1000 Eaton Boulevard
Cleveland, OH 44122
United States
Smart Online Expandable Rack/Tower UPS
System - Online, double-conversion protection
for mission critical applications
Highlights
1500VA online 2U expandable
rack / tower UPS
Enhanced serial
communications port and
SNMP/Web card slot
Maintains 120V +/-2% output
during overvoltages to 138 and
brownouts as low as 65V
2 load banks, 6 outlets
Fault tolerant auto-bypass
$250,000 Ultimate Lifetime
Insurance (USA, Puerto Rico &
Canada only)
MODEL NUMBER: SU1500RTXL2U
Description
Tripp Lite's Smart Online SU1500RTXL2U on-line, double conversion UPS protects critical server,
networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges.
Multi-use form factor occupies only 2 rack spaces (2U) in standard 19 inch rackmount configuration and
includes tower stands to support upright placement. Large capacity 1.5kVA/1200 watt UPS continuously
converts incoming AC to DC, then back to perfect sine wave AC output at 120V AC (+/-2%). Removes
harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power
problems not addressed by other UPS types. True sine wave output and zero transfer time offers
guaranteed compatibility with all equipment types. Includes 6 outlets arranged in two individually
switchable load banks that can be independently controlled via software interface to selectively reboot
remote equipment, or shed less critical loads to extend battery runtime for more critical equipment. Battery
support can be extended indefinitely through the addition of external 2U rackmount battery packs (part#
BP48V212U). Includes slot for internal SNMP/web card, plus DB9 enhanced serial monitoring port for
unattended shutdown, remote control and monitoring of UPS system and power data. Compatible with
Tripp Lite's Watchdog system service software.
Package Includes
SU1500RTXL2U Online DoubleConversion UPS System
PowerAlert Software and
cabling
Mounting hardware for 4 post
rack enclosures/tower stands
Instruction manual with warranty
information
Features
True on-line, double conversion UPS provides pure, sine wave AC output at all times
Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer
time
Removes harmonic distortion, electrical impulses, frequency variations and other hard to solve power
problems
Accepts input voltages between 80 and 138 (65 to 138 at loads under 70%), regulating output to 120V
+/-2%
1500VA/1200 watt power capacity with 6 NEMA 5-15R outlets
Standard internal battery set provides 17 minutes runtime at half load
Expandable runtime with multiple external battery packs (part# BP48V212U)
Innovative design makes unit adaptable for rackmount or tower applications (tower stands included)
Uses only 2 rack spaces (2U) in standard 19 inch rack
DB9 serial port for network interface; SNMP compatible
Slot for optional SNMP/web card (part# SNMPWEBCARD)
PowerAlert unattended shutdown software and 6 ft. network cable included
Compatible with Tripp Lite's Watchdog system service software
Fault tolerant auto-bypass maintians continuous utility output to connected equipment, even in cases
where the UPS is overloaded or suffers an internal failure that requires service
Diagnostic LEDs
Battery replacement door
Mounting hardware included for 4 post rack enclosures, 2 post telecom rack compatible with separate
purchase 2POSTRMKIT accessory
$250,000 Ultimate Lifetime connected equipment insur
2 year manufacturers product warranty
Specifications
1/4
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332117168
INPUT
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
Maximum Input Amps
12
Maximum Input Watts
1395
Input Connection Type
NEMA 5-15P
Voltage Compatibility (VAC)
120
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Nominal Voltage
120V AC
Output Voltage Regulation
Maintains full-time sine wave output within 2% of 120V, less than 5% total harmonic distortion
Output Frequency Regulation
Regulates line frequency to 50/60Hz +/- 0.05Hz
Overload Protection
Via input breaker
Customized Load Management
Receptacles
"2 individually controllable load banks support automated load shedding and remote reboot on demand of locked
network devices. Configurable via PowerAlert software to automatically switch off optional loads, like monitors, to
increase available runtime for servers and other critical devices. (Bank A consists of 4 outlets / Bank B consists of 2
outlets) "
BATTERY
Runtime Full Load (min.)
Internal batteries — 5 min. /1 BP48V212U battery pack (1500VA) — 28 min.
Runtime Half Load (min.)
Internal batteries — 17 min. / 1 BP48V212U battery pack (750VA) — 74 min.
Expandable Runtime
Yes
Expandable Runtime Description
Supports extended runtime with optional external battery pack BP48V212U (multi-pack compatible)
DC System Voltage (VDC)
48
Battery Access
User replaceable, hot swap battery replacement supported via front access panel
Battery Pack Accessory (Optional)
BP48V212U (optional)
Typical Battery Lifespan
3-6 years, depending on usage
Battery Charge
2-4 hours to 90%
VOLTAGE REGULATION
Voltage Regulation Description
On-line, double-conversion power conditioning maintains output within 2% of 120 volts at all times
Overvoltage Correction
Maintains output of 120V +/-2% without consuming battery power during overvoltages to 138V AC
Brownout Correction
Maintains output of 120V +/-2% during undervoltages to 80V AC
2/4
Cleveland, OH 44122
United States
Severe Brownout Correction
At load levels less than 70%, UPS maintains output of 120V +/-2% during undervoltages to 65V AC
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
6 LED STATUS DISPLAY: line power (green), online (green), bypass (yellow), on battery (green), overload (red),
battery low (yellow) 4 LED LOAD / BATTERY LEVEL DISPLAY (100%, 75%, 50%, 25%)
Switches
Includes main power off/on switch, plus 1 switch to select battery charge / load level display
Audible Alarm
Multi-function audible alarm offers notification of UPS start, backup operation, low battery warning, overload, UPS
fault and remote shutdown
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
2440
EMI / RFI AC Noise Suppression
Yes
AC Suppression Response Time
Instantaneous
PHYSICAL
Material of Construction
Steel
Cooling Method
Built-in cooling fan
Form Factors Supported
Supports 2U rackmount installation in 4 post rack enclosures. 2 post rackmount installation supported with optional
2POSTRMKIT. Upright tower installation supported with included tower stands
Shipping Dimensions (hwd / in.)
8.00 x 23.50 x 31.00
Shipping Dimensions (hwd / cm)
20.32 x 59.69 x 78.74
Shipping Weight (lbs.)
63.80
Shipping Weight (kg)
28.94
Unit Dimensions (hwd / in.)
3.500 x 17.500 x 22.000
Unit Dimensions (hwd / cm)
8.89 x 44.5 x 52.8
Unit Weight (lbs.)
49
Unit Weight (kg)
22.23
ENVIRONMENTAL
Relative Humidity
0 to 95%, non-condensing
COMMUNICATIONS
WatchDog Compatibility
Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft
reboot of application / OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk
applications
Network Monitoring Port
Built-in DB9 port offers both enhanced RS-232 enable monitoring data, plus contact closure monitoring ability
EPO Port
Supports "Emergency Power Off" via special-order cabling, contact Tripp Lite for more information
SNMP Compatibility
Yes, includes slot for optional SNMPWEBCARD accessory (#SNMPWEBCARD)
LINE / BATTERY TRANSFER
3/4
Cleveland, OH 44122
United States
Transfer Time (Line Power to
Battery Mode)
Zero, online UPS continuously converts incoming AC to DC, then back to AC. When commercial power is
interrupted, UPS maintains continuous output from battery reserves with absolutely no disruption in output AC
power.
Low Voltage Transfer to Battery
Power
Maintains continuous operation during undervoltages as low as 80V (65V at load levels under 70%). Below this
switchover point, output is supported from battery derived AC power.
High Voltage Transfer to Battery
Power
Maintains continuous operation without using battery power during overvoltages to 138V. Above this point, output is
FEATURES & SPECIFICATIONS
Cold Start
Yes, inverter can be "cold started" to enable temporary AC output during a power failure
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Optional Coverage
3-5 year warranties, plus next day and on-site warranty coverage available for select opportunities. Contact Tripp
Lite for additional information.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
