ASNT6142-KHC
ASNT6142-KHC
    ADSANTEC(先进科技)
    CQFN24
    20GHZ 10DB-25DB LINEAR AMPLIFIER
ASNT6142-KHC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ASNT6142-KHC DC-20GHz Linear amplifier  Fully differential input interface with on-chip 50Ohm termination  Fully differential output interface with on-chip 50Ohm termination  Single +3.3V or -3.3V power supply  Power consumption: 695mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFN 24-pin package vee Exhibits low jitter and limited temperature variation over industrial temperature range vcc  pkdet Features gain control, input offset adjustment, and input peak detector vcc  dcinp Broadband (DC-20GHz) linear amplifier for receiver-side applications vcc  vee vcc vcc inp outp vcc vcc 1 vcc vgc vcc vcc vcc dcinn outn vcc inn vee Rev. 1.1.2 ASNT6142 vee May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com DESCRIPTION dcinp 50 pkdet vcc 1K 50 inp outp inn outn 50 50 1K dcinn vcc vgc Fig. 1. Functional Block Diagram The temperature-stable linear amplifier ASNT6142-KHC, which is fabricated in an advanced SiGe technology, provides low-jitter broadband variable signal amplification between its input inp/inn and output outp/outn signal ports and is intended for use in high-speed communication systems. Gain adjustment is performed through the external control port vgc. A graph of the amplifier’s single-ended gain vs. vgc (where vcc=0V and x-axis values are settings below vcc) is shown below. Differential gain is found by adding 6dB to these y-axis numbers. Fig. 2. Single-ended Gain vs. Vgc Rev. 1.1.2 2 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com The part’s I/Os support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (see also POWER SUPPLY CONFIGURATION). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. The differential DC signaling mode is recommended for optimal performance. The on-chip peak detector delivers a single-ended output voltage pkdet proportional to the input signal’s amplitude. Additional control ports dcinp and dcinn can be used for input signal common-mode voltage adjustment. POWER SUPPLY CONFIGURATION The part can operate with either a negative supply (vcc = 0.0V=ground and vee = -3.3V), or a positive supply (vcc = +3.3V and vee = 0.0V=ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V and vee = -3.3V. ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. Table 1. Absolute Maximum Ratings Parameter Min Max Units Main Supply Voltage (vcc-vee) 3.6 V Power Consumption 0.80 W RF Input Voltage Swing (SE) 1.0 V CM control Voltage (dcinp/n-vcc) -2.2 +0.8 V Gain Control Voltage (vgc1-vcc) -2.0 +0.4 V Case Temperature +90 ºC Storage Temperature -40 +100 ºC Operational Humidity 10 98 % Storage Humidity 10 98 % Rev. 1.1.2 3 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com TERMINAL FUNCTIONS TERMINAL Name No. Type inp inn outp outn dcinp dcinn vgc pkdet Name vcc vee Rev. 1.1.2 DESCRIPTION High-Speed I/Os Differential high-speed data inputs with internal SE 50Ohm termination to vcc Differential high-speed data outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Low-Speed I/Os 17 Analog inp common mode control voltage Input inn common mode control voltage 3 5 Input Low-speed amplitude adjustment tuning input 15 Output Analog voltage generated by the peak detector Supply and Termination Voltages Description Pin Number Positive power supply (+3.3V or 0V) 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 Negative power supply (0V or -3.3V) 1, 7, 13, 19 21 23 11 9 CML input CML output 4 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER vee vcc Ivee Power consumption Junction temperature Bandwidth CM level Input noise density S11 CM level S22 Differential gain Differential gain Output referred 1dB compression point THD Voltage range Input Impedance Voltage range Input Impedance MIN -3.1 -25 -0.8 10 TYP MAX UNIT General Parameters -3.3 -3.5 V 0.0 V 210 mA 695 mW 50 85 °C HS Input Data (inp/inn) 20 GHz 0 V 1.5 nV/sqrt(Hz) -10 dB HS Output Data (outp/outn) -0.6 V -8 dB 25 dB dB 2.7 dBm COMMENTS ±6% External ground -3dB High Gain DC to 20GHz DC to 20GHz At 10GHz, vgc= vcc At 10GHz, vgc= vcc -1.5V Single-Ended, 20GHz 0.2 % At 350mVp-p output swing, SE Low-Speed Control Input (vgc) vcc-2.0 vcc V 2 KOhm DC Offset Control Inputs (dcinp/dcinn) vcc-2.0 vcc V 1 KOhm PACKAGE INFORMATION The chip die is housed in a custom, 24-pin CQFN package shown in Fig. 3. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. The part’s identification label is ASNT6142-KHC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per 2011/65/EU for all ten substances. Rev. 1.1.2 5 May 2020 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Drive Suite 112, Torrance, CA 90505 Offices: 310-530-9400 / Fax: 310-530-9402 www.adsantec.com Fig. 3. CQFN 24-Pin Package Drawing (All Dimensions in mm) REVISION HISTORY Revision 1.1.2 1.0.2 Date 05-2020 01-2020 Rev. 1.1.2 Changes Updated Package Information First release 6 May 2020
ASNT6142-KHC 价格&库存
很抱歉,暂时无法提供与“ASNT6142-KHC”相匹配的价格&库存,您可以联系我们找货
