1000 Eaton Boulevard
Cleveland, OH 44122
United States
SMART750XLA is not for sale in Colorado, Vermont and Washington state. Customers in these states
should purchase the recommended ENERGY STAR® 2.0 model instead: SU1000RTXLCD2U. Learn
more about ENERGY STAR 2.0 and sales restrictions in these states.
SmartPro 120V 750VA 500W Line-Interactive Sine
Wave UPS, Tower, Extended Run, Network Card
Options, USB, DB9 Serial
Highlights
750VA line interactive tower
UPS; Sine wave output
100/110/120V nominal output
during brownouts and
overvoltages
USB, RS232 and slot for
Network Management Card
options
Expandable runtime; Front
panel status LEDs; Single line
TEL/DSL suppression
NEMA 5-15P input; 8 NEMA 515R outlets
MODEL NUMBER: SMART750XLA
Package Includes
Description
750VA line-interactive tower UPS system for server, networking and telecommunications equipment.
Supports extended runtime with optional BP24V28-2U and BP24V70-3U external battery packs.
Compatible with 120V, 110V or 100V nominal voltage at 60Hz. Switches to battery-derived AC output
during power failures and extreme voltage variations. Line-interactive automatic voltage regulation (AVR)
provides voltage boost during brownouts and voltage cut during overvoltages to maintain regulated output
during brownouts and overvoltages. Includes NEMA 5-15P input plug and 8 NEMA 5-15R output
receptacles. Network-grade AC surge and noise suppression. Network management via USB port, DB9
serial port and slot for Network Management Card option. HID-compliant USB interface enables
integration with built-in power management and auto shutdown features of Windows and Mac OS X.
Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3
network interfaces at once. PowerAlert UPS monitoring software is available via free download. Features
3-stage load current monitoring and battery charge status, plus line power and voltage boost/cut status
LEDs. Dataline surge suppression protects dialup, DSL or network Ethernet connection. Audible alarm.
Self-test. Field replaceable, hot-swappable internal batteries and external battery packs. Attractive allblack color scheme.
Features
SmartPro line-interactive UPS system is ideal for voice, data, medical and industrial networking
applications
Large internal batteries offer 20.7 minutes at half load (375VA/250W) and 10 minutes at full load
(750VA/500w)
Runtime is expandable with optional BP24V28-2U (limit 1) and BP24V70-3U (no limit) external battery
packs
1/5
SMART 750XLa UPS System
USB and serial cabling
User manual with warranty
information
Cleveland, OH 44122
United States
Some external battery configurations require the use of Tripp Lite's External Battery Configuration
Software (see manual)
Intelligent battery management system extends battery life
Line-interactive automatic voltage regulation (AVR) maintains selectable 120V, 110V or 100V nominal
output during brownouts as low as 83V and overvoltages to 145V
Network interfaces support simultaneous communications via built-in USB port, DB9 serial port and slot
Compatible with Tripp Lite UPS management card options WEBCARDLX and SNMPWEBCARD
HID-compliant USB interface enables integration with built-in power management and auto shutdown
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
NEMA 5-15P input plug; 8 battery-supported NEMA 5-15R output receptacles
Front panel LEDs offer current monitoring, voltage regulation and battery charge level information
UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of
internal batteries by user required
Specifications
OVERVIEW
UPC Code
037332142948
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
5.4A (120V),5.8A (110V), 6.4A (100V)
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
120V 15A
Voltage Compatibility (VAC)
120
OUTPUT
Output Capacity (VA)
750
Output Capacity (kVA)
0.75
Output Capacity (Watts)
500
Output Capacity (kW)
0.5
Nominal Voltage Details
120V default
Frequency Compatibility
60 Hz
2/5
Cleveland, OH 44122
United States
Output Voltage Regulation (Line
Mode)
-13%, + 15%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
10
Runtime Half Load (min.)
20.7
Expandable Runtime
Yes
External Battery Pack Compatibility
BP24V15RT2U (limit 1); BP24V28-2U (limit 1); BP24V70-3U (multi-pack
compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Supports battery access and hot-swap replacement without powering connected equipment off
Internal UPS Replacement Battery
Cartridge
RBC24-SLT
VOLTAGE REGULATION
Voltage Regulation Description
Automatic Voltage Regulation (AVR) circuits maintain clean, regulated computer-grade 120, 110, 100V nominal
output, without using battery power, during brownouts 95V (120V), 87V (110V), 83V (100V)
Overvoltage Correction
Input voltages between 127 and 145V (120V), 116 and 133 (110V), 111 and 121 (100V) are reduced by 12%;
Voltage setpoints ±5% tolerance
Undervoltage Correction
Voltage boost of 14% applies when input is 95 to 108 (120v), 87 to 99 (110v), 83 to 90 (100v); Voltage setpoints
±5% tolerance
USER INTERFACE, ALERTS & CONTROLS
Switches
Includes two pushbutton switches for on/off power control and self-test/ alarm cancel functions. Also includes two
dipswitch controls for setting the nominal voltage
Audible Alarm
Audible alarm warns of power failure condition
LED Indicators
9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for
load and battery charge level
3/5
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
Dataline Suppression
Includes 8-wire RJ45 jack; pins 1, 2, 3 and 6 provide 10baseT Ethernet line surge suppression with 7.5V clamping;
pins 4 and 5 provide single-line tel/DSL line surge suppression starting at 260V
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
351
Primary UPS Height (mm)
257
Primary UPS Width (mm)
170
Shipping Dimensions (hwd / in.)
14.00 x 9.60 x 17.80
Shipping Dimensions (hwd / cm)
35.56 x 24.38 x 45.21
Shipping Weight (lbs.)
38.40
Shipping Weight (kg)
17.42
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
25.65 x 17.02 x 35.05
(hwd, in.)
10.1 x 6.7 x 13.8
UPS Power Module Weight (kg)
15.38
UPS Power Module Weight (lbs.)
33.9
Unit Dimensions (hwd / in.)
10.090 x 6.660 x 13.760
Unit Weight (lbs.)
33.9000
Unit Weight (kg)
15.38
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
71
AC Mode Efficiency Rating (100%
Load)
96%
Audible Noise
Audible Noise < 50 dBA at Front Side 1 Meter
4/5
Cleveland, OH 44122
United States
COMMUNICATIONS
Network Management Cards
WEBCARDLX ; TLNETCARD ;
SNMPWEBCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
WatchDog Compatibility
Compatible with Tripp Lite's WatchDog Software to restore operation to locked equipment through soft reboot of
application/OS or hard power off/on reboot of connected equipment; ideal for unattended kiosk applications
Description
Network management card optional
Communications Interface
DB9 Serial; Slot for SNMP/Web interface; USB
LINE / BATTERY TRANSFER
Transfer Time
4-8 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
95V (120V), 87V (110V), 83V (100V); Voltage setpoints ±5% tolerance
High Voltage Transfer to Battery
Power (Setpoint)
145V (120V), 133V (110V), 121V (100V); Voltage setpoints ±5% tolerance
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Optional Coverage
3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp
Lite for additional information
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
