684M3W3103L461
684M3W3103L461
    NORCOMP
    弯插
    CONN D-SUB PLUG 3POS R/A SOLDER
684M3W3103L461 数据手册
DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED ELECTRICAL: INSULATOR RESISTANCE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER CONTACT AMPERAGE: 5 GΩ MIN. 250V -55°C TO +125°C 1.0 mΩ MAX. SEE P/N KEY 1.543 [39.20] MECHANICAL: 4.5 Kg MAX. CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 0.3 Kg MIN. 1.311 [33.30] 0.994 [25.25] MATERIALS: CONTACTS: INSULATOR: PBT UL94V-0 RATED SHELL: BRACKET: BOARD LOCK: NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS COPPER ALLOY, GOLD FLASH 230°C PROCESS TEMP. A1 A2 A3 0.492 [12.50] 0.327 [8.30] 10° 0.240 [6.10] 0.031 [0.80] 684M3W3103LYYY 00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DRAWN: P. JENKINS DATE: 08/22/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M3W3103L461 6 DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED RIGHT ANGLE BRACKET DIMENSIONS(in/mm) OPTION #4-40 INSERT 46 1.311 62 0.270 0.270 A1 0.520 A2 Ø 0.130 2-PLACES P 0.185 4.70 0.087 2.22 0.420 [10.67] A3 POWER CONTACTS Ø 0.165 3-PLACES 0.420 PCB EDGE Ø 0.148 [Ø 3.75] P 0.520 [13.20] RoHS COMPLIANT THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: P. JENKINS DATE: 08/22/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M3W3103L461 6
684M3W3103L461 价格&库存
很抱歉,暂时无法提供与“684M3W3103L461”相匹配的价格&库存,您可以联系我们找货
684M3W3103L461
    684M3W3103L461
      • 1+82.20683
      • 18+80.40524
      • 35+78.68696
      库存:5
      684M3W3103L461
        库存:490
