PRODUCT SPECIFICATION SHEET
Customer
Customer P/N
TBA
Product Type
Temperature Compensated Crystal Oscillator
Part Number
9T19200001-Q
Part Description
Nominal Frequency
S1
SMD TCXO 2.0 x 1.6
19.200000MHz
Prepared
Han Shuang
Reviewed
Kuro Peng
Approved
Jay Lee
Date
Version
Customer's Approval & Date:
2021-12-6
廣東惠倫晶體科技股份有限公司
中 国 广 东 省 东 莞 市 黄 江 镇 东 环 路 鸡 啼 岗 段 68 号
68 Donghuan Road, Jitigang Village, Huangjiang,
Dongguan, Guangdong Province, P. R. China
WEB : http://www.dgylec.com/
TEL : +86 ( 0 ) 769 - 38879888
FAX : +86 ( 0 ) 769 - 38879889
EMAIL : yl@dgylec.com
FAITH LONG CRYSTAL Proprietary and Confidential Information
Pb
RoHS
COMPLIANT
Lead-Free
Moisture Sensitivity Level 1
Page 1 of 6
SMD TCXO 2.0 x 1.6
PN: 9T19200001-Q
Ver.
S1
CONTENTS
Item
1
History of Specification Revision
3
2
Electrical Specifications
4
3
4
Page
2.1 Operation conditions
4
2.2 Output characteristics
4
2.3 Frequency characteristics
4
2.4 Phase noise characteristics
4
Product Design
5
3.1 Package dimensions and pad functions
5
3.2 Recommended land pattern
5
3.3 Recommended reflow profile
5
Testing Circuit
6
Page 2 of 6
SMD TCXO 2.0 x 1.6
PN: 9T19200001-Q
Ver.
S1
1. History of Specification Revision
Ver.
Contents
Date
Reviser
S0
Initial release
2020-6-19
Han Shuang
S1
Update normal temperature frequency
difference
2021-12-6
Han Shuang
Remark
Page 3 of 6
SMD TCXO 2.0 x 1.6
PN: 9T19200001-Q
Ver.
S1
2. Electrical Specifications
Parameters
1
Nominal frequency
Supply voltage (VCC)
2
3
Current consumption
4
Operating temperature range
5
Storage temperature range
Parameters
1
Output type
2
3
4
5
Standard output Load
Output level
Duty cycle
Harmonics
6
7
3
Max.
1.7
-30
-40
Typ.
19.200000
2.8
Remark
3.3
2.0
+85
+85
Unit
MHz
V
mA
°C
°C
Min.
Typ.
Max.
Unit
Remark
Decoupling capacitor is
required in external
circuit
Clipped sine wave
10 KΩ//10 pF
0.8
40
50
60
-5
Vpp
dBc
Start-up time vs. frequency
2.0
ms
Within ±0.5 ppm of final
frequency
Start-up time vs. output level
2.0
ms
Reach 90% of final Vpp
output level
Min.
Typ.
19.200000
Max.
Unit
MHz
Parameters
1
Nominal frequency
2
Min.
Frequency tolerance
Frequency stability vs. temperature
-2.0
-2.0
+2.0
+2.0
Min.
Typ.
-130
-152
Max.
Remark
ppm
At 25±2°C, after 2 times
of reflow, refer to
nominal frequency
(See below NOTE 1)
ppm
Refer to frequency at 25°
C within operating
temperature range
4
Frequency stability vs. supply voltage
-0.1
+0.1
ppm
5
Frequency stability vs. load variation
-0.1
+0.1
ppm
6
Aging over 1st year
-1.0
+1.0
ppm/yr
NOTE 1: After reflow, please leave DUT for more than 24 hours at room temperature.
Parameters
1
Phase noise at 1kHz offset
2
Phase noise at 100kHz offset
Ground level
Unit
dBc/Hz
dBc/Hz
±5% VCC variation
±5% load variation
At room temperature
Remark
Page 4 of 6
PN: 9T19200001-Q
SMD TCXO 2.0 x 1.6
Ver.
S1
3. Product Design
Top view
Bottom view
Unit : mm
2.00±0.15
0.22
0.425
Pad 4
Pad 3
Pad 3
Pad 4
0.425
0.625
YL xxx
1.60±0.15
0.40
0.625
Pad 1
Pad 2
Pad 2
0.15
Pad 1 index
Pad 1
1.20
Pad
Lateral view
0.8 Max.
Function
Symbol
1
NC or GND
(Ground recommended)
NC
2
3
4
Ground
Output
Supply voltage
GND
OUT
VCC
0.60
0.60
0.80
0.40
0.80
1.20
Unit : mm
10 sec. Max.
Temp.
260 5
(1) Total time : 360 sec. Max.
(2) Solder melting point : 225℃
220
60 sec. Max.
180
150
120 sec. Max.
Time (sec.)
Page 5 of 6
PN: 9T19200001-Q
SMD TCXO 2.0 x 1.6
Ver.
S1
4. Testing Circuit
C3
A
VCC
4
VCC
Power
Supply
_
V
OUT
TCXO
C1
Output
3
RL
CL
GND
(or NC) GND
1
2
GND
External Components:
Parts
Function
AC noise bypass for VCC
C1
C3
DC block for output
RL
Load resistance
CL
Load capacitance
Recommended
10nF
10nF
10KΩ
10pF
Page 6 of 6
很抱歉,暂时无法提供与“9T19200001-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.16000
- 30+2.08800
- 100+1.94400
- 500+1.80000
- 1000+1.72800
