ASNT6163-KHC
ASNT6163-KHC
    ADSANTEC(先进科技)
    CQFN24
    ANALOG SIGNAL SELECTOR 1-OF-2
ASNT6163-KHC 数据手册
Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com ASNT6163-KHC DC-32GHz Analog Signal Selector 1-of-2  1dB compression point of 0dBm  DC-to-1GHz broadband channel selector port  Optional two-channel mixer/adder setting available  Low jitter and limited temperature variation over industrial temperature range  Single +3.6V or -3.6V power supply  Power consumption: 700mW  Fabricated in SiGe for high performance, yield, and reliability  Custom CQFN 24-pin package vee Temperature-stabilized differential gain of approximately 0dB vcc  d0p Two differential CML-type input ports and one differential CML-type output port vcc  d0n DC to 32GHz broadband operation vcc  on2 vcc vcc sel qp vcc ASNT6163 ief1c qn 1 vcc d1n vcc d1p vcc vcc vee vcc Rev. 0.0.2 vcc ief3c December 2019 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com DESCRIPTION on2 50 d0p d0n 50 50 ief1c/ief3c 50 d1p d1n qp qn 50 50 sel Fig. 1. Functional Block Diagram The temperature stable ASNT6163-KHC analog signal selector 1-of-2 is intended for use in high-speed systems. The IC shown in Fig. 1 can deliver one of two different broad-band analog differential signals d0p/d0n and d1p/d1n to its differential output qp/qn with a nominal gain of 0dB. It can also be used as a two-channel analog mixer/adder of signals d0p/d0n and d1p/d1n. Two low-speed analog current controls Ief1c and Ief3c are available for bandwidth and peaking adjustments. The active input selection is performed through the external high-speed single-ended port sel that can be referenced to either vcc or vee. When the low-speed single-ended control port on2 is set to vcc, it switches the circuit into mixer/adder mode with both inputs active at the same time. The part’s I/O’s support the CML logic interface with on chip 50Ohm termination to vcc and may be used differentially, AC/DC coupled, single-ended, or in any combination (also see Error! Not a valid bookmark self-reference.). In the DC-coupling mode, the input signal’s common mode voltage should comply with the specifications shown in ELECTRICAL CHARACTERISTICS. In the AC-coupling mode, the input termination provides the required common mode voltage automatically. POWER SUPPLY CONFIGURATION The part can operate with either negative supply (vcc = 0.0V = ground and vee = −3.6V), or positive supply (vcc = +3.6V and vee = 0.0V = ground). In case of the positive supply, all I/Os need AC termination when connected to any devices with 50Ohm termination to ground. Different PCB layouts will be needed for each different power supply combination. All the characteristics detailed below assume vcc = 0.0V = ground. Rev. 0.0.2 2 December 2019 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com ABSOLUTE MAXIMUM RATINGS Caution: Exceeding the absolute maximum ratings shown in Table 1 may cause damage to this product and/or lead to reduced reliability. Functional performance is specified over the recommended operating conditions for power supply and temperature only. AC and DC device characteristics at or beyond the absolute maximum ratings are not assumed or implied. All min and max voltage limits are referenced to ground (assumed vcc). Table 1. Absolute Maximum Ratings Parameter Supply Voltage (vee) Power supply current Input Voltage RF Input Voltage Swing (SE) Case Temperature Storage Temperature Operational Humidity Storage Humidity Min vcc-1.2 -40 10 10 Max -4.0 320 vcc-0.6 0.6 +90 +100 98 98 Units V mA V V ºC ºC % % TERMINAL FUNCTION TERMINAL Name No. Type d0p d0n d1p d1n qp qn 15 17 3 5 11 9 sel 21 ief1c ief3c 23 7 on2 19 Name vcc vee Rev. 0.0.2 CML type CML type CML type DESCRIPTION High-speed Signals Differential high speed data inputs with internal SE 50Ohm termination to vcc Differential high speed data outputs with internal SE 50Ohm termination to vcc. Require external SE 50Ohm termination to vcc Control Signals SE High-speed high-impedance input (active: high, d1 is connected to q default: low, d0 is connected to q;) Analog Analog current control with internal 64KOhm termination to vcc Control and 72KOhm termination to vee. Low-speed high-impedance input (active: high, mixer/adder mode; CMOS default: low, 1-of-2 selector mode;) Supply and Termination Voltages Description Pin Number Positive power supply rail 2, 4, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24 Negative power supply rail 1, 13 3 December 2019 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com ELECTRICAL CHARACTERISTICS PARAMETER MIN vee vcc Ivee Power consumption Junction temperature Bandwidth Common mode level Voltage swing, pk-pk S11 Control range Default voltage level Bandwidth Common mode level Small Signal Differential Gain Output referred 1dB Compression Point THD High logic level Low logic level Bandwidth High logic level Low logic level Input current Rev. 0.0.2 TYP MAX UNIT COMMENTS General Parameters -3.4 -3.6 -3.8 V ±5.5% 0.0 V External ground 200 mA In Selector Mode 280 mA In Mixer/Adder Mode 700 mW In Selector Mode 1000 mW In Mixer/Adder Mode -25 50 125 °C Input Analog (d0p/d0n, d1p/d1n) DC 32 GHz -3dB mV AC-coupled vcc Single-ended, with unused input not 0 400 mV connected or AC terminated 0 800 mV Differential -35 dB at 3GHz -16 dB at 10GHz -11 dB at 20GHz -9 dB at 25GHz Current Control Signals (ief1c/ief3c) V vee vcc V at ±3.6V supply vee+1.9 Output Analog (qp/qn) DC 32 GHz -3dB With external 50Ohm vcc-0.55 V DC termination -1.5 0.0 +1.5 dB up to 25GHz 1 dBm 0.5 % 0.6 % 1.9 % 2.5 % Low-Speed Control (on2) V vcc V vee High-Speed Control (sel) 1 GHz V vcc V vee 20 uA 4 Single-Ended, 20GHz at 1GHz at 10GHz at 25GHz at 35GHz Mixer/Adder Mode 1-of-2 Selector Mode Input d1p/d1n is active Input d0p/d0n is active sink or source December 2019 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com PACKAGE INFORMATION The chip die is housed in a custom 24-pin CQFN package shown in Fig. 2. The package provides a center heat slug located on its back side to be used for heat dissipation. ADSANTEC recommends for this section to be soldered to the vcc plain, which is ground for a negative supply, or power for a positive supply. Fig. 2. CQFN 24-Pin Package Drawing (All Dimensions in mm) Rev. 0.0.2 5 December 2019 Advanced Science And Novel Technology Company, Inc. 2790 Skypark Dr., Ste #112, Torrance, CA 90505 Office: (310) 530-9400 Fax: (310) 530-9402 www.adsantec.com The part’s identification label is ASNT6163-KHC. The first 8 characters of the name before the dash identify the bare die including general circuit family, fabrication technology, specific circuit type, and part version while the 3 characters after the dash represent the package’s manufacturer, type, and pin out count. This device complies with the Restriction of Hazardous Substances (RoHS) per EU 2011/65/EU for all ten substances. REVISION HISTORY Revision 0.0.2 Rev. 0.0.2 Date 12-2019 Changes Preliminary release 6 December 2019
ASNT6163-KHC 价格&库存
很抱歉,暂时无法提供与“ASNT6163-KHC”相匹配的价格&库存,您可以联系我们找货
