DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67
ELECTRICAL:
INSULATOR RESISTANCE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
POWER CONTACT AMPERAGE:
5 GΩ MIN.
250V
-55°C TO +125°C
1.0 mΩ MAX.
SEE P/N KEY
1.543 [39.20]
MECHANICAL:
4.5 Kg MAX.
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE: 0.3 Kg MIN.
1.311 [33.30]
0.994 [25.25]
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SHELL:
BRACKET:
BOARD LOCK:
SEAL:
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
F08 FLEXIBLE ADHESIVE
230°C PROCESS TEMP.
A1
A2
A3
0.492 [12.50]
0.327 [8.30]
10°
MEETS IP67 STANDARDS
(SEE PAGE 3 FOR SEALING DETAILS)
0.240 [6.10]
0.031 [0.80]
684S3W3103LYYY
00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
04/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
684S3W3103L461
3
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
OPTION
#4-40 INSERT
P
0.185
46
4.70
0.087
1.311
62
2.22
0.270
0.270
A1
0.520
A2
Ø 0.130
2-PLACES
0.420 [10.67]
A3
POWER CONTACTS
Ø 0.165
3-PLACES
0.420
PCB EDGE
Ø 0.148 [Ø 3.75]
P
0.520 [13.20]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
04/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
684S3W3103L461
3
A
A
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
DETAIL A-A
SHOWN FOR REFERENCE ONLY
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
04/22/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
684S3W3103L461
3
很抱歉,暂时无法提供与“684S3W3103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+138.83728
- 18+135.76520
- 35+131.69339
