HXY70P03D
HXY70P03D
    HXY(华轩阳)
    TO252
    类型:P沟道;漏源电压(Vdss):30V;连续漏极电流(Id):70A;导通电阻(RDS(on)@Vgs,Id):7.2mΩ@10V,20A;阈值电压(Vgs(th)@Id):2.5V@250uA;...
HXY70P03D 数据手册
HUAXUANYANG HXY70P03D HXY ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET Description The HXY70P03D uses advanced trench technology to provide excellent RDS(ON), low gate charge and D operation with gate voltages as low as 4.5V. This S device is suitable for use as a G Battery protection or in other Switching application. TO252-2L General Features D VDS = -30V ID =-70 A RDS(ON) < 10mΩ @ VGS=-10V G Application S Battery protection P-Channel MOSFET Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID HXY70P03D Pack Marking Qty(PCS) TO252-2L 70P03 XXX YYYY 2500 Absolute Maximum Ratings (TC=25℃ unless otherwise specified) Symbol Parameter Rating Units VDS Drain-Source Voltage -30 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current, VGS @ -10V1,6 -70 A ID@TC=100℃ -10V1,6 -50 A -200 A 80 mJ -40 A 90 W -55 to 175 ℃ -55 to 175 ℃ 20 ℃/W 50 ℃/W 1.6 ℃/W IDM EAS IAS PD@TC=25℃ Continuous Drain Current, VGS @ Pulsed Drain Current2 Single Pulse Avalanche Energy3 Avalanche Current Total Power Dissipation4 TSTG Storage Temperature Range TJ Operating Junction Temperature Range RθJA RθJC Thermal Resistance Junction-ambient Thermal Resistance Junction-ambient 1(t≦10S) 1(Steady Thermal Resistance Junction-case Shenzhen HuaXuanYang Electronics CO.,LTD 1 State) www.hxymos.com HUAXUANYANG HXY70P03D HXY ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol BVDSS Parameter Drain-Source Breakdown Voltage RDS(ON) Static Drain-Source On-Resistance2 VGS(th) Gate Threshold Voltage Conditions Min. Typ. Max. Unit VGS=0V , ID=-250uA -30 --- --- V VGS=-10V , ID=-20A --- 7 10 mΩ VGS=-4.5V , ID=-15A --- 11 18 mΩ VGS=VDS , ID =-250uA -1.2 --- -2.5 V VDS=-24V , VGS=0V , TJ=25℃ --- --- -1 VDS=-24V , VGS=0V , TJ=55℃ --- --- -5 IDSS Drain-Source Leakage Current IGSS Gate-Source Leakage Current VGS=±20V , VDS=0V --- --- ±100 nA Rg Gate Resistance VDS=0V , VGS=0V , f=1MHz --- 1.2 --- Ω Qg Total Gate Charge (-10V) --- 60 --- Qgs Gate-Source Charge --- 9 --- Qgd Gate-Drain Charge --- 15 --- Td(on) Turn-On Delay Time --- 17 --- --- 40 --- --- 55 --- --- 13 --- --- 3450 --- --- 255 --- --- 140 --- Tr Td(off) Tf Rise Time Turn-Off Delay Time Fall Time Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance VDS=-15V , VGS=-10V ID=-18A VDD=-15V VGS=-10V RG=3.3Ω, ID=-20A VDS=-25V , VGS=0V , f=1MHz uA nC ns pF Continuous Source Current1,5 VG=VD=0V , Force Current --- --- -70 A VSD Diode Forward Voltage2 VGS=0V , IS=-1A , TJ=25℃ --- --- -1.2 V trr Reverse Recovery Time IF=-20A , di/dt=100A/µs , --- 22 --- nS --- 72 --- nC IS Qrr Reverse Recovery Charge TJ=25℃ Note : 1.The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3.The EAS data shows Max. rating . The test condition is V DD=-50V,VGS=-10V,L=0.1mH,IAS=-40A 4.The power dissipation is limited by 150℃ junction temperature 5.The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation 6.The maximum current rating is package limited. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY ELECTRONICS CO.,LTD HXY70P03D P-Channel Enhancement Mode MOSFET Typical Characteristics Fig.1 Typical Output Characteristics Fig.2 On-Resistance vs. Gate-Source Voltage Fig.3 Forward Characteristics of Reverse Fig.4 Gate-Charge Characteristics Fig.5 Normalized -VGS(th) vs. TJ Fig.6 Normalized RDSON vs. TJ Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com HUAXUANYANG HXY70P03D HXY ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET Fig.7 Capacitance Fig.8 Safe Operating Area Normalized Thermal Response (RθJC) 1 DUTY=0.5 0.2 0.1 0.1 0.05 0.02 0.01 0.01 P DM SINGLE T ON T D = TON/T TJpeak = TC+P DMXRθJC 0.001 0.00001 0.0001 0.001 0.01 0.1 1 10 t , Pulse Width (s) Fig.9 Normalized Maximum Transient Thermal Impedance Fig.10 Switching Time Waveform Shenzhen HuaXuanYang Electronics CO.,LTD Fig.11 Unclamped Inductive Switching Waveform www.hxymos.com HUAXUANYANG HXY70P03D HXY ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET TO252-2L Package Information Symbol Dimensions In Millimeters Dimensions In Inches Min. Max. Min. Max. A 2.200 2.400 0.087 0.094 A1 0.000 0.127 0.000 0.005 b 0.660 0.860 0.026 0.034 c 0.460 0.580 0.018 0.023 D 6.500 6.700 0.256 0.264 D1 5.100 5.460 0.201 0.215 D2 4.830 TYP. 0.190 TYP. E 6.000 6.200 0.236 0.244 e 2.186 2.386 0.086 0.094 L 9.800 10.400 0.386 0.409 L1 L2 2.900 TYP. 1.400 L3 0.114 TYP. 1.700 0.055 1.600 TYP. 0.067 0.063 TYP. L4 0.600 1.000 0.024 0.039 Φ 1.100 1.300 0.043 0.051 θ 0° 8° 0° 8° h 0.000 0.300 0.000 0.012 V 5.350 TYP. Shenzhen HuaXuanYang Electronics CO.,LTD 0.211 TYP. www.hxymos.com HUAXUANYANG HXY70P03D HXY ELECTRONICS CO.,LTD P-Channel Enhancement Mode MOSFET Attention ■ Any and all HUA XUAN YANG ELECTRONICS products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your HUA XUAN YANG ELECTRONICS representative nearest you before using any HUA XUAN YANG ELECTRONICS products described or contained herein in such applications. ■ HUA XUAN YANG ELECTRONICS assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein. ■ Specifications of any and all HUA XUAN YANG ELECTRONICS products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. ■ HUA XUAN YANG ELECTRONICS CO.,LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. ■ In the event that any or all HUA XUAN YANG ELECTRONICS products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of HUA XUAN YANG ELECTRONICS CO.,LTD. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. HUA XUAN YANG ELECTRONICS believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. When designing equipment, refer to the "Delivery Specification" for the HUA XUAN YANG ELECTRONICS product that you intend to use. Shenzhen HuaXuanYang Electronics CO.,LTD www.hxymos.com
HXY70P03D 价格&库存
很抱歉,暂时无法提供与“HXY70P03D”相匹配的价格&库存,您可以联系我们找货
