1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartOnline 120V 3kVA 2.7kW On-Line DoubleConversion UPS, 2U Rack/Tower, Extended Run,
Network Card Option, ENERGY STAR
MODEL NUMBER: SU3000RTXL2U
Highlights
Zero transfer time between AC
power and battery operation
+/-2% output voltage regulation
in online and battery modes
Expandable runtime with
optional external battery packs
Optional WEBCARDLX network
interface for full remote access
13.8 min. runtime at half load;
4.8 min. at full load
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, surges and line noise. Converts incoming AC power to filtered DC power, then back to AC with
a pure sine wave.
Features
Protects Mission-Critical Rack-Mounted EquipmentProtects equipment against data loss, downtime
and damage due to power outages, voltage fluctuations and transient surges+/-2% voltage regulation in
online and battery modesSelectable 120V 50/60 Hz output voltage with up to 0.9 power factor6 breakered
NEMA 5-15/20R and 1 non-breakered L5-30R outlets10-ft. (3.05 m) AC power cord with NEMA L5-30P
input plug504-joule surge protection rating for shielding connected devices from damaging power surges
and spikes
Reliable Battery Backup with Expandable RuntimeSupports half load for 13.8 min. and full load for 4.8
min.Zero transfer time between AC power and battery operation keeps network running during
blackoutsExpandable runtime with optional external battery packs, such as Tripp Lite's BP72V15-2U
ENERGY STAR Version 2.0 CertificationHigh efficiency operation and low BTU heat output reduces
energy costs and meets strict EPA guidelines
Switchable Breakered Load BanksNEMA 5-15/20R outlets divided into 2 numbered load banks, each of
which may be individually powered on and off remotely to reset or reboot connected equipment
Front LED Panel14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload,
battery condition and fault status informationRotates for viewing in rack and tower formats
Audible AlarmIndicates power failure, overload, battery condition and EPO operation
Communications PortsUSB and DB9 ports enable data-saving unattended shutdown when used with
Tripp Lite's PowerAlert software (available via free download at tripplite.eaton.com/products/poweralert)Optional WEBCARDLX allows full remote access for power monitoring, configuration, control and
email notifications via secure web browser, SNMP, telnet or SSH
Versatile Installation OptionsHardware included for 4-post mounting in 2U of EIA-standard 19 in.
rackMounts in 2-post rack with optional 2POSTRMKITWMMounts in upright tower position with optional 29USTAND
1/6
SU3000RTXL2U SmartOnline
Double-Conversion UPS
USB cable
DB9 cable
EPO cable
Rack-mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332197023
UPS Type
On-Line
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A maximum
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
Recommended Electrical Service
30A 120V
Input Cord Length (ft.)
10
Input Cord Length (m)
3.05
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2700
Output Capacity (kW)
2.7
Output Capacity Details
INVERTER SHORT-CIRCUIT PROTECTION: Inverter short-circuit protection is electrically protected; OVERLOAD
CAPACITY: Supports inverter operation up to 105% load continuously, 125% for 30 seconds, 150% for 10 seconds
and >150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN
bypass limits of 120V ±10%) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits
of 120V ±10%).
Power Factor
0.9
Crest Factor
3:1
Nominal Voltage Details
120V default
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Accepts 40 to 70Hz input frequency. Output frequency matches input nominal on startup, defaults to 60 Hz on coldstart. Frequency conversion from 60 to 50 Hz -or- 50 to 60 Hz supported. Output capacity de-rates to 70% of
normal levels during frequency conversion operation.
Output Voltage Regulation (Line
Mode)
+/- 2%
Output Voltage Regulation (Battery
Mode)
+/- 2%
Load Management Receptacles
Two switchable three-outlet load banks
Output Circuit Breakers
20A (x2) - each breaker protects 3 5-15/20R outlets, L5-30R outlet is un-breakered
Output AC Waveform (AC Mode)
Pure Sine wave
2/6
Cleveland, OH 44122
United States
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 115V; 120V; 127V
Output Receptacles
(6) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4.8 min. (2700W)
Runtime Half Load (min.)
13.8 min. (1350W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP72V15-2U (limit 1); BP72V28RT-3U (multi-pack compatible); BP72V18-2US (multi-pack compatible)
DC System Voltage (VDC)
72
Battery Recharge Rate (Included
Batteries)
Less than 8.1 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
See RBC selector guide (replacement battery part number is also labeled on the internal battery door)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Online, double-conversion power conditioning
Overvoltage Correction
ONLINE MODE: 2% output voltage regulation during overvoltages to 150
Undervoltage Correction
2% output voltage regulation during undervoltages to 80V (66-100% load)
Severe Undervoltage Correction
2% output voltage regulation during undervoltages to 70V (33-66% load) or 60V (under 33% load)
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power failure, low battery, overload, replace battery and EPO operation
LED Indicators
14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery
and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in
rack/tower formats
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
504
EMI / RFI AC Noise Suppression
Yes
3/6
Cleveland, OH 44122
United States
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Includes 4 post rackmount installation accessories
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITWM ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
71.12
(inches)
28
Minimum Required Rack Depth with
External Battery Pack (cm)
77
External Battery Pack (in.)
30.25
without External Battery Pack (cm)
74
without External Battery Pack (in.)
29.25
Primary UPS Depth (mm)
616
Primary UPS Height (mm)
88
Primary UPS Width (mm)
438
Shipping Dimensions (hwd / in.)
9.45 x 23.62 x 29.92
Shipping Dimensions (hwd / cm)
24.00 x 59.99 x 76.00
Shipping Weight (lbs.)
87.00
Shipping Weight (kg)
39.46
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
8.79 x 43.79 x 61.60
(hwd, in.)
3.46 x 17.24 x 24.25
UPS Power Module Weight (kg)
31.17
UPS Power Module Weight (lbs.)
68.72
Unit Weight (lbs.)
68.720
Unit Weight (kg)
31.17
4/6
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
5 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
531
AC Economy Mode BTU / Hr. (Full
Load)
484.5
Battery Mode BTU / Hr. (Full Load)
1037
AC Economy Mode Efficiency Rating
(100% Load)
95%
Audible Noise
50 dBA max, front-side @ 1m
COMMUNICATIONS
Network Management Cards
WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure
communications
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports and modify the UPS Power Strategy settings
download PowerAlert software at https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
No transfer time (0 ms.) in online, double-conversion mode
Low Voltage Transfer to Battery
Power (Setpoint)
80V (100% load), 70V (66% load), 60V (33% load)
High Voltage Transfer to Battery
Power (Setpoint)
150
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries;
Remote management; Surge/noise protection; Zero transfer time
Green Energy-Saving Features
High efficiency economy mode operation; Individually controllable load banks; Schedulable daily hours of economy
mode operation
Grounding Lug
Includes back-panel grounding lug
STANDARDS & COMPLIANCE
5/6
Cleveland, OH 44122
United States
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; ENERGY STAR Qualified; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
