1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 3000VA 2700W 120V DoubleConversion UPS - 7 Outlets, Extended Run,
Network Card Included, LCD, USB, DB9, 2U
Rack/Tower
Highlights
Updated design for 2023
Protects equipment against
blackouts, brownouts, transient
surges and line noise
Keeps equipment running during
outages to allow time for file
saves and safe shutdown
Zero transfer time between online and battery modes for
uninterrupted operation
Included WEBCARDLXE
network card enables full remote
access and control 24/7
Menu-driven LCD keeps you up
to date with status info and other
vital analytics
MODEL NUMBER: SU3000RTXLCD2UN
Package Includes
Provides pure sine wave output in education, healthcare, military, government and other IT applications in
small or mid-size networks.
Features
Double-Conversion UPS Protects Equipment Against Damage, Downtime and Data Loss
This on-line double-conversion UPS system maintains perfect output by converting AC input to DC, then
reconverting UPS output to fully regulated sine wave AC. Constant on-line operation completely isolates
sensitive equipment from every power problem on the AC line. The SmartOnline® SU3000RTXLCD2UN
provides the highest level of power protection and battery backup for education, healthcare, military,
government and other mission-critical IT applications where space is limited, but premium power reliability
is essential.
Reliable, Expandable Battery Backup Keeps You Operational Through Power Outages
The field-replaceable, hot-swappable VRLA battery modules allow you to work through short power
failures and give you enough time to safely save files and shut down your system in case of a prolonged
blackout. Zero transfer time between on-line and battery modes maintains continuous operation of
connected equipment without interruption or rebooting. Extra runtime is available by connecting up to four
optional extended battery modules (BP72RT, sold separately).
Pre-Installed LX Platform Network Management Card Allows Remote Access 24/7
The WEBCARDLXE network interface enables full remote configuration and management, including load
shedding, reboots of connected equipment and safe shutdowns. The IP-based Auto Probe feature
ensures continuous network uptime by communicating with other network devices, detecting lost
connectivity and automatically rebooting IT equipment. Optional EnviroSense2 modules (E2MT, E2MTDO
and E2MTHDI, all sold separately) provide a variety of environmental monitoring and control options.
NEMA Outlets Protect Your Connected Components
One L5-30R and six 5-20R outlets provide connected equipment with pure sine wave AC output and allow
you to manage power consumption down to the outlet group level. Power provided by these outlets is
filtered to protect connected equipment against damaging surges and line noise. Four 5-20R outlets are
grouped into two load banks that let you shed non-critical loads to extend runtime for critical loads.
Premium Protection from EMI/RFI Line Noise Helps Your Equipment Perform Better
1/6
WEBCARDLXE network
management card
USB cable
DB9 cable
Rack-mounting hardware
Tower support stands
Safety instructions
Quick start guide
Cleveland, OH 44122
United States
This UPS system filters out disruptive electromagnetic and radio frequency interference that can inflict
hardware damage or data loss. This EMI/RFI filtering also helps your connected components perform
better and last longer.
Clear LCD Interface Keeps You Informed at a Glance
The menu-driven front-panel LCD provides detailed alarms and notifications to help diagnose any issues.
It provides system status, event logs, battery and power module status, usage analytics, serial number,
firmware update info and more. Audible alarms can be disabled through the front menu when the UPS
goes to battery power. The LCD rotates to accommodate both rack-mount and tower installation.
Advanced Communications Ports Allow for Automatic Saves and Shutdowns
RS-232 and USB ports connect to a device for a variety of communication options (cables are included). A
dry-contact relay port can be programmed through the LCD to provide reliable communications to
automation and industrial components. The RPO/ROO port permits emergency shutdown or remote
restart of all connected equipment.Automatically Turns Back On After Power Is Restored
Battery-independent restart ensures automatic UPS power-up without user interaction after lengthy power
outages, even after a complete battery discharge.
Versatile Installation Options
You can mount the SU3000RTXLCD2UN in just 2U of space in an EIA-standard 19-inch rack using the
included hardware. You can also adapt it for tower installation using the included support stands or add
the optional RK2PC (sold separately) for 2-post rack mounting. The eight-foot power cord with NEMA L530P plug connects to a compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332253552
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 120V AC
Nominal Input Voltage Description
120V factory default
UPS Input Connection Type
L5-30P
UPS Input Cord Length (ft.)
8
UPS Input Cord Length (m)
2.4
Recommended Electrical Service
120V
Plug Type
L5-30P
8
2.44
Input Current
24A
Power Factor (Input)
0.99
2/6
Cleveland, OH 44122
United States
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2700
Output Capacity (kW)
2.7
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
120V factory-default nominal voltage
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Online Mode: Sync with line ±5% of nominal line frequency (outside this range: ±0.5% of auto-selected nominal
frequency). Battery Mode: ±0.5% of auto-selected nominal frequency
Output Voltage Regulation (Line
Mode)
+/- 1%
(Economy Line Mode)
+/- 1%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable two-outlet load banks
Output AC Waveform (AC Mode)
Pure Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 115V; 120V; 127V
Output Receptacles
(6) 5-20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4.8 min. (2700W)
Runtime Half Load (min.)
13.9 min. (1350W)
Expandable Runtime
Yes
Expandable Runtime Description
Add up to 4 extended battery modules (EBM). Part number BP72RT . *Note: BP72RT is compatible
only with the SU3000RTXLCD2UN 2023 UPS design update featured on this page. For previous
SU3000RTXLCD2UN design battery pack functionality, please see the Legacy Product Datasheet under the Support
tab, Documents & Downloads section.
External Battery Pack Compatibility
BP72RT
DC System Voltage (VDC)
72
3/6
Cleveland, OH 44122
United States
Battery Recharge Rate (Included
Batteries)
3 hours recharge to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
744-A3122 *Note: 744-A3122 is the replacement battery for the SU3000RTXLCD2UN
2023 UPS design update featured on this page. For the replacement battery in the previous design of
SU3000RTXLCD2UN, please see the Legacy Product Datasheet under the Support tab, Documents & Downloads
section.
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data,
plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional options
Switches
RPO / ROO
Alarm Cancel Operation
Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option
available
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
4 status-indicating LEDs
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
190
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
190
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( RK2PC )
Minimum Required Rack Depth (cm)
68.07
4/6
Cleveland, OH 44122
United States
(inches)
26.8
Optional Mounting Accessory Notes
2 post rail kit available, part # RK2PC
Shipping Dimensions (hwd / in.)
9.45 x 22.84 x 30.71
Shipping Weight (lbs.)
77.83
Shipping Weight (kg)
35.30
UPS Housing Material
Metal
Unit Dimensions (hwd / in.)
3.410 x 17.330 x 23.820
Unit Weight (lbs.)
63.06
Unit Weight (kg)
28.60
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
With battery: 32° to 104°F (0° to 40°C); without battery: -13° to 131°F (-25° to 55°C)
Relative Humidity
0 to 96%, non-condensing
AC Mode Efficiency Rating (100%
Load)
91.6
AC Economy Mode Efficiency Rating
(100% Load)
97.2
Online Mode Heat Dissipation
(BTU/Hr) @ Full Load
844
Battery Mode Heat Dissipation
1462
Audible Noise
47 dB at 1m
Operating Elevation (m)
Up to 3000m
COMMUNICATIONS
Network Management Cards
(1) WEBCARDLXE
Network Monitoring Port Description
WEBCARDLXE Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and
contact closure communications; not compatible with WEBCARDLX
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and RS232 cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card included
Communications Interface
(1) Included network card; (1) RS-232; (1) USB
LINE / BATTERY TRANSFER
Transfer Time
0ms
5/6
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Expandable battery backup; Hot swappable batteries; On-Line/Double-Conversion; Pure sine wave output; Remote
management; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Individually controllable load banks
APPLICATIONS
UPS Applications
Mission Critical Applications
STANDARDS & COMPLIANCE
Product Certifications
UL Listed; cUL Listed
Product Compliance
CE (Europe); ENERGY STAR Qualified; FCC (USA); REACH; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
Extended Service Plans
ADVANCED DEPOT EXCHANGEService Part Number: TL9SW5Y-3000UCParts, electronics and UPS batteries
coverageNext business day shippingTechnical support5-year onsite plan: TLWFLN75XX-6009UCOnsite parts and
labor coverage for 5 yearsParts, electronics and UPS batteries coverage24x7 onsite labor coverage, next-day
responseNext-day shippingTechnical support
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
