Approval sheet
Metal Stamping Antenna
2.4 ~ 2.5 GHz Working Frequency
P/N: RFMTA271200NNAB001
Customer:
Customer ‘s Part No.:
Approval No.:
Issue Date:
Page 1 of 10
RFMTA271200NNAB001_V01
Aug. 2015
Approval sheet
Version
V01
Page 2 of 10
Date
2015
Aug.
Description
New Release
Author
HWCHAN
Aug. 2015
Approval sheet
Antenna Specification
ELECTRICAL CHARACTERISTICS
Item
Specification
Working Frequency Range
2.4 ~2.5 GHz
Return Loss
-10dB(Max)
VSWR
2 max.
Peak Gain
3.38 dBi
Polarization
Linear Vertical
Radiation Pattern
Directional
Impedance
50
*Note 1. Central Frequency should be defined after customers’ application approval.
MATERIAL TABLE
Items
Description
SUS430 鍍鎳 T=0.4mm
Antenna Material
ORDERING RULE
RF
MTA
Product
Code
Type Code
2712
00
N
Metal
Cable
Connector
Dimension Length (unit:
Brand
(Unit: mm)
cm)
N
Type of
Connector
Walsin RF
Device
MTA:
Metal
Antenna
01
Application
Project
A: 2.4GHz
D:IPEX III
ISM band
E: IPEX IV
U:MURATA
N: None
Page 3 of 10
Wire
Diameter
C:MCX
A: Reverse
Female
F: IPEX A13 B:
cable length
Reverse
H: Hirose
e.g.: 2712
Male
I: IPEX
Length
e.g.: 00
F: Female
M: MMCX
27.7mm,
None Cable
M: Male
S: SMA
Width12.8mm
N: None
T: TNC
length, width 2 digits for
B
Project
status
0: 0GHz
3: 3GHz
5: 5 GHz
6: 6GHz
A: N
Per 2 digits of
A
B: GSM
900/1800
B: MP
dual band T:During
G: GPS band Test
L: 2.4/5.2/5.8 X: Pile Run
GHz
0:None
1:∅0.81
3:∅1.13
01~99 series
6:RG316
7:∅1.37
number
8:RG178
tri-band
N: NFC
T:LTE
band
W:
WCDMA
band
Aug. 2015
Approval sheet
DIMENSIONS
Page 4 of 10
Aug. 2015
Approval sheet
Test Report
■ PCB Layout
Page 5 of 10
Aug. 2015
Approval sheet
■ ELECTRICAL CHARACTERISTICS
Return Loss
Page 6 of 10
Aug. 2015
Approval sheet
■ Antenna Efficiency and Peak Gain
Page 7 of 10
Aug. 2015
Approval sheet
■RADIATION PATTERN
2400~2500 MHz
X-Z Plane
Phi=0.00deg
Gain . dB
Page 8 of 10
Aug. 2015
Approval sheet
Y-Z Plane
Phi=90.00deg
Gain . dB
Page 9 of 10
Aug. 2015
Approval sheet
X-Y Plane
Theta=90.00deg
Gain . dB
Page 10 of 10
Aug. 2015
很抱歉,暂时无法提供与“RFMTA271200NNAB001”相匹配的价格&库存,您可以联系我们找货
