ASNT8151-KHC
ASNT8151-KHC
    ADSANTEC(先进科技)
    CQFN24
    PROGRAMBL PLL W/ INTEGRATED VCOS
ASNT8151-KHC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT8151-KHC 24.0-to-32.1GHz Programmable PLL with 3 integrated VCOs  Programmable clock multiplier (CMU) with three selectable frequency ranges of internal PLL  External RC loop filter  LVDS input reference clock interface  Fully differential CML output full-rate clock interface  Selectable LVDS output clock divided-by-16 interface  3-state input control interface  Single positive or negative power supply  Power consumption: 0.53W at the maximum operational speed  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFN 24-pin package Rev. 1.0.2 1 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION fltr crp crn vc0 vc1 LS CIB C PLL C16 CRL HS COB cp cn LS COB c16p c16n Fig. 1. Functional Block Diagram The ASNT8151-KHC is a clock multiplication unit (CMU) with a triple-range phase-locked loop (PLL) incorporating three high-speed voltage-controlled oscillators: VCO1 (lower frequency), VCO2 (medium frequency), and VCO3 (higher frequency). The chip shown in Fig. 1 generates a high-speed clock signal cp/cn with its phase and frequency locked to those of the incoming reference clock crp/crn. The differential clock cp/cn with frequency f is delivered to the output by CML output buffer HS COB. The reference clock crp/crn with frequency f/16 is accepted by LVDS input buffer LS CIB. The chip also generates a divided-by-16 clock signal c16p/c16n with frequency f/16 that is delivered to the output by LVDS output buffer LS COB. One of the VCOs is activated using two 3-state control signals vc0 and vc1. The same control signals are used to activate or disable the output buffer LS COB. When operating in closed-loop mode, the PLL requires an external loop filter connected to pin fltr. The PLL also supports an open-loop mode of operation with its selected VCO controlled externally by a voltage applied to the filter pin fltr. The part’s high-speed output buffer supports the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination. The part’s lowspeed I/Os support the LVDS interface with internal 100Ohm termination between the direct and inverted lines. The differential DC signaling mode is recommended for optimal performance. LS CIB The Low-Speed Clock Input Buffer (LS CIB) can process an external reference clock signal crp/crn with a frequency equal to 1/16 of the selected VCO frequency. The clock inputs support the LVDS logic interface with on chip 100Ohm termination between the direct and inverted lines. The proprietary LVDS buffer exceeds the requirements of standards IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-644-1995. It is designed to accept a differential signal with a wide range of DC common mode voltages, or a singleended (SE) signal applied to one input pin with a DC threshold voltage applied to the other input pin. In case of a SE AC-terminated input, the common mode voltage should satisfy the requirements presented in ELECTRICAL CHARACTERISTICS. In case of a SE DC-terminated input, the DC common mode voltage should match the average level of the applied reference clock signal. Rev. 1.0.2 2 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PLL The PLL contains a phase frequency detector, a charge pump, an on-chip integrator with an additional offchip filter connected to pin fltr, and three selectable LC-tank VCOs with different central frequencies. The recommended parameters of the external filter schematic components shown in Fig. 2 are for reference only, and can be modified based on specific requirements. a. b. Fig. 2. External Filter Schematic for Positive (a) and Negative (b) Power Supplies The main function of the PLL is to synthesize a full-rate clock C by aligning the phase and frequency of the divided clock C16 from the internal divider to the externally applied reference clock crp/crn. The divided clock is delivered to outputs c16p/c16n through a CML output buffer LS COB. Selection of the required VCO is defined by the CMOS control signals vc0 and vc1 as shown in Table 1. The same signals are used to activate the LS COB block. Here “nc” means “not connected”. Table 1. VCO and LS COB Control Modes vc0 “0” “0” “0” nc nc nc ”1” ”1” ”1” vc1 Selected VCO LS COB “0” VCO1 (lower frequency) On nc VCO1 (lower frequency) Off ”1” VCO2 (medium frequency) On “0” VCO3 (higher frequency) Off nc VCO1 (lower frequency) Off ”1” VCO2 (medium frequency) Off “0” VCO3 (higher frequency) On nc VCO3 (higher frequency) Off ”1” VCO2 (medium frequency) On The PLL can also operate in open-loop mode with an external control voltage applied to pin fltr. In this case, the unused VCO is completely disabled in order to save power. The allowed control range is shown in Table 2. Table 2. VCO Control Voltage fltr voltage, V vcc vcc-2.5 Rev. 1.0.2 Frequency of the active VCO min max 3 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com HS COB The High Speed Clock Output Buffer (HS COB) receives a full-rate clock C from the PLL and converts it into CML output signal cp/cn. The buffer provides an internal single-ended termination of 50Ohm to vcc for each output line and also requires 50Ohm external termination resistors to be connected between vcc and each output. LS COB The Low-Speed Clock Output Buffer (COB) receives the divided-by-16 clock signal from the PLL’s divider and converts it into LVDS output signal c16p/c16n. The proprietary low-power LVDS output buffer utilizes a special architecture that ensures operation at frequencies up to 2.5GHz with low power consumption. The buffer satisfies all requirements of the IEEE Std. 1596.3-1996 and ANSI/TIA/EIA-6441995. For correct operation, it requires external differential 100Ohm DC termination at the receiver side. The output pins should NEVER be CONNECTED to devices with 50Ohm termination to ground WITHOUT DC BLOCKS! The buffer can be enabled or disabled by the external 3-state control signals vc0 and vc1 as shown in Table 1 above. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = -2.8V or −3.3V), or positive supply (vcc = +2.8V or +3.3V and vee = 0.0V = ground). In case of the positive supply, all CML I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vee = 0.0V and vcc = +3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 3 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vee). Table 3. Absolute Maximum Ratings Parameter Supply Voltage (vcc) Power Consumption Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Rev. 1.0.2 Min -40 10 10 4 Max 3.6 580 1.0 +90 +100 98 98 Units V mW V ºC ºC % % April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type cp cn 3 5 crp crn c16p c16n 17 15 23 21 vc0 vc1 fltr Name vcc vee Rev. 1.0.2 9 11 19 DESCRIPTION High-Speed I/Os Output CML differential clock outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Low-Speed I/Os Input LVDS/CML clock inputs. See LS CIB for allowed application schemes Output LVDS clock outputs. See LS COB for a detailed description Input Input Controls 3-state control signals Pin for connecting the external loop filter. Can be also used for VCO external control in open-loop mode Supply and Termination Voltages Description Pin Number Positive power supply (+2.8V or +3.3V) 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 External ground (0V ) 1, 7, 13 5 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivcc Power consumption Junction temperature Frequency Swing CM Voltage Level Frequency Logic “1” level Logic “0” level Jitter Duty Cycle Phase Noise Frequency Interface Logic “1” level “nc” level Logic “0” level Low frequency of VCO1 High frequency of VCO1 Low frequency of VCO2 High frequency of VCO2 Low frequency of VCO3 High frequency of VCO3 External control voltage range Rev. 1.0.2 MIN TYP MAX UNIT COMMENTS General Parameters 0.0 V External ground 2.8 / 3.3 V ±5% 160 mA 450 / 530 mW -25 50 125 °C LS Input Reference Clock (crp/crn) 1.50 2.006 GHz 1/16 of the VCO frequency 200 800 mV Differential, p-p 1.2 vcc-0.4 V HS Output Clock (cp/cn) 24.0 32.1 GHz Matches VCO frequency V vcc vcc-0.55 V 200 fs Peak-to-peak at 25.78GHz 50% 108 dBc/Hz At 32GHz at 1.0MHz offset LS Output Clock (c16p/c16n) 1.50 2.006 GHz LVDS Meets the IEEE Std. 3-State control inputs (vc0, vc1) vcc-0.3 V (vcc+vee)/2 Recommended to keep not connected. The required level is created internally. vee+0.3 V VCOs 24.0 GHz Lower-frequency VCO 27.5 GHz 25.3 GHz Medium-frequency VCO 27.7 GHz 27.5 GHz Higher-frequency VCO 32.1 GHz vcc-2.5 vcc V In open-loop mode 6 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFN package shown in Fig. 3. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. Fig. 3. CQFN 24-Pin Package Drawing (All Dimensions in mm) Rev. 1.0.2 7 April 2021 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The part’s identification label is ASNT8151-KHC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with Commission Delegated Directive (EU) 2015/863 of 4 June 2015 amending Annex II to Directive 2011/65/EU of the European Parliament and of the Council as regards the list of restricted substances (Text with EEA relevance) on the restriction of the use of certain hazardous substances in electrical and electronics equipment (RoHS Directive) in accordance with the definitions set forth in the directives for all ten substances. REVISION HISTORY Revision 1.0.2 Rev. 1.0.2 Date 04-2021 Changes Initial release 8 April 2021
ASNT8151-KHC 价格&库存
很抱歉,暂时无法提供与“ASNT8151-KHC”相匹配的价格&库存,您可以联系我们找货
