MMBT3906
NP General Purpose Transistor
FEATURES
Epitaxial planar die construction.
Complementary NPN type available
(MMBT3904).
Collector Current Capability ICM =-200mA.
Low Voltage(Max:-40V).
2A
JS
APPLICATIONS
Ideal for medium power amplification and switching.
SOT-23
O
CR
MI
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
PARAMETER
collector-emitter voltage
VEBO
emitter-base voltage
IC
collector current (DC)
ICM
peak collector current
IBM
peak base current
Ptot
total power dissipation
Tstg
Tj
UNIT
open emitter
-40
V
open base
-40
V
-6
V
open collector
uc
nd
VCEO
Value
co
collector-base voltage
CONDITIONS
mi
VCBO
Se
SYMBOL
mA
250
mW
storage temperature
-65 to +150
°C
junction temperature
150
-200
mA
-100
mA
r
to
Tamb≤25°C
-200
°C
Note Transistor mounted on an FR4 printed-circuit board.
www.jsmsemi.com
第1/5页
MMBT3906
ELECTRICAL CHARACTERISTICS @ Ta=25℃
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
ICBO
collector cut-off current
IE = 0; VCB = -30 V
-50
nA
IEBO
emitter cut-off current
IC = 0; VEB =- 6 V
-50
nA
DC current gain
VCE = -1V;
IC= -0.1mA
IC = -1mA
IC = -10mA
IC = -50mA
IC = -100mA
60
80
100
60
30
300
hFE
JS
collector-emitter saturation
voltage
IC = -10mA; IB = -1mA
-200
mV
IC = -50mA; IB = -5mA
-300
mV
VBEsat
base-emitter saturation
voltage
-850
mV
-950
mV
CR
MI
VCEsat
collector capacitance
IE = Ie= 0; VCB = -5 V;
f = 1 MHz
4.5
pF
Ce
emitter capacitance
IC = Ic= 0; VEB = -500 mV;
f = 1 MHz
10
pF
fT
transition frequency
IC = -10mA; VCE = -20 V;
f = 100MHz
250
MHz
4
dB
65
ns
35
ns
35
ns
300
ns
225
ns
75
mi
Se
IC = -100μA; VCE = -5V;
RS = 1 kΩ;f = 10Hz to15.7 kHz
noise figure
co
NF
O
Cc
Switching times (between 10% and 90% levels);
td
delay time
tr
rise time
toff
turn-off time
ts
storage time
tr
fall time
Pulse test: tp≤300 ms; d≤0.02.
www.jsmsemi.com
ns
r
Note
ICon= -10mA; IBon = -1mA;
IBoff= -1mA
to
Turn-on time
uc
nd
ton
第2/5页
MMBT3906
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
O
CR
MI
JS
r
to
uc
nd
co
mi
Se
www.jsmsemi.com
第3/5页
MMBT3906
O
CR
MI
JS
mi
Se
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
co
A
uc
nd
E
K
SOT-23
B
Min
Max
A
2.70
3.10
B
1.10
1.50
C
0.90
1.10
0.30
0.50
0.35
0.48
D
G
H
C
E
r
J
D
to
Dim
G
1.80
2.00
H
0.02
0.10
J
0.05
0.15
K
2.20
2.60
All Dimensions in mm
www.jsmsemi.com
第4/5页
MMBT3906
SOLDERING FOOTPRINT
0.95
0.95
2.00
JS
0.90
MI
Unit : mm
0.80
O
CR
PACKAGE
INFORMATION
Package
Shipping
MMBT3906
SOT-23
3000pcs / Tape & Reel
r
to
uc
nd
co
mi
Se
Device
www.jsmsemi.com
第5/5页
很抱歉,暂时无法提供与“MMBT3906”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.04500
- 100+0.04200
- 300+0.03900
- 500+0.03600
- 2000+0.03450
- 5000+0.03360
