ASNT5160-KHC
ASNT5160-KHC
    ADSANTEC(先进科技)
    CQFN24
    50GB BROADBAND AND OR LOGIC GATE
ASNT5160-KHC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT5160-KHC DC-50Gbps AND/OR Logic Gate  High speed broadband AND/OR Boolean logic gate  Exhibits low jitter and limited temperature variation over industrial temperature range  25GHz analog input bandwidth for both data inputs  Ideal for high speed proof-of-concept prototyping  Fully differential CML input interfaces  Fully differential CML output interface with 400mV single-ended swing  Single +3.3V or -3.3V power supply  Power consumption: 270mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFN 24-pin package Rev. 1.0.2 1 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION 50 50 dap qp AND core dan qn 50 50 50 50 dbp dbn Fig. 1. Functional Block Diagram The temperature stable ASNT5160-KHC SiGe IC provides broadband AND/OR Boolean logic functionality, and is intended for use in high-speed measurement / test equipment. The IC shown in Fig. 1 can AND/OR a high-speed data input signal dap/dan with another high-speed data input signal dbp/dbn, and deliver a high-speed NRZ data output signal qp/qn. An RZ data output signal can be generated by inserting up to half of the IC’s maximum data input frequency into one data input signal dap/dan or dbp/dbn while providing an up to its maximum clock signal analog bandwidth into the other data input dap/dan or dbp/dbn. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (also see POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.3V), or positive supply (vcc = +3.3V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. Rev. 1.0.2 2 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground. Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power Consumption RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min -40 10 10 Max -3.6 0.30 1.0 +90 +100 98 98 Units V W V ºC ºC % % TERMINAL FUNCTIONS TERMINAL Name No. Type dap dan dbp dbn qp qn Name vcc vee Rev. 1.0.2 DESCRIPTION High-Speed I/Os Differential data/clock inputs with internal SE 50Ohm termination to vcc. Differential data/clock inputs with internal SE 50Ohm termination to vcc. Differential data outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc. Supply and Termination Voltages Description Pin Number Positive power supply. (+3.3V or 0) 2, 4, 6, 8, 10, 12, 14, 15, 16, 17, 18, 20, 22, 24 Negative power supply. (0V or -3.3V) 1, 7, 13, 19 21 23 3 5 11 9 CML input CML input CML output 3 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Data Rate Clock Frequency Swing CM Voltage Level Data Rate Logic “1” level Logic “0” level Rise/Fall times Output Jitter MIN TYP MAX UNIT COMMENTS General Parameters -3.1 -3.3 -3.5 V ±6% 0.0 V External ground 85 mA 270 mW -40 25 125 °C HS Input Data/Clock (dap/dan, dbp/dbn) DC 50 Gbps When used to generate NRZ data DC 25 GHz When used to generate RZ data 0.05 1.0 V Differential or SE, p-p vcc-0.8 vcc V Must match for both inputs HS Output Data (qp/qn) DC 50 Gbps V vcc vcc-0.4 V With external 50Ohm DC termination 6 8 10 ps 20%-80% 1 ps Peak-to-peak PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFN package shown in Error! Reference source not found.. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT5160-KHC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with Commission Delegated Directive (EU) 2015/863 of 4 June 2015 amending Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of restricted substances (Text with EEA relevance) on the restriction of the use of certain hazardous substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set forth in the directives for all ten substances. Rev. 1.0.2 4 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 2. CQFN 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.0.2 5 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com REVISION HISTORY Revision 1.0.2 Rev. 1.0.2 Date 04-2021 Changes First release 6 April 2021
ASNT5160-KHC 价格&库存
很抱歉,暂时无法提供与“ASNT5160-KHC”相匹配的价格&库存,您可以联系我们找货
