U444-06N-V-C
U444-06N-V-C
    TRIPPLITE
    USB 3.1 GEN 1 USB-C TO VGA DISPL
U444-06N-V-C 数据手册
USB-C to VGA Adapter with PD Charging, White Highlights ● Supports USB DisplayPort Alternate Mode for transmitting video ● Supports HD video resolutions up to 1920 x 1200 (1080p) @ 60 Hz ● USB-C PD charging port supports power input up to 20V 3A (60W) ● Reversible USB-C plug connects in either direction ● Plug-and-play operation with no software or drivers required MODEL NUMBER: U444-06N-V-C System Requirements ● Source device with USB-C port that supports USB DisplayPort Alternate Mode ● Display device with VGA input (VGA port) Adds VGA and USB-C PD charging ports to the USB-C port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Package Includes Description The U444-06N-V-C USB 3.2 Gen 1 USB-C to VGA Adapter expands the potential of your tablet, laptop, Chromebook, MacBook, smartphone or PC’s USB-C port. It’s ideal for transmitting 1080p video to a large display and powering and charging a PD Charging-compliant mobile device—all at the same time. With a source device that also supports USB DisplayPort Alternate Mode, you can extend video from your primary display to another, duplicate the same video on both displays, or change the second display to your primary. The plug-and-play U444-06N-V-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. To send HD video to a VGA television, projector or monitor, connect the VGA port to the display using a VGA cable (sold separately). The VGA port supports HD video resolutions up to 1920 x 1080 (1080p) at 60 Hz. The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) the U444-06N-V-C is connected to. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). Features Turn Your Device’s USB-C Port into a Multiport WorkstationIdeal for transmitting video to a large display and powering and charging a PD Charging-compliant mobile device simultaneouslyPlug-and-play operation with no software, drivers or external power requiredSmaller than a credit card for easy carrying in a pocket, purse or laptop bag Transmit Crystal-Clear 1920x1080 (1080p) Video to VGA DisplayCompatible with USB-C source devices that support USB DisplayPort Alternate ModeSupports HD video resolutions up to 1920 x 1080 (1080p) @ 60 HzExtends video from your primary display to anotherDuplicates the same video on 2 displaysConverts a secondary display to your primary display Charge a Connected DeviceUSB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C deviceSupports power input up to 20V 3A (60W)Note: USB-C PD port does not support Quick Charge (QC). Built-In Cable with Reversible USB-C ConnectorFumble-free reversible USB-C plug connects in either direction for quick connection every time 1/4 ● U444-06N-V-C USB 3.2 Gen 1 USB-C to VGA Adapter ● Owner’s manual Specifications OVERVIEW UPC Code 037332193704 Technology VGA/SVGA VIDEO Video Input USB C (MALE) Video Output HD15 (FEMALE) Number of Monitors Supported 1 Video Ports HD15 (FEMALE) Supported Resolutions 1280x720 (720p); 1920x1080 (1080p) Max Supported Video Resolution VGA: 1920 X 1200 (1080p) @ 60HZ Extended Mode Yes Extended Mode Details Extend the desktop of the host computer to a VGA display at resolutions up to 1920 x 1080 (1080p) @ 60 Hz Mirror Mode Yes Mirror Mode Details Mirror the video output of the host computer on a VGA display at resolutions up to 1920 x 1080 (1080p) @ 60 Hz HDR Support No 3D Video Supported No EDID Support No DisplayPort Alt Mode Yes INPUT Built-In Cable Length (ft.) 0.36 Built-In Cable Length (m) 0.11 Built-In Cable Length (in.) 4.33 Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) No 2/4 POWER Power Consumption (Watts) 0.60 USB Power Delivery (PD) Charging Support Yes USB Power Delivery (PD) Charging Specification 2.0 CHARGING Number of Charging Ports 1 Total Charging Watts 60 Charging Port Type USB C (FEMALE) Charging Ports Details (x1) USB-C Port provides PD 2.0 charging up to 20V/3A (60W) to the host device Charging Ports USB-C: 60W (20V 3A) Power Delivery (PD 2.0) Charging Ports / Amps 3A PHYSICAL Color White Material of Construction PVC, ABS Cable Jacket Color White Cable Jacket Material PVC Cable Jacket Rating VW-1 Cable Outer Diameter (OD) 3.9mm Wire Gauge (AWG) 28+34 Shipping Dimensions (hwd / in.) 0.79 x 4.72 x 3.94 Shipping Dimensions (hwd / cm) 2.01 x 11.99 x 10.01 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.4 x 5.9 x 4.0 Unit Packaging Type Box Unit Weight (lbs.) 0.07 Unit Weight (kg) 0.03 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 158 F (-10 to 70 C) BTUs 2.1 BTU/Hr 3/4 Operating Humidity Range 10% to 85% RH, Non-Condensing Storage Humidity Range 5% to 90% RH, Non-Condensing Power Provided to Connected Device(s) Up to 20V 3A (60W) Input (USB-C) CONNECTIONS Number of Ports 2 Side A - Connector 1 USB C (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Displayport Specification 1.2 USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support Yes Remote Wakeup Support Yes Multi-Resolution Support Yes STANDARDS & COMPLIANCE Product Certifications EN 55024; EN 55032 Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
U444-06N-V-C 价格&库存
很抱歉,暂时无法提供与“U444-06N-V-C”相匹配的价格&库存,您可以联系我们找货
U444-06N-V-C
    • 1+142.04914
