SS32 THRU SS310
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Forward Current - 3.0 Amperes
Reverse Voltage - 20 to 100 Volts
DO-214AC(SMA)
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
0.110(2.80)
0.100(2.54)
0.071 (1.80)
0.055 (1.40)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
MECHANICAL DATA
0.096(2.42)
0.078(1.98)
Case : JEDEC DO-214AC molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.007 ounce, 0.25grams
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
0.222(5.66)
0.194(4.93)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS
SS32
SS33
SS34
SS35
SS36
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
SS38 SS310
80
56
80
100
70
100
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
3.0
Amps
IFSM
100.0
Amps
VF
0.55
IR
CJ
RθJA
TJ,
TSTG
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
1
0.70
0.85
0.5
10
300
55.0
-65 to +125
-65 to +150
-65 to +150
Volts
mA
pF
C/W
C
C
SS32 THRU SS310
FIG. 1- FORWARD CURRENT DERATING CURVE
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES SS32 THRU SS310
3.0
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
SS32-SS36
SS38-SS310
0.6
50
75
100
125
150
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
80
60
40
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
50
CURRENT,AMPERES
TJ=25 C
10.0
1
SS32-SS34
SS35-SS36
SS38-SS310
0.1
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.01
0.4
0.6
0.8
1.0
1.2
1.4
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
60
80
2000
TJ=25 C
100
SS32-SS34
SS35-SS310
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
10
0.1
1.0
10
100
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
1000
100
NUMBER OF CYCLES AT 60 Hz
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
2
100
很抱歉,暂时无法提供与“SS36/SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36800
- 50+0.34040
- 200+0.31740
- 600+0.29440
- 1500+0.27600
- 3000+0.26450
