74LV244
Octal buffer/line driver; 3-state
Rev. 4 — 1 March 2016
Product data sheet
1. General description
The 74LV244 is a low-voltage Si-gate CMOS device and is pin and function compatible
with 74HC244 and 74HCT244.
The 74LV244 is an octal non-inverting buffer/line driver with 3-state outputs. The output
enable inputs 1OE and 2OE control the 3-state outputs. A HIGH on nOE causes the
outputs to assume a high impedance OFF-state. The 74LV244 is identical to the 74LV240
but has non-inverting outputs.
2. Features and benefits
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical VOLP (output ground bounce) < 0.8 V at VCC = 3.3 V; Tamb = 25 C
Typical VOHV (output VOH undershoot) > 2 V at VCC = 3.3 V; Tamb = 25 C
Complies with JEDEC standard no. 7A
Multiple package options
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV244D
40 C to +125 C
SO20
plastic small outline package; 20 leads; body width 7.5 mm SOT163-1
74LV244DB
40 C to +125 C
SSOP20
plastic shrink small outline package; 20 leads;
body width 5.3 mm
74LV244PW
40 C to +125 C
TSSOP20 plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT339-1
SOT360-1
74LV244
Nexperia
4. Block diagram
很抱歉,暂时无法提供与“74LV244D,112”相匹配的价格&库存,您可以联系我们找货
