1
1 1A
2 1B
1Y 3
4 2A
5 2B
2Y 6
9 3A
10 3B
3Y 8
12 4A
13 4B
2
4
5
9
10
12
4Y 11
13
mna212
Figure 1. Logic symbol
5
3
6
8
Y
A
11
B
aaa-008083
GND
001aab715
Figure 2. IEC logic symbol
Figure 3. Logic diagram (one gate)
Pinning information
5.1 Pinning
74LV03
1A
1
14 VCC
1B
2
13 4B
1Y
3
12 4A
2A
4
11 4Y
2B
5
10 3B
2Y
6
9
3A
GND
7
8
3Y
aaa-027324
Figure 4. Pin configuration SO14
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
1A, 2A, 3A, 4A
1, 4, 9, 12
data input
1B, 2B, 3B, 4B
2, 5, 10, 13
data input
1Y, 2Y, 3Y, 4Y
3, 6, 8, 11
data output
GND
7
ground (0 V)
VCC
14
supply voltage
74LV03
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 12
74LV03
Nexperia
6
Functional description
Table 3. Function table
[1]
Output
Input
nA
nB
nY
L
L
Z
L
H
Z
H
L
Z
H
H
L
[1]
H = HIGH voltage level;
L = LOW voltage level;
Z = high-impedance OFF-state.
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
Min
Max
Unit
-0.5
+7.0
V
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
[1]
±50
mA
±25
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Ptot
[1]
[2]
total power dissipation
Tamb = -40 °C to +125 °C
[2]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
Ptot derates linearly with 8 mW/K above 70 °C.
74LV03
Product data sheet
3 / 12
74LV03
Nexperia
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
Min
Typ
Max
1.0
3.3
5.5
V
[1]
Unit
VCC
supply voltage
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 1.0 V to 2.0 V
500
ns/V
VCC = 2.0 V to 2.7 V
200
ns/V
VCC = 2.7 V to 3.6 V
100
ns/V
VCC = 3.6 V to 5.5 V
50
ns/V
[1]
9
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to VCC = 1.0 V (with input
levels GND or VCC).
Static characteristics
Table 6. Static characteristics
Symbol Parameter
VIH
VIL
VOL
II
HIGH-level
input voltage
LOW-level
input voltage
LOW-level
output voltage
input leakage
current
74LV03
Product data sheet
Conditions
-40 °C to +85 °C
Min
Typ
VCC = 1.2 V
0.9
VCC = 2.0 V
[1]
-40 °C to +125 °C Unit
Max
Min
Max
0.9
V
1.4
1.4
V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
VCC = 1.2 V
0.3
0.3
V
VCC = 2.0 V
0.6
0.6
V
0.8
0.8
V
0.3VCC
0.3VCC
V
IO = 100 μA; VCC = 1.2 V
V
IO = 100 μA; VCC = 2.0 V
0.2
V
IO = 100 μA; VCC = 2.7 V
0.2
V
IO = 100 μA; VCC = 3.0 V
0.2
V
IO = 100 μA; VCC = 4.5 V
0.2
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
0.50
V
IO = 12 mA; VCC = 4.5 V
0.35
0.55
0.65
V
1.0
1.0
μA
VI = VIH or VIL
VI = VCC or GND; VCC = 5.5 V
4 / 12
74LV03
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
IOZ
OFF-state
output current
per input pin; VCC = 2.0 V to 3.6 V;
VI = VIL; VO = VCC or GND;
other inputs at VCC or GND
VI = VIL; VO = 6.0 V;
[2]
Typ
[1]
Max
Min
Max
±5.0
±10
μA
±10.0
±20
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
40
μA
ΔICC
additional
supply current
per input; VI = VCC - 0.6 V;
500
850
μA
CI
input
capacitance
3.5
pF
[1]
[2]
Typical values are measured at Tamb = 25 °C.
The maximum operating output voltage (VO(max)) is 6.0 V.
10 Dynamic characteristics
Table 7. Dynamic characteristics
GND = 0 V; For test circuit see Figure 6.
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation
delay
nA, nB to nY; see Figure 5
Max
Min
Max
VCC = 1.2 V
50
ns
VCC = 2.0 V
17
26
31
ns
VCC = 2.7 V
13
19
23
ns
8
ns
10
16
19
ns
13
16
ns
4
pF
VCC = 3.0 V to 3.6 V
[3]
[1]
[2]
[3]
[4]
[2]
VCC = 3.3 V; CL = 15 pF
CPD
Typ
[1]
power dissipation CL = 0 pF; RL = ∞ Ω;
capacitance
VI = GND to VCC
[4]
All typical values are measured at Tamb = 25 °C.
tpd is the same as tPLZ and tPZL.
Typical values are measured at nominal supply voltage (VCC = 3.3 V).
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz,
fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs.
74LV03
Product data sheet
5 / 12
74LV03
Nexperia
10.1 Waveforms and test circuit
VI
nA, nB input
VM
GND
t PZL
t PLZ
VCC
nY output
VM
VOL
VX
mnb132
Measurement points are given in Table 8
VOL is a typical voltage output level that occurs with the output load.
Figure 5. Inputs nA and nB to output nY propagation delay times
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VM
VX
VM
≤ 2.7 V
0.5 × VCC
VOL + 0.1 V
0.5 × VCC
2.7 V to 3.6 V
1.5 V
VOL + 0.3 V
1.5 V
≥ 4.5 V
0.5 × VCC
VOL + 0.1 V
0.5 × VCC
74LV03
Product data sheet
6 / 12
74LV03
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
PULSE
GENERATOR
VI
RL
VO
DUT
RT
CL
RL
001aae235
Test data is given in Table 9
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 6. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLZ, tPZL
≤ 2.7 V
VCC
≤ 2.5 ns
50 pF
1 kΩ
2 × VCC
2.7 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
1 kΩ
2 × VCC
≥ 4.5 V
VCC
≤ 2.5 ns
50 pF
1 kΩ
2 × VCC
74LV03
Product data sheet
VEXT
Load
7 / 12
74LV03
Nexperia
11 Package outline
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
A2
Q
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.05
0.01
0.01
0.004
0.028
0.012
0.244
0.039 0.028
0.041
0.228
0.016 0.024
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Figure 7. Package outline SOT108-1 (SO14)
74LV03
Product data sheet
8 / 12
74LV03
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
TTL
Transistor-Transistor Logic
13 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV03 v.4
20170831
Product data sheet
74LV03 v.3
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74LV03 v.3
20030303
Modifications:
• Deleted DIL, SSOP and TSSOP package ordering and package outlines (discontinued options).
• Corrected power dissipation formula.
74LV03 v.2
19980420
Product specification
ECN 853-1963 19257
74LV03 v.1
74LV03 v.1
19970328
74LV03
Product data sheet
Product data sheet
ECN 853-1963 29494
74LV03 v.2
9 / 12
74LV03
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74LV03
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
10 / 12
74LV03
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74LV03
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
11 / 12
74LV03
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 2
Pinning ............................................................... 2
Pin description ................................................... 2
Functional description ........................................3
Limiting values .................................................... 3
Recommended operating conditions ................ 4
Static characteristics .......................................... 4
Dynamic characteristics .....................................5
Waveforms and test circuit ................................ 6
Package outline ...................................................8
Abbreviations ...................................................... 9
Revision history .................................................. 9
Legal information .............................................. 10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 31 August 2017
Document identifier: 74LV03
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Nexperia:
74LV03D,112 74LV03D,118
