No. 68 Huangjiang Donghuan Road, Huangjiang Town, Dongguan City, Guangdong Province, China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
SMD TSX 2.52.0
NOMINAL FREQ.
19.200000 MHz
FL P/N
2Z19200001-Q
REVISION
S1
CUSTOMER P/N
CUSTOMER'S APPROVAL & DATE
FL CORPORATION
APPROVED
CHECKED
DESIGNED
Jay Lee
Kuro Peng
Chen XuanRu
MSL 1
RoHS Compliant
FL P/N
REV.
CONTENTS
2Z19200001-Q
S1
PAGE
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3 to 4
‧ CONNECTION DIAGRAM, DIMENSIONS & MARKING
5
‧ MARKING
6
‧ SUGGESTED REFLOW PROFILE
6
‧ STRUCTURE ILLUSTRATION
7
‧ RELIABILITY TEST SPECIFICATIONS
8
‧ PACKING
9 to 10
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
11
ATTACHMENT (optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
1/11
FL P/N
REV.
2Z19200001-Q
S1
PAGE
2/11
Rev.
Revise Page
S0
N/A
S1
P.6
Revise Contents
Date
Ref. No.
Reviser
Initial released.
1-Jul-20
N/A
Chen XuanRu
Change MARKING
1-Dec-21
N/A
May Zhang
FL P/N
REV.
2Z19200001-Q
S1
PAGE
PRODUCT DESCRIPION
Standard atmospheric conditions
Unless otherwise specified, the standard range of atmospheric conditions for making measurement and tests are as
follow:
30±10°C
Ambient temperature :
40% to 70%
Relative humidity :
If there is no doubt the results, measurement shall be made within the following limits:
30±3℃
40% to 70%
Relative humidity :
Measure equipment
Electrical characteristics are measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode).
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
Parameters
Nominal frequency
Oscillation mode
Load capacitance
Frequency tolerance
Tolerance over temperature
(reference 30°C)
Aging
Frequency drift after reflow
Operating temperature
Storage temperature
Equivalent series resistance
Quality factor
Spurious mode series
resistance
Insulation resistance
Drive level
Shunt Capaitance
Motional Capacitance
First-order curve fitting
parameter
Symbol
FL
CL
Electrical Spec.
19.200000
AT-cut Fundamental
7
-10
+10
Units
MHz
NA
pF
ppm
(Note 1)
At 30±3°C
-12
+12
ppm
at -30~+85℃(Note 2)
ESR
Q
-0.7
-2
-30
-40
75000
+0.7
+2
+105
+105
70
ppm/year
ppm
°C
°C
W
1100
W
IR
DL
C0
C1
500
10
0.3
1.8
100
1.3
3.1
MW
mW
pF
fF
-0.4
-0.1
ppm/°C
18
Second-order curve fitting
parameter
-4.5
19
Third-order curve fitting
parameter
8.5
10
11.5
10-4
ppm/°C2
10-5
ppm/°C3
Notes
after two reflows
(Note 3)
±1MHz
At DC 100V
(Note 4)
(Note 4)
(Note 4)
3/11
FL P/N
REV.
2Z19200001-Q
S1
PAGE
4/11
ELECTRICAL SPECIFICATIONS (CONT.)
22
23
24
25
26
Parameters
Residual frequency stability
slope
5°C small orbit hysteresis 1
5°C small orbit hysteresis 2
DLD Freq. (Max-Min)
DLD Freq. (Repeatability)
DLD ESR (Max-Min)
DLD ESR (Repeatability)
Symbol
Electrical Spec.
Units
ppb/℃
(Note 5)
ppb/℃
ppb pk-pk
ppm
ppm
(Note 6)
(Note 7)
(Note 8)
(Note 8)
(Note 8)
(Note 8)
-50
+50
-50
+50
100 (magnitude)
3.0
0.7
Notes
Note 1
Note 2
Note 3
Note 4
The load capacitance is measured according to IEC Standard #60444-7.
Above 85°C tolerance over temperature bound by third-order coefficient range.
Minimum Q value calculated from ESR and L is smaller than this specification.
The curve fitting parameter is obtained from the Qualcomm crystal curve fitting algorithm, t0=30 °C
(Refer to Curve Fitting Calculation Table: 80-V9690-23)
Note 5 Condition 1A – Test condition (continuous temperature rate change of ~1.0°C/min):
- Measure FT points every 1°C, heating up from -30 to +85°C, subtract a fifth-order polynomial best fit and
then calculate the slope of the residual.
- The residual slope should be within ±50 ppb/°C.
Note 6 Condition 1B – Hysteresis 1 test condition (continuous temperature rate change of ~1.0°C/min):
- Measure FT points every 0.5°C while cycling temperature over a 5°C small temperature orbit;an example
5°C small orbit temperature cycle is +30°C to +35°C to +30°C.
- During every individual heating/cooling cycle there should be 11 points; discard the first point of each
heating and cooling cycle; this leaves 10 points for the fifth-order polynomial best fit from 1A for each of
the 10 points, and then calculate the slope each heating and cooling cycle. Subtract of the residual for
each of these heating and cooling 10 point curves.
Note 7 Hysteresis 2 test condition (continuous temperature rate change of ~1.0°C/min):
- Measure FT points every 0.5°C while cycling temperature over a 5°C small temperature orbit; an
example 5°C small orbit temperature cycle is +30°C to +35°C to +30°C.
- During every individual heating/cooling cycle there should be 11 points; discard the first and last point
of each heating and cooling cycle, which results in 9 temperature points. Calculate the average measured
peak-to-peak frequency difference for these 9 temperature points.
- The average difference is the magnitude of the small orbit hysteresis 2.
Note 8 0.01 uW to 100 uW to 0.01 uW, number of points: 15 points up and 15 points down = 29 total data points.
Note 9 This crystal specification complies to Qualcomm Mini-Specification 80-V9690-24 Rev. D.
NTC THERMISTOR SPECIFICATIONS TABLE
1
2
3
4
5
Parameters
Operating Temperature
Storage Temperature
Resistance
B-constant
Tolerance
Symbol
Electrical Spec.
-30
+105
-40
+105
100
4250
1
Units
°C
°C
kW
K
Notes
At 25°C
At 25°C - 50°C
FL P/N
REV.
2Z19200001-Q
S1
CONNECTION DIAGRAM
DIMENSIONS
(Unit : mm)
Unit : mm
Pad
#1
#2
#3
#4
Function
Xtal terminal (Input)
Thermistor + GND terminal
Xtal terminal (Output)
Thermistor terminal
SUGGESTED LAYOUT
PAGE
5/11
FL P/N
REV.
2Z19200001-Q
S1
MARKING
Frequency
EX: 19.200MHz = 192
YL
lot (2 digits)
year month
Administrative Symbo
2017
2018
2019
2020
2021
2022
2023
2024
Total time : 360 sec. Max.
Solder melting point :225 oC
Temp. (℃)
10 sec. Max.
260 5
220
60 sec. Max.
180
150
120 sec. Max.
Time (sec.)
PAGE
6/11
FL P/N
REV.
2Z19200001-Q
S1
PAGE
7/11
COMPONENTS
MATERIALS
QTY
1
Cap (Lid)
Kovar (Fe+Co+Ni)
1
2
Base (Package)
Alumina Ceramics (Al2O3)
+ Kovar (Fe+Co+Ni)
1
3
Pad (Package)
Ni + Au
4
4
Crystal Blank
SiO2
1
5
Electrode
Cr + Nobel material
2
6
Conductive Adhesive
Ag
2
7
Thermistor
Alumina Ceramics (Al2O3),
Ni + Ag+ Sn
1
8
Solder
Sn + Ag + Cu
2
FINISH/SPECIFICATIONS
Ni plating
Silicone resin
FL P/N
REV.
2Z19200001-Q
S1
PAGE
8/11
RELIABILITY SPECIFICATIONS
1. MECHANICAL ENDURANCE
Test Item
No.
1 Drop test
2 Shock test
3 Mechanical shock
4 Vibration
5 Gross leak
6 Fine leak
7 Solderability
8
Resistance to soldering
heat
Test Methods
150 cm height, fall freely onto stainless plate 3 times.
150g/150cm height, 3times in the direction of ±x, ±y, ±z on concrete
floor.
Device are shocked to half sine wave (1000 G) three mutually
perpendicular axes each 3 times. 1.0ms duration time.
Frequency range
Amplitude
Perpendicular axes each test time
10 to 55 Hz
1.52 mm
2 hours (x, y, z axis)
Total test time 6 hours
Standard sample for automatic gross leak detector. Test pressure
2kg/cm2.
Helium bombing 4.5kgf/cm2 for 2 hours.
Temperature
215°C ± 5°C
Immersing depth
0.5 mm minimum
Immersion time
10 ± 0.5 seconds
Flux
Rosin resin methyl alcohol
solvent ( 1 : 4 )
Pre-heat temperature
125°C
Pre-heat time
60 to 120 sec.
Test temperature
260 ± 5°C
Test time
5 ± 1 sec.
JIS C6701
IEC-68-02-27
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
MIL-STD-202F
2. ENVIRONMENTAL ENDURANCE
Test Item
No.
High
Temp.
storage
9
10 Low Temp. storage
Test Methods
+ 125°C ± 3°C for 500 ± 12 hours
- 40°C ± 3°C for 500 ± 12 hours
Total 100 cycles of the following temperature cycle
MIL-STD-883E
1 cycle
11 Thermal shock
125+/- 3 oC
MIL-STD-883E
25 oC
-55+/- 3
o
C
30 min.
30 min.
10 min. max.
12 High Temp. & humidity
85°C±3℃, RH 85%, 500 hours
JIS C5023
FL P/N
REV.
2Z19200001-Q
S1
PAGE
9/11
PACKING : (EIA-481-2)
Direction of feed
Index Mark
Direction of products
Dimension
PKG Type
A0
B0
2.25±0.1
2.70±0.1
2520 TSX (8mm)
P1
P2
4±0.1
2±0.1
Standard Reel Quantity is 3,000 pcs per reel.
THE INSPECTION FOR TAPE TENSION
REMARK : NA
K0
1.45±0.10
D1
1±0.1
Unit : mm
T
0.25±0.05
D0
1.55±0.05
W
8±0.3
P0
4±0.1
E
1.75±0.1
F
3.50±0.1
FL P/N
2Z19200001-Q
REV.
S1
PAGE
10/11
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Inner Packing
Standard:Diameter 18cm
Standard:430×330+20mm
Material:Plastics
Name: Material:HDPE (15 reels enter)
Anti-Static Shielding Bag Standard:205
×250mm
Material:APET/CPP
Carton
Standard:400×400×280mm
Material:AB corrugated paper (4 bags
enter)
L1
L2
The label instruction
Label Drawing
Mark Name of Article
Spec.
1.Part No.
L1
条码标签
Bar Code Label 2.Lot No.
(Chintz Paper)
3.Q'ty
4.Freq
L2
条码标签
Bar Code Label
(Chintz Paper)
1.Part No.
2.Date Code
3.Q'ty
4.Freq
Size
70x50mm
Printing
White
70x50mm
White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging, please provide the operation procedure.
FL P/N
REV.
2Z19200001-Q
S1
PAGE
11/11
Range
Banned Substances
Products
Maximum concentration
ppm (mg/kg)
Packing Material
ppm (mg/kg)
1
镉及镉化合物
Cadmium and cadmium compounds
100
100
2
铅及铅化合物
Lead and lead compounds
1000
100
3
汞及汞化合物
Mercury and mercury compounds
1000
100
1000
100
1000
N/A
4
5
六价铬化合物
Hexavalent-Chromium VI (Cr+6)
聚溴联苯 PBB
Polybrominated biphenyls
6
聚溴二苯醚 PBDE
Polybrominated diphenyl ethers
1000
N/A
7
邻苯二甲酸二(2-乙基己基)酯
DEHP
Di (2-ethylhexyl) phthalate
1000
N/A
8
邻苯二甲酸丁苄酯 BBP
Butyl Benzyl Phthalate
1000
N/A
9
邻苯二甲酸二丁酯 DBP
Dibutyl Phthalate
1000
N/A
10
邻苯二甲酸二异丁酯 DIBP
Diisobutyl Phthalate
1000
N/A
11
氟(F)、氯(Cl)、溴(Br)、碘(I)
Fluorine、Chlorine、 Bromine、
Iodine
900、900、900、900
注:Br+Cl<1000
N/A
12
包装材料中重金属(汞、镉、六价
铬、铅、PBB、PBDE)之总量
Heavy metals (mercury, cadmium,
lead, Cr+6,PBB and PBDE) in packing
materials
N/A
100
铅(Pb) + 镉(Cd) + 汞(Hg) + 六价铬
(Cr+6)
很抱歉,暂时无法提供与“2Z19200001-Q”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.78210
- 100+0.73260
- 300+0.68310
- 500+0.63360
- 2000+0.60885
- 5000+0.59400
