1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 120V 3kVA 2.4kW On-Line DoubleConversion UPS, 3U Rack/Tower, Extended Run,
WEBCARDLX Network Interface
MODEL NUMBER: SU3000RTXL3UN
Highlights
Zero transfer time suitable for
advanced network applications
+/-2% output voltage regulation
in online and battery modes
Expandable runtime with
optional external battery packs
Pre-installed WEBCARDLX
network interface for remote
UPS access
14 min. runtime at half load; 5
min. at full load
To enable the Auto Probe
feature, this product requires LX
firmware update 15.5.2 or later
to be installed
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Pre-installed WEBCARDLX network interface permits remote
UPS management.
Features
Protects Mission-Critical Rack-Mounted Equipment
● 120V 50/60 Hz output voltage with 0.8 power factor
+/-2% voltage regulation in online and battery modes
4 breakered NEMA 5-15/20R, 4 breakered 5-15R and 1 non-breakered L5-30R outlets
10-ft. (3.05 m) AC power cord with NEMA L5-30P input plug
510 joules for combating EMI/RFI line noise that can distort or destroy data
Reliable Battery Backup with Expandable Runtime
● Supports half load for 14 min. and full load for 5 min.
Zero transfer time between AC power and battery operation keeps network running during blackouts
Expandable runtime with optional external battery packs, such as Tripp Lite's BP72V15-2U
Pre-Installed WEBCARDLX Network Interface
● Allows full remote access for power monitoring, configuration, control and email notifications via secure
web browser, SNMP, telnet or SSH
Supports 10/100 Mbps auto-sensing for communication with an Ethernet network
No Java required
Broad Communications Compatibility
● Supports IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP
and NTP
Supports automatic and manual assignment of IP address
1/6
SU3000RTXL3UN SmartOnline
Double-Conversion UPS
network interface
USB cable
DB9 cable
EPO cable
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Optional Economy Mode
● High 94% efficiency in economy mode cuts BTU heat output, power consumption and energy costs
Switchable Breakered Load Banks
● NEMA 5-15/20R and 5-15R outlets divided into 2 load banks, each of which may be individually
powered on and off remotely to reset or reboot connected equipment
Front LED Panel
● 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery
condition and fault status information
Rotates for viewing in rack and tower formats
USB and DB9 Ports
● Enable data-saving unattended shutdown with Tripp Lite's PowerAlert software (available via free
download at tripplite.eaton.com/products/power-alert)
Versatile Installation Options
● Mounts in 3U of EIA-standard 19 in. 4-post rack (hardware included), 2-post rack or upright tower
position
Specifications
OVERVIEW
UPC Code
037332181466
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
Input Circuit Breakers
40A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 120V
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
2/6
Cleveland, OH 44122
United States
Output Capacity (kW)
2.4
Output Capacity Details
OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150%
load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and
frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE
bypass limits)
Power Factor
0.8
Crest Factor
3:1
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start
Output Voltage Regulation (Line
Mode)
+/- 2%
(Economy Line Mode)
+/- 10%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable four-outlet load banks, (bank 1 - four 5-15/20R, bank 2 - four 5-15R outlets)
Output Circuit Breakers
15A branch rated (x2) - each breaker protects 4 outlets, L5-30R is unbreakered
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
(4) 5-15R; (4) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5 min. (2400W)
Runtime Half Load (min.)
14 min. (1200W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC96-3U (quantity 1)
Battery Replacement Description
Hot-swappable, user replaceable batteries
3/6
Cleveland, OH 44122
United States
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 80
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 65 (under 70% load only)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown
conditions
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
510
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
73.66
(inches)
29
Minimum Required Rack Depth with
External Battery Pack (cm)
81
External Battery Pack (in.)
32
without External Battery Pack (cm)
80
4/6
Cleveland, OH 44122
United States
without External Battery Pack (in.)
31.5
Primary UPS Depth (mm)
660
Primary UPS Height (mm)
132
Primary UPS Width (mm)
452
Shipping Dimensions (hwd / in.)
12.00 x 23.00 x 32.50
Shipping Dimensions (hwd / cm)
30.48 x 58.42 x 82.55
Shipping Weight (lbs.)
110.00
Shipping Weight (kg)
49.90
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.21 x 45.21 x 66.04
(hwd, in.)
5.2 x 17.8 x 26
UPS Power Module Weight (kg)
33.48
UPS Power Module Weight (lbs.)
73.8
Unit Weight (lbs.)
74.0000
Unit Weight (kg)
33.57
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
1117
AC Economy Mode BTU / Hr. (Full
Load)
523
Battery Mode BTU / Hr. (Full Load)
1224
AC Economy Mode Efficiency Rating
(100% Load)
94%
COMMUNICATIONS
Network Management Cards
WEBCARDLX
Network Monitoring Port Description
Includes pre-installed Network Management Card; DB9 port supports RS232 and contact closure communications;
Economy-mode setting option is available using PowerAlert software and DB9 Serial cable connection OR installed
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
5/6
Cleveland, OH 44122
United States
Description
Network management card included
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface;
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 65V (
