DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED
5 GΩ MIN.
250V
-55°C TO +125°C
1.0 mΩ MAX.
SEE P/N KEY
2.089 [53.05]
1.852 [47.05]
4.5 Kg MAX.
0.3 Kg MIN.
1.533 [38.95]
0.492 [12.50]
A1
A2
A3
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
230°C PROCESS TEMP.
A5
A4
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
0.327 [8.30]
10°
0.240
[6.10]
0.031 [0.80]
684M5W5103LYYY
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
P. JENKINS
DATE:
08/22/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
684M5W5103L461
3
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
1.852
OPTION
#4-40 INSERT
CL
P
0.185
46
0.570
4.70
0.570
0.087
62
2.22
0.030
0.330
[8.38]
0.520 [13.20]
0.420 [10.67]
Ø 0.130
[3.30]
2-PLACES
0.270
[6.86]
0.420 [10.67]
Ø 0.165
[4.20]
5-PLACES
0.270
[6.86]
POWER CONTACTS
PCB EDGE
Ø 0.148 [Ø 3.75]
P
0.520 [13.20]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
P. JENKINS
DATE:
08/22/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
684M5W5103L461
3
