Advanced Science And Novel Technology Company, Inc.
2790 Skypark Drive Suite 112, Torrance, CA 90505
Offices: 310-530-9400 / Fax: 310-530-9402
www.adsantec.com
ASNT1122-KHC
DC-32Gbps Broadband 1 of 4 Selector/Switch
High speed broadband switch connecting one of four inputs to a single output
Exhibits low jitter and limited temperature variation over industrial temperature range
Ideal for high speed proof-of-concept prototyping
CML compliant single ended input data interfaces
Fully differential CML output data interface
Digital control signals
Adjustable output signal’s duty cycle
Single +3.3V or -3.3V power supply
Power consumption: 300mW
Fabricated in SiGe for high performance, yield, and reliability
Custom CQFN 24-pin package
Rev. 1.0.2
1
April 2021
www.adsantec.com
DESCRIPTION
vcc
d0p
d1p
vcc
outp
outn
d2p
d3p
vbias
sel1
sel2
Fig. 1. Functional Block Diagram
The temperature stable and broadband ASNT1122-KHC SiGe IC is a high isolation selector switch that is
intended for use in high-speed measurement/test equipment. The IC shown in Fig. 1 routs one of 4 singleended CML inputs (d0p, d1p, d2p, d3p) to its differential CML output outp/outn while effectively
blocking the other data inputs with high isolation. Selection of a specific data input is controlled by two
digital control signals sel1 and sel2 in accordance with Table 1. The duty cycle of the output signal is
controlled by an external analog voltage vbias.
Table 1. Switch Controls
sel1 sel2
outp
outn
d0p direct d0p inverted
d2p direct d2p inverted
1
d1p direct d1p inverted
1
1
d3p direct d3p inverted
The part’s I/Os support the CML logic interface with on chip 50Ohm termination to vcc and may be used
differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY
CONFIGURATION). In the first mode, the input signal’s common mode voltage should comply with the
specifications shown in ELECTRICAL CHARACTERISTICS. In the second mode, the input termination
provides the required common mode voltage automatically. The differential DC signaling is
recommended for the optimal performance.
POWER SUPPLY CONFIGURATION
The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive
supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC
Rev. 1.0.2
2
April 2021
www.adsantec.com
termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts
will be needed for each different power supply combination.
All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V.
ABSOLUTE MAXIMUM RATINGS
Caution: Exceeding the absolute maximum ratings shown in Table 2 may cause damage to this product
and/or lead to reduced reliability. Functional performance is specified over the recommended operating
conditions for power supply and temperature only. AC and DC device characteristics at or beyond the
absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to
ground (assumed vcc).
Table 2. Absolute Maximum Ratings
Parameter
Supply Voltage (vee)
Power Consumption
RF Input Voltage Swing (SE)
Case Temperature
Storage Temperature
Operational Humidity
Storage Humidity
Min
-40
10
10
Max
-3.6
0.33
1.0
+90
+100
98
98
Units
V
W
V
ºC
ºC
TERMINAL FUNCTIONS
TERMINAL
Name
No.
Type
d0p
d1p
d2p
d3p
outp
outn
15
17
21
23
11
9
sel1
sel2
vbias
3
5
7
Name
vcc
vee
Rev. 1.0.2
CML
input
DESCRIPTION
High-Speed I/Os
Single-ended data inputs with internal 50Ohm termination to
vcc
CML Differential data outputs with internal 50Ohm termination to
output vcc. Require external SE 50Ohm termination to vcc
Controls
CMOS Digital control signals
input
Input Analog control voltage
Supply and Termination Voltages
Description
Positive power supply (+3.3V or 0V)
Negative power supply (0V or -3.3V)
3
Pin Number
2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24
1, 13, 19
April 2021
www.adsantec.com
PARAMETER
TYP MAX UNIT
COMMENTS
General Parameters
-3.1
-3.3
-3.5
V
±6%
vee
0.0
V
External
ground
vcc
Ivee
90
mA
Power consumption
300
mW
Junction temperature -40
25
125
°C
HS Input Data (d0p, d1p, d2p, d3p)
Data Rate
Gbps
Frequency
GHz
SE Swing
50
300
600
mV
Peak-to-peak
CM Voltage Level
vcc-330
mV
At vbias = vee
Input Select (sel1, sel2)
Frequency
1 MHz
Logic “0” level
vcc-2.5
vcc-2.3
V
Logic “1” level
vcc-0.2
vcc
V
Input Bias (vbias)
Voltage range
V
vee
vcc
HS Output Data (outp/outn)
Data Rate
Gbps
Frequency
GHz
Logic “1” level
V
vcc
Logic “0” level
vcc-0.4
V
With external 50Ohm DC termination
Rise/Fall Times
14
15
16
ps
20%-80%
Additive Jitter
2
ps
Peak-to-peak
Rev. 1.0.2
MIN
4
April 2021
www.adsantec.com
PACKAGE INFORMATION
The chip die is housed in a custom 24-pin CQFN package shown in Fig. 2. The package provides a center
heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this
section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive
supply.
Fig. 2. CQFN 24-Pin Package Drawing (All Dimensions in mm)
Rev. 1.0.2
5
April 2021
www.adsantec.com
The part’s identification label is ASNT1122-KHC. The first 8 characters of the name before the dash
identify the bare die including general circuit family, fabrication technology, specific circuit type, and part
version while the 3 digits after the underscore represent the package’s manufacturer, type, and pin out
count.
This device complies with Commission Delegated Directive (EU) 2015/863 of 4 June 2015 amending
Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of
restricted substances (Text with EEA relevance) on the restriction of the use of certain hazardous
substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set
forth in the directives for all ten substances.
REVISION HISTORY
Revision
1.0.2
Rev. 1.0.2
Date
04-2021
Changes
First release
6
April 2021
